This thread is privately moderated by pacoflyer, who may elect to delete unwanted replies.
Old Oct 25, 2013, 10:53 AM
pacoflyer is offline
Find More Posts by pacoflyer
Trader Rating: 4
United States, NY, Buffalo
Joined Oct 2007
Trader Rating: 4
For Sale
OS 120 Gemini Twin
Almost new OS 120 Gemini twin.
Bench run once just to hear her purr.
$375 shipped.
pacoflyer is offline Find More Posts by pacoflyer
Old Oct 25, 2013, 08:54 PM
sdstick is offline
Find More Posts by sdstick
Trader Rating: 117
Flying RC since 1962
sdstick's Avatar
United States, TN, Columbia
Joined Mar 2006
Trader Rating: 117
Are parts still available for this engine?
sdstick is offline Find More Posts by sdstick
Old Oct 25, 2013, 09:20 PM
CryHavoc is online now
Find More Posts by CryHavoc
Trader Rating: 109
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
United States, CA, San Diego
Joined Apr 2000
Trader Rating: 109
Only those shared with the 160 Gemini twin.
CryHavoc is online now Find More Posts by CryHavoc
Old Oct 26, 2013, 03:28 AM
Vigger is offline
Find More Posts by Vigger
Trader Rating: 1
Denmark, Syddanmark, Vejle County
Joined Jun 2013
Trader Rating: 1
Which is pretty much only the connecting rod.
All other parts are either discontinued or parts you probably wont need to change like (rocker cover)
Vigger is offline Find More Posts by Vigger
Old Oct 26, 2013, 01:13 PM
sdstick is offline
Trader Rating: 117
sdstick's Avatar
Joined Mar 2006
Trader Rating: 117
I am getting ready to build a Sig 1/4 scale Cub, this would be a nice engine for it but not being able to get parts sure scares me.
Old Oct 26, 2013, 01:47 PM
sdstick is offline
Trader Rating: 117
sdstick's Avatar
Joined Mar 2006
Trader Rating: 117
What is the weight and power difference between the 120 twin and 160 twin?
Old Oct 27, 2013, 10:38 AM
Fidelity101 is online now
Find More Posts by Fidelity101
Trader Rating: 173
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
Trader Rating: 173
I've seen this engine in person and it's beautiful! Pacoflyer is a top notch seller...he's new to rcgroups but has been very active in rcuniverse for many years under the same username. Buy with confidence!
Specs for 160:
SPECS: Construction: Aluminum and Aluminum alloys
Displacement: 13.26cc (x2) or .809 cu in (x2)
Bore: 27.7mm (1.09")
Stroke: 22.0mm (.866")
Power Output: 2.0 BHP at 10,000 RPM
Weight: 1100g (38.8oz)
Practical RPM Range: 2,000 - 10,000 RPM
Length: 120mm (4.72") from backplate to front of the drive washer
Width: 196mm (7.72")
Height: 80mm (3.15")
Crankshaft Thread Size: 5/16-24
Suggested Props: 15x8, 16x6, 18x6, 18x7, 18x8, 20x6
Width (outer cylinder jacket to outer cylinder jacket): 120mm (4.72")
Specs for 120 series 2:
From the tech notes:
Displacement: 9.95 cc (X2) or .607 cu in (X2)
Bore: 24.0mm (.945") Stroke: 22.0 (.866")
Power Output: 1.7 BHP at 10,000 RPM Weight: 1090g (38.5 ozs)
Suggested Props: 14X9,14X10,14X11,15X8,15X9,15X10,16X6,17X6,18X6
Fidelity101 is online now Find More Posts by Fidelity101
Old Oct 27, 2013, 10:44 AM
Trader Rating: 173
Go fast, pull up.
Joined Nov 2008
Trader Rating: 173
Just found this...regarding replacement parts:
Originally Posted by corsair167 View Post
My information comes from a 1990 2nd edition OS Engines exploded views book. Listed by part numbers, the Gemini II is the better engine and shares alot of parts with the 160. Rods are used in 120II,160,240, & 320. Cylinders are different, but heads, crank, case, cam,etc are the same as the 160 twin. I have a 160 Gemini purchased new in the 90's. I use Wildcat 2-4 stroke fuel at 10% but my Satio 150 likes 15%. Hope this helps. If you want, I can email the info too. Larry
Old Oct 27, 2013, 10:55 AM
Trader Rating: 173
Go fast, pull up.
