Old Nov 03, 2013, 08:05 AM
scousethief is offline
Find More Posts by scousethief
scousethief's Avatar
United Kingdom, England, Redcar
Joined Jan 2006
I'll wait until Banggood stock them, postage from the U.S is a ripoff
scousethief is offline Find More Posts by scousethief
Old Nov 03, 2013, 08:42 AM
crashdumby is offline
Find More Posts by crashdumby
TREE TOP PILOT
crashdumby's Avatar
United States, IN, Greenfield
Joined Feb 2007
Originally Posted by jesolins View Post
Hi C,
It will bind, but for $40 you would be able to get the Tx and X4 both at other stores like $33 @ Banggood, or $36 @ TMart.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Hi jim long time no talk.lol I seen that thanks for the info.....cd
crashdumby is offline Find More Posts by crashdumby
Old Nov 03, 2013, 08:55 AM
mjru is offline
Find More Posts by mjru
United States, NY, Saratoga
Joined Apr 2013
One of the pins in the quad-end of the usb cable has disappeared into the housing and I cant charge it now. Debating if I want to try the warranty or just break the plug open and fix it myself.
Be careful with the plug, it's not nearly as durable as the quad!
Edit: debate is over... plug is mangled, quad is charging. Couldn't resist
mjru is offline Find More Posts by mjru
Old Nov 03, 2013, 12:01 PM
theimacman is offline
Find More Posts by theimacman
Flyin' Ryan
theimacman's Avatar
United States, IL, Champaign
Joined May 2012
Originally Posted by Buckaroo Banzai View Post
It does make me wonder though what the binding process would be with the X4 TX and also if the tiny TX with this would bind with the X4?
The binding process is simple... just turn on the Proto X, then turn on the Tx. They link up almost immediately.
And, yep, you can fly the X4 with the tiny Proto X Tx.
Originally Posted by crashdumby View Post
Yes, but as already said, that is way too expensive... you could get an entire X4 and Tx, or just the Tx, for much less:
http://www.banggood.com/Hubsan-X4-H1...6-p-89080.html
Originally Posted by palomo View Post
Finally, out of curiosity - I wanted to see if proto x would bind with my X4 TX and amazingly it; BEEPED at the bind cycle and was able to fly it more comfortably...
So there you go folks, try it!!
Welcome to the thread... we've been talking about that for several pages now.
theimacman is offline Find More Posts by theimacman
Old Nov 03, 2013, 12:26 PM
Uncle Gravity is offline
Find More Posts by Uncle Gravity
Chasin' Auntie Gravity's Tail
Uncle Gravity's Avatar
Joined Nov 2007
It is very twitchy.
But it's so cool anyway!!
As others have mentioned, extending the "sticks" on the stock TX tones down the twitchiness quite a bit. I use the X4 TX most of the time, but the little guy is a handy pocket TX on the go.
The stock thingies are press fit so they pop right off. I used the top half of some spare Futaba/Spektrum 3M x 0.5 thread alloy sticks. With a little care, you can "tap" the stock sticks with the alloy extensions, allowing the latter to screw on and off.
Uncle Gravity is offline Find More Posts by Uncle Gravity
Old Nov 03, 2013, 02:55 PM
groan is offline
Find More Posts by groan
dead sexy
groan's Avatar
Canada, ON, Ottawa
Joined Nov 2006
Picked up mine today at greathobbies.com atht e local hobby shop.
This thing is so amazingly tiny. One of the employees was playing with it when I got in the store.
Here are a few shots. I have yet to fly it.
Here is my mod for the sticks.
groan is offline Find More Posts by groan
Old Nov 03, 2013, 03:09 PM
FieldofDreamsFlyer is offline
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
You can get a transmitter here in the us
http://www.ebay.com/itm/190879960146...84.m1423.l2649
FieldofDreamsFlyer is offline Find More Posts by FieldofDreamsFlyer
Old Nov 03, 2013, 03:36 PM
3vw is offline
3vw
Find More Posts by 3vw
3vw
3vw's Avatar
Joined Jun 2004
Hi guys,
I thought I'd share what I do to power my Proto X.
Thankfully, Estes included a socket to plug the battery in, instead of just doing a direct solder of the battery leads to the board, hey
I've been flying with all these different size batteries from the stocker (100mah) to a 120mah to 160mah to even the big 200mah onboard for almost a week now. Since I can easily externally charge the batteries (with my Blade Nano Celectra chargers), I always can have a battery ready to fly... couldn't stand that fly for 5 mins and then wait for a charge 25 mins to fly again
I also recommend (like others have) using the X4 TX because it just flys/controls sooo much better.
