HobbyKing Cellmeter-7 Battery Checker and Turnigy Servo Centering Tool
Two very helpful and affordable devices.
Keep tabs on your Lithium battery packs and precisely install servos with these two products from HobbyKing.
HOBBYKING CELLMETER-7 — LiPo/LiFe/Li-ion/NiMH/ NiCd Digital Battery Checker with Balance Function
The new HobbyKing Cellmeter-7 with built-in balance function really is the must-have tool for the RC Hobbyist. Not only is it capable of instantly checking the overall and individual cell voltage of Lipo/Life & Li-ion batteries (with balance plugs fitted) it can also give you an instant reading of the remaining capacity of the battery at the same time, so no guess work! The cell button allows you to balance your packs, the mode button also allows you to check highest and lowest individual cells and voltage differences between individual cells Finally, as well as the Lithium battery port, there is an additional receiver style 3-pin port for checking overall voltage on NiMH/NiCd Rx batteries.
The HobbyKing Cellmeter-7 is a simple, fast and brilliant way to check battery voltage, balance your packs and most importantly, help you determine the condition of your packs within seconds.
FEATURES
  • Easy to read LCD screen
  • Easy to use Menu
  • Full instructions included
  • Total voltage, cell voltage and remaining capacity readings for all Lithium type batteries
  • NiCcd/NiMH Rx Voltage Checker
  • Mode allows you to display highest & lowest cells and max voltage differential between cells
  • Instant Battery capacity graph
  • Balance mode
  • 1S~7S Lithium type cells
SPECS
Dimensions 84x50x16mm
Weight40g
Item no.9265000003-0
Price $10.93
TURNIGY Servo Centering Tool
When installing a servo, it is vital that it is centered. This means you have to find a battery, plug in the ESC, pull out and set-up a model on your transmitter, wire it all up, etc. Well those days are over…the Turnigy Servo Centering Tool is a stand-alone unit that has a built in Li-poly battery and can handle up to four 1520us or 760us servos. You simply plug in your servo, press the power button and BAM…your servo goes to its center and is held there, allowing you to install the servo arm in its optimal position and then adjust your linkage to center everything up. The days of 30% Sub trim and uneven travel side to side are over. With its built-in USB rechargeable battery, compact size and servo versatility, there is no excuse to not build it right from the start.
SPECS
Servos compatibility1520us or 760us selectable
Number of servos controlledUp to 4
BatteryInternal 500ma Li-poly
Charging USB (cable included)
Size 60x36x21mm
Item no.9171000276-0 (BLACK) / 9171000276-0 (RED)
Price $11.48
Visit the site for more info—HOBBYKING!
Old Oct 16, 2013, 02:39 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Why not simply use a transmitter and receiver to check center position? If you want to control the model, you need to have these anyways.
SoloProFan is online now Find More Posts by SoloProFan
Old Oct 16, 2013, 03:33 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
The servo centering tool has a built in battery; just plug in servos and center. That's pretty simple in my book.
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Oct 16, 2013, 04:20 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
It is, but you can do the same with the transmitter and receiver you probably already have, or should have, as it will be used to control the model in the end. So you already have a tool to check servo position. If you want to quickly test servos, I can understand the use of a servo checker, but this tool is more limited, as you can only center the servo. And if you first center the servos with this, adjust all control rods to have 90 degree angle between control rod and servo horn, you still run the risk of having the servos in slightly different positions once you do connect your receiver and transmitter because of tolerances in the transmitter's sticks, etc. So you might end up doing the fine tuning to get 90 degree angles between control rods and servo horns again, after the first check.
It feels like calibrating an ESC's throttle range to a servo tester, and then later on having to repeat the process because the neutral position of the actual transmitter's gas stick is slightly off, or has lower or smaller range so you still end up with throttle not being fully tuned to the gas stick's range and neutral position. And having to re-calibrate throttle range of the ESC to actual gas stick again.
Old Oct 16, 2013, 09:11 PM
McKrackin is offline
Find More Posts by McKrackin
Incurable heli addict
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Hmmm...
McKrackin is offline Find More Posts by McKrackin
Old Oct 17, 2013, 08:35 PM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
I saw the servo centering device. Very good price for what you get, albeit with limited functionality (center only).
Not being stocked in the HK USA website does make the delivered unit much more expensive.
my Electrodynamics EDR-203 Servo Exerciser
http://www.electrodynam.com/rc/EDR-203/index.shtml
Has a precision "Center" as well as the ability to drive the servo.
Nice to receive the HK as a gift, but I can't see the value right now.
ltc is offline Find More Posts by ltc
Old Oct 17, 2013, 08:37 PM
ltc is offline
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
Originally Posted by McKrackin View Post
Hmmm...
Same display/functions as the Futaba BR-3000 as well.
Old Oct 17, 2013, 10:26 PM
beamcat is offline
Find More Posts by beamcat
Joined Sep 2013
Hum.... it is a good idea but..... I had notice using different transmitter the center points is slightly different. Even setting all trim to 0.........
beamcat is offline Find More Posts by beamcat
Old Oct 18, 2013, 01:13 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Indeed. I see more value in an exersizer, I think a centering tool is too limited.
So you end up fine tuning control rods... again.
Old Oct 21, 2013, 02:10 AM
beamcat is offline
Joined Sep 2013
yes, so just connect it directly to the radio and doing it once. not twice.
Cool RC CellMeter-7 Digital Battery Capacity Checker LiPo LiFe Li-ion NiMH Nicd szewang2805 Hot Online Deals 4 Oct 03, 2013 01:04 AM
Sold H-King Cellmeter-7 Lipo/Life/Li-ion/Nimh/Nicd Digital Battery Checker Mikey 68 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jun 28, 2013 01:42 PM
Sold H-King Cellmeter-6 Lipo/Life/Li-ion Cell Checker & Alarm major.monogram Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 29, 2013 08:19 AM
Sold Turnigy 7 in 1 NIB -Battery Checker/Watt Meter/Servo Test/Tach/Temp & IR -shipped USA LowWatts Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jul 21, 2012 10:13 PM
New Product Funky Cellmeter battery checker Spadkun Batteries and Chargers 0 Apr 24, 2007 09:01 AM
