Old Feb 21, 2004, 05:48 PM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Will my first scratch built electric Fly.
I am building my first scratch built electric. It is a high wing decathlon type aircraft made from blucor fan fold. Since I am just starting in electrics I need some opinions on what to expect from the following setup.
Span 43"
Cord 6.8"
undercamber wing with 2.5 inch dihedral.
GWS EPS 300C 4.3 to 1 gearbox
GWS 9X4.7 slow flier prop.
7 Cell Kan 1050 battey pack.
GWS IPS300 speed controller.
Fixed gear tail dragger.
Rudder and Elevator control
Futaba PCM 512 5 channel receiver (its old but small)
2 Bluebird BMS-371 servos
Motor calc sais that this setup will fly very sedately but I have my doubts because of the estimated 9 oz/sqft wing loading.
I would like some opinions please.
BGR is offline Find More Posts by BGR
Old Feb 21, 2004, 08:44 PM
phonics-monkey is offline
Find More Posts by phonics-monkey
phonics-monkey's Avatar
Joined Sep 2003
Cool plane!
phonics-monkey is offline Find More Posts by phonics-monkey
Old Feb 21, 2004, 11:55 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Try a bigger prop (10x4.7? or 10x6 HD) in Motocalc - I think that might be better, unless the amp draw is too high.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 22, 2004, 01:10 AM
BGR is offline
BGR
BGR
Foam Junkie
Joined Dec 2003
Thanks Phil, yea I was looking at a bigger prop but it puts the amps at max for the ESC. However I tried a 9x6 and motor calc liked it even better than the 9x4.7.
Only issue with a 9x6 is that I cant find one with the right size hole, will need to use an adapter.
Old Feb 22, 2004, 06:22 AM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
1st thing if you haven't done it yet is to spar up the wing. Make sure its rigid or it will buckle in the air due to the weight.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Feb 22, 2004, 07:03 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
I hate those elongate threaded shafts - collet type adapters on Dremel-shortened shafts are so much better and more versatile!
Cheers, Phil
Yippee! My first scratch-built! The 'Tiny'!!! Hogster Electric Plane Talk 28 Sep 07, 2004 12:17 AM
My first scratch built indoor flyer (photos) Turbo442 Scratchbuilt Indoor and Micro Models 19 Jun 03, 2004 10:06 PM
Starting my first scratch built, need some help... Trikster Foamies (Kits) 7 Mar 11, 2004 12:08 AM
Yippee! check out my first scratch built... torcgolf Slope 9 Dec 08, 2003 07:22 PM
My First Scratch Built Plane - Thanks Hoppy Andycart Foamies (Kits) 12 Nov 12, 2002 02:22 AM