Check out the vid I made of flying @ the Mall...
IMG 2883 (1 min 4 sec)
3vw is offline Find More Posts by 3vw
Old Nov 03, 2013, 06:00 PM
Ssayer is online now
Find More Posts by Ssayer
Oldie, not Moldie
Ssayer's Avatar
United States, MI, Leonard
Joined Feb 2012
Good use for the "antenna" from my Hubsan X4
Description: Good use for the X4's antenna  ;)
Ssayer is online now Find More Posts by Ssayer
Old Nov 03, 2013, 06:25 PM
danunax is offline
Find More Posts by danunax
Joined Sep 2013
Originally Posted by 3vw View Post
you could go through the escalator and exit from the top storey. pity what not one flip
what kind of battery is there on board?
danunax is offline Find More Posts by danunax
Old Nov 03, 2013, 06:36 PM
pfriedel is offline
Find More Posts by pfriedel
pfriedel's Avatar
United States, WI, Wauwatosa
Joined Mar 2002
So because I hadn't seen it written down, if anyone comes to this thread wondering about forcing the gyro calibration, this is the process:
Bind your transmitter to the protoX as usual. Then give it full right rudder at zero throttle. Waggle the aileron left and right and keep repeating until the blue eyes blink.
Setting it up on my Devo was painless. I copied my v911 config, changed the radio to Hubsan4 and bound it. Aside from some "quirkiness" in my v911 config where all of the channels were reversed in the mixer and not in the input selection (so far as I can tell, none of them are reversed on the protoX), it bound up and flies perfectly, although it wants more trim than I'd expect. Now I need a straightforward non-fiddling flight to see when the LVC starts to complain - I swear the lights start blinking after 2 minutes.
(Edited: Lights start to blink at 3:20, but it has tons of grunt until my 4 minute standard "micro" timer goes off on my transmitter. Hrm....)
pfriedel is offline Find More Posts by pfriedel
Old Nov 03, 2013, 06:43 PM
emsvitil is offline
Find More Posts by emsvitil
United States, CA, Hawthorne
Joined Oct 2013
Transmitter.........
For those that have the stock transmitter and the X4 transmitter.
A lot of times the circuit boards for lower level electronics are the same as the higher level boards. They just don't have all the components on them............
Can the stock transmitter be made into a X4 equivalent transmitter by just adding a few components?
Looks like there's a place for yaw trim on the outside of the stock transmitter. Can you just add momentary contact buttons to the circuit board?
And maybe other features that the X4 transmitter has might be able to be added too.......
emsvitil is offline Find More Posts by emsvitil
Old Nov 03, 2013, 06:52 PM
pfriedel is offline
pfriedel's Avatar
Joined Mar 2002
http://youtu.be/RtW3IApLCmE
Say, I know that mall!
Old Nov 03, 2013, 07:30 PM
3vw is offline
3vw
3vw
3vw's Avatar
Joined Jun 2004
I was probably using the Venom 120mah in the vid. It's a good compromise for weight vs. power.
Living where you do, I'll bet you've been there.
Old Nov 03, 2013, 07:58 PM
HeliStorm (FPV America) is offline
Find More Posts by HeliStorm (FPV America)
Working to make things happen!
HeliStorm (FPV America)'s Avatar
United States, OH
Joined Mar 2013
Hi guys,
The guard didn't seem to care, so I guess you work there, or are known there. I used to work security at a university, and we would have shut something like you were doing down. Not that I wouldn't have asked the guy where he got it after I did, but...
HeliStorm (FPV America) is offline Find More Posts by HeliStorm (FPV America)
New Product Estes Proto Q Nano Quadcopter RTF .. looks like everyone is going with the hubsan X4! tc3wins Mini Multirotors 4 Jan 01, 2014 11:05 AM
Discussion ESTES Dart Quadcopter RTF $49.99 @ sellout.woot.com Mujiber Hot Online Deals 4 Apr 27, 2013 11:10 PM
Sold Protos 500 Carbon, RTF, Very Clean! ljsoarinson Aircraft - Electric - Helis (FS/W) 0 Mar 16, 2013 12:02 AM
Sold *BRAND NEW* Mini Protos mCP X Canopies ShaneXman Aircraft - Electric - Helis (FS/W) 2 Feb 12, 2013 11:32 AM
Sold Protos (500 Class) RTf trade for a 550-600 class heli RTF or 30 to 50 Nitro RTF davidg51537 Aircraft - Electric - Helis (FS/W) 2 Aug 12, 2009 06:43 AM
