Old Dec 11, 2001, 07:01 AM
Bleriot is offline
Find More Posts by Bleriot
Bleriot's Avatar
Joined May 2000
7.2-7.5V Voltage regulator
Hi Is there a circuit diagram using easily available parts to build a voltage regulator to put in between a 3 cell Tadrian Lithium Battery pack (10.2V off the charger) and the esc so that the esc never sees more than 7.5 volts? Thank you. Best Regards
Bleriot is offline Find More Posts by Bleriot
Old Dec 11, 2001, 10:03 AM
rlt55 is offline
Find More Posts by rlt55
Senior Moment
rlt55's Avatar
Woburn, MA, USA
Joined Jul 2001
Here is a 1 amp unit http://www.epanorama.net/circuits/lm317.html
I use them all the time. Work just fine.
rlt55 is offline Find More Posts by rlt55
Old Dec 11, 2001, 08:33 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Here's another:
Li-Ion Charger
Notes & Hints:
Keep a fire extenguisher handy!!!
Don't drill cooling hole in batteries.
Gene Bond is offline Find More Posts by Gene Bond
Old Dec 11, 2001, 10:46 PM
Quacker is offline
Find More Posts by Quacker
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
Hi Bleriot. I just found this thread. The LM317 has an internal current limiter that may be too low for you. The TO-220 package is limited at 1.5 amps peak. After this point, the voltage will drop off in order not to excede 1.5 amps. The part also has a minimum voltage drop of about 2.25 volts at 1.5 amps. This means that as your battery voltage drops, it will have to be more than 7.5 + 2.25 = 9.75 volts to keep the voltage in regulation. If the battery gets lower than this, the output of the 317 drop down as well. There are regulators that have a lower (better) dropout voltage than this. You should also anticipate needing a heatsink.
Quacker is offline Find More Posts by Quacker
Site Sponsor
Old Dec 13, 2001, 12:22 AM
Mauilvr is offline
Find More Posts by Mauilvr
Almost a Pilot
Mauilvr's Avatar
NorCal
Joined Oct 2001
Bleriot:
You can't drill cooling holes in the regulators either.
Don't waste your time writing National Semicinductor asking them to drill cooling holes in their regulators - they won't listen either.
Mauilvr is offline Find More Posts by Mauilvr
GWS "BP15A" ESC set at 7.5V for 3 lipos... Suspenders Scratchbuilt Indoor and Micro Models 2 Aug 13, 2005 07:54 AM
Question Beginner's question about voltage regulator/2-cell lipo nessuno Scratchbuilt Indoor and Micro Models 5 May 15, 2005 07:25 PM
Alert 7.5v on a 7.4v battery? hingus2000 Micro Helis 6 Sep 24, 2004 07:27 PM
9.0V or 7.2 for Cuttoff Voltage on 3S Lipoly?? Orion_V Batteries and Chargers 5 Jun 27, 2004 06:24 PM
Need help building 8 cell -> 7.5V SMPS Ben C Life, The Universe, and Politics 6 Oct 24, 2002 03:32 PM
