Old Nov 11, 2013, 02:18 PM
vartaz is offline
Find More Posts by vartaz
Denmark, Central Denmark Region, Karup
Joined Aug 2012
Im just about to pull the trigger love that camera and flight time. Is there any way to mod it to be a hardcore FPV machine , 2km range?? more power to video and radio TX or better antennas? is it possible. DJI must know we want longer range for this amazing craft
vartaz is offline Find More Posts by vartaz
Old Nov 11, 2013, 02:57 PM
Steph280 is online now
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
You are probably better off getting a Phantom 1 and add your own video transmission system. The Vision will not give you 2km range both video and RC, and you will not be able to use any goggles or LCD screens other than an iOS/Android tablet.
Steph280 is online now Find More Posts by Steph280
Old Nov 11, 2013, 03:34 PM
HGT is offline
HGT
Find More Posts by HGT
HGT
United States, CO, Parker
Joined Jan 2013
Originally Posted by Studiowise View Post
would i be thrown out of the 'community' if i swapped my LED's - so green to red and red to green? it just always feels like im 'driving' in reverse with my tail-lights coming at me!
Or you can but the red and green on the correct sides. Both are possible.
HGT is offline Find More Posts by HGT
HGT is offline
HGT
HGT
Joined Jan 2013
Originally Posted by studiowise View Post
i have no doubt it's effective but it ain't gonna win any beauty awards is it
+1....
Old Nov 11, 2013, 03:39 PM
kiwirider is offline
Find More Posts by kiwirider
kiwirider's Avatar
United Kingdom, Liverpool
Joined Nov 2013
Originally Posted by RemE View Post
Your application is a perfect use model for a Vision! The still photos are the Vision's best attribute.
When DJI comes out with the 46MM Lens Filter Adapter kit, you could research IR pass filters. I haven't checked the Vision but most all solid state cameras can see outside our visible light spectrum. Take a IR TV remote and point it at the Vision's camera, you should be able to see it blink. I bet you can find a 46mm lens filter that will block most of the visible light and enhance the IR content, just guessing right now.
Please share what you find! Very interesting.
You'll probably have to remove the IR blocking filter (sometimes known as the low-pass filter) otherwise they will be fighting with each other with a consequence that the exposure times will be very long. You are quite right though in that silicon is sensitive to very near IR - up to about 1200 nm.
If you remove the blocking filter and replace it with a 750nm IR pass filter, you will get some very interesting images!
Once I get my some practice in with the Vision (my first RC), I'll be tempted to try this myself
kiwirider is offline Find More Posts by kiwirider
Old Nov 11, 2013, 03:56 PM
kiwirider's Avatar
Joined Nov 2013
Originally Posted by Lame Bucket View Post
This will allow NIR and most of the visible red light (red actually starts around 620nm), however this will block all green and blue light into the sensor. You would be able to make a NDVI (using the red) however you will not be able to make a full false colored image. But since this will be a screw on kit and you will be able to swap between traditional filter and this filter than you will be able to overlay the NDVI the traditional photo for some really good quality images. This would probably work great! You will probably have to increase the exposure or shutter speed (I honestly don't know much about cameras) due to the amount of blocked light.
I don't know anything about NDVI I have done quite a lot of work with IR and CMOS sensors though. The filter quoted would be a good starter - it is good quality Schott glass. I think I would want to be going a bit higher though - say 720nm ....
Do you need visible red for NDVI?
Old Nov 11, 2013, 04:13 PM
Studiowise is offline
Find More Posts by Studiowise
UK Photog
Studiowise's Avatar
United Kingdom, England, Bristol
Joined Nov 2013
sorry HGT, that one passed me by. can you elaborate as i think the 'correct' bit confuzzed me
Studiowise is offline Find More Posts by Studiowise
Old Nov 11, 2013, 04:37 PM
Lame Bucket is offline
Find More Posts by Lame Bucket
Joined Nov 2013
We have a wide verity of expertise in this group! Whatever you can tell us about this sensor may be helpful to those who don't know a lot about cameras (aka - me). As far as NDVI, you do need a visible band as a basis of comparison. NDVI compares whats being reflected to whats being absorbed, which can tell us a lot about the health of the plant. If its not absorbing or reflecting as it should be, this can mean that the plant is either sick or damaged. Most often NIR and VIS-R are compared.
