Old Dec 01, 2013, 04:46 PM
HELIRON69 is offline
Find More Posts by HELIRON69
HELIRON69's Avatar
United States, PA, Chambersburg
Joined Feb 2010
They have CW and CCW for a reason. It depends on how the finger brushes lay on the armature. Run the wrong way and they will not last long.
HELIRON69 is offline Find More Posts by HELIRON69
Old Dec 01, 2013, 05:13 PM
jgestner is offline
Find More Posts by jgestner
United States, WI, Merrill
Joined Jun 2011
Originally Posted by pakrat961 View Post
"Listed" rotation shouldn't matter, just wire 'em backwards. No?
I'm not sure how long the motors brushes would last if spinning the opposite direction intended. I haven't taken any time to experiment with that, but I remember a few folks unhappy with the longevity of some Horizon/Blade mQX motors and trying the opposite brushed version. As I recall some had reasonable success, but as flimsy as these pager motor brushes are I would not expect the same results when spinning towards and pushing the wiper/brushes into their mounts.
I actually want to try replacing all four motors with THIS one: http://www.microflight.com/Online-Ca...Coreless-Motor
I'm curious to see how the lower resistance and different size motor affect performance. I have two bum-motors on mine already (I guess I'm kinda rough with it), so I don't have much to lose by tearing it apart.
I also would not want to experiment with trying to stuff a 7mm X 16.5mm motor into the flimsy frame of the Proto when the mounting holes for 6mm X 12mm are already making that area the weakest point on the whole quad. But enjoy to hear how and if that works out. You are also talking about a 2.9 gram motor X 4 vs 1.3 gram motor X 4 weight difference. Oh Well.
I anxiously await your results.
But ENJOY every experiment as if it may be your last.
John
Motor Specifications
Motor 3.3ohm
Case Size 7mm x 16.5mm
Wire Length 60mm
Connector Type 1.27mm Nano
Suggested Propeller Tri-Turbofan Prop
Shaft Size 1mm
Weight 2.9g
Current draw with suggested prop about 500mA
Thrust with suggested prop estimated 11 grams static thrust
These are great little Motors, a direct replacement for the SS Orange (same motor) and has a Micro Connector are pre-installed. These motors have long 60mm leads for easy installation. 1mm Shaft. 2.9g
jgestner is offline Find More Posts by jgestner
Old Dec 01, 2013, 11:00 PM
Mid7night is online now
Find More Posts by Mid7night
I make planes I want to fly
Mid7night's Avatar
Southern Cal.
Joined Mar 2004
John
You clearly haven't seen how many of my previous experiments have turned out... ::cough::lawn darts::cough:: But I learned something about every crash!
I don't think I'd call the motor mounts the weakest part of the Proto-X, and I certainly wouldn't call it flimsy. I got caught in an updraft outdoors, lost control and it fell about 30ft onto asphalt; no damage. I was able to buffer it a little with some last minute thrust right before impact, but it felt the majority of the fall directly. Pretty tough little bird. If anything, I'd peg the motors themselves as the weakest link in the whole system, besides having a loose mount.
Also, I wouldn't stuff the bigger motor through the original little hole, I'd probably figure out how to just mount them on top of the frame (hotglue to the rescue)
Another challenge would be fitting the props onto the 1mm shaft; I don't think I have a 1mm drill bit...
Maybe I'll get some play-money for Christmas and try it out. Heck, if it works, and produces more thrust, we may have a candidate for Tiniest Quad-Cam! (hey, I can daydream)
Mid7night is online now Find More Posts by Mid7night
Old Dec 01, 2013, 11:05 PM
Kev71H is offline
Find More Posts by Kev71H
Kev71H's Avatar
San Jose, California, United States
Joined Apr 2002
FYI
Even THiS much adjustment helps!!! I may glue them there. Just carefully pull them up.
Kev71H is offline Find More Posts by Kev71H
Old Dec 02, 2013, 07:37 AM
3vw is offline
3vw
Find More Posts by 3vw
3vw
3vw's Avatar
Joined Jun 2004
Originally Posted by HedRick View Post
I wonder if the extra weight will affect motor life.
How is the COG with those batts? Does the gyro take over?
The use of the large-er batteries was more of an experiment than anything just to see if they would work. Since having found the Hobbytown Ares 100mah battery (with wire & connector configured RTF) I tend to only use them now.
Having said that, when using the BIG batteries that hang over the front... I needed to compensate by clicking the rear trim to balance it out in a hover. FYI when using the largerest 200mah, it took as much as 18 clicks to the rear to trim it out
BTW I realise I could have turned the battery sideways and mounted it that way (with making a longer wire) for better COG but it wasn't worth the effort at the time... just buy the Ares batteries and you'll simply have plug & play.
