Old Jan 10, 2004, 06:51 PM
Joined Sep 2002
TA-183 Huckebein Building thread
Well guys here we go.
After blowing off the gear bays I decided to start building. This will be blow by blow.
First cut the intake openning. Use a dremel tool.
U812 is offline Find More Posts by U812
Old Jan 10, 2004, 06:53 PM
Joined Sep 2002
Next cut the doors open. Use masking tape to mark the edge. Then use an exacto to start a small openning large enough to get the tip of a razor saw in and start cutting.
Goes very easy with the rasor. A great tip I got from Gregg.
Old Jan 10, 2004, 06:54 PM
Joined Sep 2002
razor saw
Old Jan 10, 2004, 06:55 PM
Joined Sep 2002
After you get them cut out mark them left and right, up down and forward.
Old Jan 10, 2004, 06:57 PM
Joined Sep 2002
I taped them back in place and found that they close perfectly. I think a fabrick hinge may be the way to go. We'll see but they swing open and closed very easy and line up great!
Old Jan 10, 2004, 09:31 PM
Joined Sep 2002
Now to cut the nose wheel doors out.
You'll notice as luck would have it that the gear door looks off.
Not so, it's the seam.
The plug moved durring the lay up process and I didn't catch it.
Do not go by the mold seam. The doors are straight. Another reason I'm looking for professional mold making.
I decided to cut the door out in one piece. I can later cut the door into two doors although I've noticed that drawings from the period show it with a single door and two. It's up to you. I personally think the single door will be less trouble.
Old Jan 10, 2004, 09:32 PM
Joined Sep 2002
Use the same system to cut it as the mains. All this went very fast and easy.
Old Jan 10, 2004, 09:33 PM
Joined Sep 2002
The next thing to do using the canopy as a gide is to cut away the cockpit area. This is where you'll slide in the batteries.
Old Jan 10, 2004, 09:34 PM
Joined Sep 2002
When your all done you'll have something thing that looks like this.
Old Jan 10, 2004, 09:36 PM
Joined Sep 2002
Next will be to place the formers in the fuse and the rails between them for mounting the gear.
More to come.
Steve
Old Jan 10, 2004, 10:35 PM
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
Your gonna beat me into the air with this one Steve!
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jan 10, 2004, 11:24 PM
Joined Sep 2002
Maybe not. I have a mess of Messerschmitts to make next week.
Well here's the solution to the bays. This will allow lots more room to work too.
What I'm doing here is modifying F1 with the rail mount holes. The white foam (thanks Bruce) is that new former F2a. From this former there will be another set of rails for the mains. Ran out of would so I can't show it tonight.
Needless to say all this gives back the strength that was lost from cutting the main doors open.
On the first 16 kits going out there will be templates to modify F1 and to make F2a. Piece of cake really.
Steve
Joined Sep 2002
Close look at the nose retract. The rails are not trimed which is why there's all the excess.
Old Jan 11, 2004, 12:12 AM
Joined Sep 2002
Ok this is going to work very well. I think backing up the rails with a CF tape might be a good idea at these lengths.
If your uncomfortable with the stance there's enough room to angle the mounts more. But this is the scale location, which Barry says is very stable.
Here are some pics of the set up for the mains. Tomorrow I'll get some more ply and cut the new former and assemble all this stuff.
Steve
Old Jan 11, 2004, 12:14 AM
Joined Sep 2002
In the above shot the fuse is upside down. The gear is just laying in place. When screwed to the rails it will not rub against the fuse as it appears.
Here's a shot looking in through the back of the fuse.
Steve
New HL Ta-183 Huckebein PunkerTFC Foamy EDFs 563 Aug 26, 2008 02:38 PM
TA-183 Huckebein for 90 mm U812 Electric Ducted Fan Jet Talk 884 Dec 12, 2006 11:10 AM
FS: RBC TA-183 HUCKEBEIN Kit jcstalls Aircraft - Electric - Airplanes (FS/W) 0 May 22, 2003 08:16 PM
Focke Wulf Ta-183 Huckebein marshall Aircraft - Electric - Airplanes (FS/W) 2 Mar 28, 2003 02:18 AM
RBC Kits TA 183 Huckebein Tempest Electric Ducted Fan Jet Talk 1 Feb 15, 2003 06:56 PM