If you are going to go with a strictly IR filter for vegetation analysis I wouldn't go any higher than what kiwirider said (720nm). I have found it often better to go with a filter that captures as much of the NIR as possible to help identify the plants absorption signature. Every plant reacts slightly different to VIS and NIR radiation, some absorb more and some less. Some more in the 800nm area some more in the 950nm. So much so that it creates a kind of "fingerprint" for each plant type. So if you were interested in doing something like this and you purchased a 950nm filter, you would cutting out a large amount of the data available to you. This of course is bound by the limitations of the equipment and software.
That is just my findings though! If you find otherwise please feel free to say so, an open discussion on the topic is always helpful to all
-LB
EDIT:
Ok so rereading the filter it says that it BLOCKS everything till 650 (VIS-R is 620–750nm) and it allows 90% of light from 730 - 2000nm. So what does it do with the light from 650 - 730nm? Ideally if you are doing NDVI's you'd want to take the image without a filter to capture as much of the NIR and VIS as possible. However if you were just doing NIR imaging and didnt want to do NDVI's I think either of those filters would work fine.
Lame Bucket is offline Find More Posts by Lame Bucket
Old Nov 11, 2013, 04:41 PM
Parapente is offline
Find More Posts by Parapente
Joined Nov 2013
Planes use red and green but on their sides. I dont know which side is red and which side or green but I suspect that's what HGT meant. Port side and etc.
Parapente is offline Find More Posts by Parapente
Old Nov 11, 2013, 04:52 PM
HGT is offline
HGT
HGT
Joined Jan 2013
A typo may be confusing you. Put red on port, green on starboard.
If you swap these 2 ESC's you will be official and prop rotation will be the same
Old Nov 11, 2013, 04:58 PM
gathan is offline
Find More Posts by gathan
Joined Nov 2013
I upgraded the software on the quad itself no problem, using the manual as a guide, but how do you upgrade the remote controller? The manual says to connect a usb cable to it, or if there isn't any; remove the back cover????
gathan is offline Find More Posts by gathan
Old Nov 11, 2013, 05:03 PM
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Yes open it up. USB plug is on top of the circuit board (to the left of the 3 plugs).
http://www.rcgroups.com/forums/showp...&postcount=985
Old Nov 11, 2013, 05:12 PM
UK Photog
Studiowise's Avatar
Joined Nov 2013
ah i get you, now, i did use to do a bit of sailing but port & starboard wasn't where i was going with this as i used to have near misses under wind power when heading towards something in the fog that was also only showing running lights!
i was thinking adding high beam WHITE LED 'headlights' for front and swop the red to the rear for tail-lights? ive not (yet ) opened up the PV2 but it shouldn' t be a massive job and at least then the warning / info sequences would remain the same.
Old Nov 11, 2013, 05:29 PM
HGT is offline
HGT
HGT
Joined Jan 2013
Wrong thread...
Old Nov 11, 2013, 05:36 PM
HGT is offline
HGT
HGT
Joined Jan 2013
My bad... I thought I was in the Phantom thread.
Discussion DJI Flame Wheel F450 and F550 *******OWNERS******* Thread. DWA Multirotor Talk 47543 Today 03:48 PM
Discussion DJI F330 Flame Wheel Owners Thread MicroFantastik Multirotor Talk 1369 Mar 21, 2016 12:25 AM
New Product DJI Phantom VISION eirlink Multirotor Talk 819 May 07, 2015 04:25 PM
New Product All New DJI Phantom Vision? Doodie Multirotor Talk 13 Oct 12, 2013 02:44 PM
Question DJI Phantom Vision, When & How much? BenHayat Multirotor Talk 5 Oct 12, 2013 02:43 PM