3vw is offline Find More Posts by 3vw
Old Dec 02, 2013, 10:49 AM
volcomsnows2k is online now
Find More Posts by volcomsnows2k
Spicy Torque Roll!
volcomsnows2k's Avatar
USA, CA, Pasadena
Joined Dec 2006
Hey pilots, anyone know where to buy replacement propellers for this little quad yet? Too many back pages to read through! Thanks everyone!
volcomsnows2k is online now Find More Posts by volcomsnows2k
Old Dec 02, 2013, 10:54 AM
Ssayer is offline
Find More Posts by Ssayer
Oldie, not Moldie
Ssayer's Avatar
United States, MI, Leonard
Joined Feb 2012
Bought some from Tower Hobbies last week...
Ssayer is offline Find More Posts by Ssayer
Old Dec 02, 2013, 02:55 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I could not trim/stabilize my Proto X quad. Hobby shop folk checked mine out and attempted to fly it and finally determined that the stabilization system was not working, gave me a replacement Proto X quad that is more stable and controllable.
Something I didn't know being new to quads: The black props on the rear and gray props on the front have to have opposite pitch. Look at a new quad as it comes out of the box. When replacing a broken or missing prop, be sure that replacement has pitch opposite to the other one. Black props to the rear and grays to the front. Props are marked A or B (hard to see) and should be installed per the drawing in the instruction sheet.
BTW, I'm still stuggling with my replacement Proto X , have not been able to trim it for steady hover so far, getting lots of exercise moving furniture to retrieve it. The Hubsan X-4 or other compatible transmitter would probably make it easier to control.
E-Challenged is online now Find More Posts by E-Challenged
Old Dec 02, 2013, 05:28 PM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
Replacement batt LINK?? Please? Thanks!
Old Dec 02, 2013, 05:36 PM
jgestner is offline
Joined Jun 2011
Use thread search or check Hobbytown USA for Ares Chronos CX 75 battery part# AZSH1156
John
Old Dec 02, 2013, 08:59 PM
BilleFly is offline
Find More Posts by BilleFly
Joined Dec 2010
COOL TOY !
Got mine on Sunday ; can't charge it Fast enough ; Best $29.99
i ever spent and I'll be doing that battery Mod soon !!!
I figure that if i take some 12K carbon tow with saturated epoxy
i can wrap this thing just like the circuit board does around
the motors. That board is Heavy, the 12K ain't. I could add 25%
to the diameter, and still loose 0.25g over-all ; i'd twist the carbon
to get rid of epoxy, and tighten the fibers together.
http://www.acpsales.com/OnlineStore.php?cat=4958
Another option is to braid three tows of 3K together ; the braid
would be stronger than the 12K twisted, so Ya need Less of it ---
it's a Better fiber arrangement
Did Ya know that carbon is a conductor ; or place your wire inside
the braid and isolate it from the circuit board . Speaking of braided carbon sleeves ; this place has a 1/4" sleeve of carbon, that will pull down to 0.09" diameter when stretched.
http://solarcomposites.com/composite...20sleeves.html
Bille
BilleFly is offline Find More Posts by BilleFly
Old Dec 02, 2013, 09:08 PM
Kev71H is offline
Kev71H's Avatar
Joined Apr 2002
Where to buy from at $29.00???
Old Dec 02, 2013, 09:52 PM
groan is offline
Find More Posts by groan
dead sexy
groan's Avatar
Canada, ON, Ottawa
Joined Nov 2006
I was just wondering the same thing!
groan is offline Find More Posts by groan
Old Dec 02, 2013, 10:13 PM
Cyberdactyl is online now
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
I fly mostly medium sized .homemade. .stuff, and the Proto-X blows my mind! Add to that, it flies pretty decent.
However, I would really like to try a hubsan controller, as my mini doesn't engage the yaw until the stick is thrown past ~50% of TDC on the left and around 40% on the right.
Cyberdactyl is online now Find More Posts by Cyberdactyl
Old Dec 03, 2013, 01:10 AM
kymoonshine is offline
Find More Posts by kymoonshine
Drag and Destroy
kymoonshine's Avatar
United States, KY, Stanford
Joined Nov 2006
still looking for replacement motor...mine sits on the work bench
kymoonshine is offline Find More Posts by kymoonshine
New Product Estes Proto Q Nano Quadcopter RTF .. looks like everyone is going with the hubsan X4! tc3wins Mini Multirotors 4 Jan 01, 2014 11:05 AM
Discussion ESTES Dart Quadcopter RTF $49.99 @ sellout.woot.com Mujiber Hot Online Deals 4 Apr 27, 2013 11:10 PM
Sold Protos 500 Carbon, RTF, Very Clean! ljsoarinson Aircraft - Electric - Helis (FS/W) 0 Mar 16, 2013 12:02 AM
Sold *BRAND NEW* Mini Protos mCP X Canopies ShaneXman Aircraft - Electric - Helis (FS/W) 2 Feb 12, 2013 11:32 AM
Sold Protos (500 Class) RTf trade for a 550-600 class heli RTF or 30 to 50 Nitro RTF davidg51537 Aircraft - Electric - Helis (FS/W) 2 Aug 12, 2009 06:43 AM
