Old Oct 28, 2013, 05:26 AM
X1AaronW is offline
Find More Posts by X1AaronW
Joined Oct 2013
scale sub prop vs boat prop
Im designing my first submarine to be made from pvc. Im putting in 2200kv brushless motor 36mm wide x 60mm long. Im building it to achieve the highest speed possible. My question is would scale sub prop be all around better than that of a 2 or 3 bladed boat prop?
X1AaronW is offline Find More Posts by X1AaronW
Old Oct 29, 2013, 04:31 AM
DDG 51 is offline
Find More Posts by DDG 51
DDG 51's Avatar
EUrope
Joined Apr 2008
If do you using high power brushless motor, with relativly high RPM per Volt, you have use 5-7 bladed Raboesh prop. I have 40-30 motor in my sub, with 7 blades 70mm prop, and result is excellent.Speed is great. But hight speed sub as a first sub ever..... I do not know, if this is good idea
DDG 51 is offline Find More Posts by DDG 51
Old Oct 29, 2013, 05:22 AM
X1AaronW is offline
Joined Oct 2013
I get that it could run a 70mm prop but you would need a gear reduction. Im going direct drive. The recommended size for this motor is 40mm x 2.198 pitch
and im assuming thats for a 2 bladed boat prop. A 5-7 would look awesome but I not really looking for scale appearance. Im just not sure what would achieve the greatest speed without burning up my motor.
Old Oct 29, 2013, 12:43 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Originally Posted by X1AaronW View Post
The recommended size for this motor is 40mm x 2.198 pitch and im assuming thats for a 2 bladed boat prop.
That's the recommended prop for a planing type boat hull. That's not necessarily the best prop for a submerged displacement hull.
Give the 40mm x 2.198 itch prop a try - don't be surprised if it doesn't work right the first few times. There may be prop torque induced problems.
CG Bob is offline Find More Posts by CG Bob
Old Oct 29, 2013, 03:10 PM
X1AaronW is offline
Joined Oct 2013
I figured a smaller prop would work better to help compensate for the torque. Would that help?
Old Nov 04, 2013, 03:37 AM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
the reccomended prop is most likely for a surface drive where the prop is half out the water, Im guessing that a reduction of prop size by 25% would be needed to ensure thew motor is not overloaded in the subsurface configuration.
Nick
nick_75au is offline Find More Posts by nick_75au
Old Nov 04, 2013, 08:43 PM
X1AaronW is offline
Joined Oct 2013
Thats kinda what I was thinking but needed to hear it
Discussion Regular props vs. 3 blade props for multi rotor application Disp0sablehero Multirotor Talk 11 May 07, 2014 04:01 AM
Question Low Kv - big prop vs. High Kv small prop neavissa Multirotor Electronics 35 Apr 09, 2013 02:40 PM
Question Higher KV & Smaller Prop VS. Lower KV and Bigger Prop fnffishcore Power Systems 4 Jan 22, 2013 10:14 PM
Discussion Confused - prop size vs motor size vs thrust cloud_9 Power Systems 26 Jan 14, 2013 03:05 AM
Discussion "Pond Boat" vs. "Scale Boat" patmat2350 Scale Boats 90 May 31, 2009 09:27 PM
