Old Oct 10, 2013, 02:58 PM
Higgins909 is offline
Find More Posts by Higgins909
Joined Aug 2013
Question
how to bend balsa sheet over wing?
I'm getting close to being done with my wing, and need to know how to bend 1/16 balsa sheet over the middle of my wing (where the rubber bands will sit)
and the LE.
Higgins909
Higgins909 is offline Find More Posts by Higgins909
Old Oct 10, 2013, 04:16 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
So long as it's not very hard wood and provided you have the grain running the right way (parallel to the LE) 1/16th balsa will easily bend over any airfoil I've seen.
Steve
slipstick is online now Find More Posts by slipstick
Old Oct 10, 2013, 07:03 PM
Curare is online now
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Yep, if you grab a sheet of 1/16 and bend it you'll notice it bends nicely across the grain. This is good as you want the fibres of your sheeting to go spanwise for strength.
Just stick it down span wise , and all will be well!
Curare is online now Find More Posts by Curare
Old Oct 10, 2013, 08:30 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I've only seen a few designs that expect you to bend it around the leading edge. So I'd suggest you avoid trying it.
The others covered the spanwise orientation of the grain and how easily it will flex around the airfoil shape for the whole chord other than the leading edge.
BMatthews is offline Find More Posts by BMatthews
Old Oct 10, 2013, 08:37 PM
Captain Dunsel is offline
Find More Posts by Captain Dunsel
United States, NJ, Southampton Township
Joined May 2005
To make thin balsa curve more easily with the grain, moisten the "outside" with water. That'll expand the grain on that side and cause the wood to bend. I do this all the time with LE sheeting. When it dries, it'll stay 'bent'.
If you aren't sure, dampen a bit of scrap and watch how it bends, i.e., if the grain is running "up and down", then the wood will flex "left to right". How much and how consistent the bending will depend on the wood grain, hardness, and amount of wetting.
CD
Captain Dunsel is offline Find More Posts by Captain Dunsel
Old Oct 10, 2013, 09:31 PM
Joined Aug 2013
cool, so that means I'll have to cut my sheet into a few pieces? I got something like 3" x 1/16" x 36" and my wing is like 6" umm long?
(I need to figure out the proper way for this, does it go width then thickness then length?)
Pretty much what I'm asking is that there is no issue with me covering it with 2 pieces? Instead of one? I doubt it, but just wanna make sure, not sure how well taking it apart would go if I had to XD
Thanks again,
Higgins909
Old Oct 10, 2013, 11:13 PM
KE your cub.
Curare's Avatar
Joined Jun 2005
I take it the 6" measurement is front to back? THat's known as the wing's chord. The measurement from wing tip to wing tip is the span.
If you have a 6" chord then yeah, use the wood spanwise, and you'll have a join in the middle running with the grain.
If you have a wing with dihedral (the wings are angled upwards) it's easier to sheet each half, sand the mating surfaces and then join the wing.
As they say, a picture is worth a thousand words
Hope this helps!
Old Oct 13, 2013, 07:32 PM
burntstringflier is offline
Find More Posts by burntstringflier
United States, WA, Bonney Lake
Joined Jun 2005
Bending Balsa
I use household ammonia when I want to form balsa to a curve. Apply it with a paintbrush and let it soak in for a minute or so (longer time for thicker wood or sharper bends), then form the balsa over the surface and secure it with rubber bands or an ace bandage, or wrap it with tape keeping the sticky side out. The ammonia temporarily dissolves the lignin in the wood, so it works much better than plain water, and it also dries very much faster than water. I have used this technique to wrap 1/16" thick "A" grain balsa completely around a 3/8" dowel to make a tube. You won't believe it until you try it.
burntstringflier is offline Find More Posts by burntstringflier
Old Oct 15, 2013, 05:00 PM
jim495 is offline
Find More Posts by jim495
Lexington, MA
Joined Feb 2009
Absolutely! I thin the ammonia with a small amount of water, and as said, brush it on, and secure the balsa in place until dry. Store the ammonia water solution in a small jar, and it will always be ready when you need it. Works amazingly well.
jim495 is offline Find More Posts by jim495
Old Oct 16, 2013, 02:26 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
I use denatured alcohol to quickly add a pre-stressed curve to balsa. The alky works just as well as water-based solutions, but it will not damage the wood, weaken it, and dries (and sets) very quickly, with no residual moisture in the wood. Also enables me to progressively increase the curve in the wood quickly, including a tight enoug radius to sheet around a leading edge. The alky "soaks" into the balsa a lit faster because it is thinner and flows better into the fibers.
TTRotary is offline Find More Posts by TTRotary
Old Oct 16, 2013, 04:02 PM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Lots of good ideas! Here's how I did it when I was rebuilding the wing on my Hobbistar 60.
I started by soaking the wood for several days wrapped in an old towel. Several days was probably overkill but I wanted it to be W-E-T.
Drew a centre line down the length and pinned it in place along the leading edge
Placed magazines over the edge to help hold the curve.
A bend was formed.
Each face was glued and held down by magazines.
The results were good.
grosbeak is offline Find More Posts by grosbeak
Help! Need tips on how to bend two 3/8 alluminum wing rods to be exactly 8 deg hog2soar Sailplane Talk 5 Oct 09, 2014 10:47 AM
Question How to fiberglass over sheet balsa? flying jeep The Builders Workshop 21 Apr 15, 2014 02:32 AM
Discussion Liquid Sheeting over Foam Wing Cores??!!!?? chilipecker Giant Scale Airplanes 12 May 12, 2013 02:08 PM
Discussion Balsa Sheeting Foam Core Wings 1stfoot The Builders Workshop 12 Mar 29, 2013 12:38 PM
Question Balsa Wing Sheeting SpadCat2000 Balsa Builders 6 Mar 19, 2013 02:27 PM