Joined Nov 2008
Trader Rating: 173
Vigger, I'm not sure this is accurate information...according to the OS users manual as well as rcuniverse and rcgroups posting from the past several years. It would be an accurate statement if you were talking about version 1, but this is clearly version 2 which shares many of the same parts as the 160.
Old Oct 27, 2013, 03:36 PM
Vigger is offline
Trader Rating: 1
Joined Jun 2013
Trader Rating: 1
The first version is a completely different design based primarily on FS 60 with almost no parts shared with the later FT 120 (piston ring is one of the few)
The later version along with the FT 160 (sister models) is based of the FS 80 and the early pre-surpass models and thus shares a few parts. But those parts you would really be interested in (piston ring, piston, cylinder head, valves, and liner) is different.
However they do share the connecting rod, crank and cam but those parts might not be the parts you would need to change in a rebuild.
The heads are definitely not interchangeable, the bore is larger on the 160 and thus can not fit in the 120 head same goes for the valves.
I have all those engines, i can check and or scan the manuals if needed :-)
Old Oct 27, 2013, 04:29 PM
Vigger is offline
Trader Rating: 1
Joined Jun 2013
Trader Rating: 1
And to make things even more complicated, 3 very different con rods with same part number has been used in this engine since it's introduction. And since this is one of the earliest it is hard guess which of those this engine has.
Parts or not, this engine is very nice if you don't care too much about the power/weight ratio i will definitely recommend this engine.
@Seller: If you haven't sold this engine by the end of the month, i'll take it for a bit lower price if interested :-)
Old Oct 27, 2013, 04:50 PM
Trader Rating: 173
Go fast, pull up.
Joined Nov 2008
Trader Rating: 173
Ok, you've got more experience than I... Thanks for the good information!
Old Oct 27, 2013, 10:24 PM
shooboy is online now
Find More Posts by shooboy
Trader Rating: 214
United States, NY, Spencerport
Joined Aug 2011
Trader Rating: 214
This is a great deal on this engine and should run great for many years. I have NEW pistons, rings, heads, cylinders, and valve covers for this engine if anyone decides to buy this engine. I also have a nice used crankcase. this engine should be priced over $500.... can't believe it's still here.....
P.S. Pacoflyer is a fantastic person to deal with, don't let the zero feedback scare you, a true gentleman and you will get exactly what's advertised
shooboy is online now Find More Posts by shooboy
Old Oct 27, 2013, 10:38 PM
redball8 is offline
Find More Posts by redball8
Trader Rating: 162
What - Me Hurry?
redball8's Avatar
United States, IL, Naperville
Joined Jul 2004
Trader Rating: 162
There's a fellow on RCU that offered full price for the motor, and the RCU listing was taken down (technical problems with the site, too). My guess is it's sold.
redball8 is offline Find More Posts by redball8
Old Oct 27, 2013, 10:43 PM
Trader Rating: 214
Joined Aug 2011
Trader Rating: 214
It may be, I spoke with him yesterday personally at a swap meet and I thought he said he still had it. Of course it may have sold in the last 24 hours. I was thinking of selling my 160 and that's what brought up that conversation....Shoo
Found OS 120 Gemini Twin LJE4357 Aircraft - Fuel - Engines and Accessories (FS/W) 7 Oct 26, 2013 10:31 AM
Sold OS FT-120 Gemini (Not GemInI II) rcb7761 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jun 27, 2013 07:43 AM
Wanted Wanted: OS Gemini II 120 Twin jjrobertson Aircraft - Fuel - Engines and Accessories (FS/W) 6 Feb 26, 2013 10:46 PM
os 120 gemini 2 twin dpenoncello Non R/C Items (FS/W) 0 Feb 25, 2013 06:20 PM
Sold New In The OS 120 GEMINI 120 Twin Cylinder Four Stroke R/C Model Airplane Engine LCS Aircraft - Fuel - Engines and Accessories (FS/W) 5 Sep 05, 2012 10:47 AM
