Old Oct 24, 2013, 02:31 PM
Harry_RC is offline
Find More Posts by Harry_RC
United States, IL, Chicago
Joined Oct 2013
Bend in antenna - field effect?
Hi, I have a HK 2.4GHz receiver with a simple wire for an antenna. Does anyone know how the EM field will change if I bend the antenna/wire, or route it with two 90 degree turns?
The reason I ask, is that I would like to have the antenna make a 90* turn to go through my plane's foam to it's external surface, then another 90* turn to run along its outer surface. Any thoughts on how that will affect signal transmission? Do the antennas have to be perfectly straight?
Sort of a second question, does EPO foam attenuate the signal much? Should I just leave it inside the foam, rather than trying to make two turns to get it to the exterior?
Sorry if that is confusing or doesn't make sense. Any advice appreciated!
Harry
Harry_RC is offline Find More Posts by Harry_RC
Old Oct 24, 2013, 02:50 PM
Rodney is online now
Find More Posts by Rodney
Florida
Joined Aug 2004
The antenna is only that last 28 to 32 mm (the part that looks like a bare wire). The material that connects that antenna to the receiver is a coaxial cable ( a conductor inside a hollow metallic tube separated by an insulation--Google Coax for a good explanation). This cable can be gently bent if you are careful to not get a crimp in it or deform it in any way. Any change in the dimensions between the inner conductor and that outer sheath can have very undesirable effects on the reception but gentle curves will be okay.
Rodney is online now Find More Posts by Rodney
Old Oct 24, 2013, 03:01 PM
Harry_RC is offline
Joined Oct 2013
Rodney - thanks so much.
Any idea how much EPO foam (Bixler2) attenuates the signal? Is it ok to just leave it inside, or worth it to run outside the foam?
Old Oct 24, 2013, 06:38 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Unless the foam is coated in a metallic paint, attenuation is near zero.
Wintr is offline Find More Posts by Wintr
Old Dec 08, 2013, 03:14 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
If at all possible.
NEVER ,fold, bend or coil any high frequency antenna. UNLESS you can check with a manufacturer.................NEVER CUT OR SHORTEN any antenna.
cyclops2 is offline Find More Posts by cyclops2
Old Dec 08, 2013, 04:31 PM
Rhea is offline
Find More Posts by Rhea
Registered with FAA since 2016
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
Ditto all of the above
Rhea is offline Find More Posts by Rhea
Old Dec 08, 2013, 11:24 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by cyclops2 View Post
If at all possible.
As stated previously, the antenna proper is the last 30mm or so and it should be kept reasonably straight and not cut. Coiling the connecting cable, however, is not a problem. The only risk is in kinking the cable sharply, which can easily damage it.
The reference to a "simple wire" in the original post is almost certainly wrong, as a 30mm wire would not be long enough for the two 90 degree bends described. The antenna must be coax with the last 30mm stripped.
Daedalus66 is offline Find More Posts by Daedalus66
Discussion Does antenna type effect current draw? RobinBones FPV Equipment 1 Oct 11, 2013 04:29 AM
Discussion sma to rp-sma connector will effect the antenna quality? squid10 FPV Talk 2 Apr 08, 2013 09:29 AM
Question What are the effects of changing the length of a TX's antenna?? TECH GEEK Electric Plane Talk 5 Jan 27, 2013 09:46 AM
Discussion 5.8 GHz Bluebeam Whip Antenna - bend or 90 deg SMA? CactusJackSlade FPV Talk 1 Jan 18, 2012 06:52 AM
