Mini OSD System w/GPS Module
HobbyKing's Mini OSD System w/GPS Module is a light weight no-nonsense OSD that provides a number of vital in-flight stats.
Inexpensive, light weight, and effective.
The Mini OSD System with GPS module from Hobbyking.com is the ideal on-screen-display for those wanting to keep weight way down while displaying vital info such as RSSI, pack voltage, speed, altitude, and GPS coordinates.
Taken from hobbyking's website: This is a Mini OSD System specially designed for use with small electric powered models. Its light weight and compact design makes it ideal for use on micro planes or any other model where saving weight is crucial.
This GPS OSD system enables you to view vital data real-time while flying your FPV model. Things such as battery voltage, flight time, ground speed and GPS coordinates are all within view while using this system. This is a must have for you FPV model!
Features:
  • GPS Coordinate Display
  • Time Display
  • Ground Speed Display
  • Voltmeter
  • Stopwatch
  • RSSI Receiver Signal Strength Detection
  • Programmable Display Content
  • Supports NTSC and PAL TV Signal
  • Supports Anti-Glare Shade Control Signal
  • Supports Manual Calibration
Specs.
  • Weight: Main Board - 4.6g / GPS Module - 25g
  • Dimensions: Main Board - 34x4x20mm / GPS Module - 45x10x42mm
  • Working Voltage: Main Board - 7.4~12V / GPS Module - 5V
Link to product
Old Oct 10, 2013, 12:08 PM
Oso Grande is offline
Find More Posts by Oso Grande
Need more props..........
Oso Grande's Avatar
United States, TX, Houston
Joined Jan 2013
I found mine to consistently show GPS coordinates that were 40 miles away from where I actually was. That said I wish they would offer just the osd without the GPS puck as it takes up less space than my other simple osd's since all the pins are on one side.
Oso Grande is offline Find More Posts by Oso Grande
Old Oct 10, 2013, 01:03 PM
quadcopter007fpv is offline
Find More Posts by quadcopter007fpv
quadcopter007fpv's Avatar
United States, CA, Riverside
Joined Feb 2012
this osd is best used with the cl-osd code , giving a home arrow and better configuration
quadcopter007fpv is offline Find More Posts by quadcopter007fpv
Old Oct 10, 2013, 01:07 PM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
awesome info 007.
Heres a link to it:
http://www.rcgroups.com/forums/showthread.php?t=1490446
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Dec 05, 2013, 09:16 PM
Fidy$Trainer is offline
Find More Posts by Fidy$Trainer
USA, GA, Atlanta
Joined Sep 2008
I'm having issues getting a fix on GPS. Does the GPS require 5v or 12v to operate?
Fidy$Trainer is offline Find More Posts by Fidy$Trainer
Old Dec 06, 2013, 07:48 AM
RCGroups Editor
Matt Gunn's Avatar
Joined Jul 2009
It says in the specs above: GPS 5v
Administrator
Old Dec 06, 2013, 11:04 AM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Does this custom code fix the GPS errors? I have heard from several others that this OSD has horrible GPS, and coordinates are often 40-50 miles away from the actual location.
AcroFPV is online now Find More Posts by AcroFPV
Old Dec 06, 2013, 11:32 AM
hangarspace is offline
Find More Posts by hangarspace
United Kingdom
Joined May 2013
That sounds more like they didn't have a good enough lock.
I've used it with the cl-osd flash, and whilst it is not the most repsonsive OSD out there, it's great for the price. It's saved me a few times when I've been disorientated.
Chris
hangarspace is offline Find More Posts by hangarspace
Old Dec 06, 2013, 11:40 AM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Chris
Next time you are in the field, check the coordinates displayed on the OSD against Google Maps.
Does anybody have any in flight footage of this OSD with the CL-OSD firmware?
Old Dec 13, 2013, 09:19 PM
Joined Feb 2012
DVD_121824_0.mpg (7 min 27 sec)
the code does have the settings to use the google cord's
i think it fixes the gps pos to with in a few miles ,
Old Dec 13, 2013, 10:56 PM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
these GPS ARE 10years old ;(
just for fun I connected one to BaseFlight FC, it worked while set NMEA 4800 baud
$15 EBAY UBLOX is 10 times more sensitive at 1/2 weight
fmkit is online now Find More Posts by fmkit
Old Jan 18, 2014, 03:16 PM
changosurf is offline
Find More Posts by changosurf
Joined Aug 2011
is anyone else having issues with the crappy SIRFSyar II GPS module not wanting to perform a hot/warm start correctly? It takes forever to get a lock. When it finally does, power cycling it causes it to do a cold start and start from scratch trying to get a fix. It doesn't appear that the battery backup is being of any use. It should lock right away after having a fix and then rebooting it, but it ends up taking forever to locate sats. what gives? anyone having this issue?
changosurf is offline Find More Posts by changosurf
Old Jan 18, 2014, 03:48 PM
United Kingdom
Joined May 2013
The batteries are shot before you get them.
Old Jan 18, 2014, 04:00 PM
Joined Aug 2011
ok, that makes sense, so is it just a question of replacing the battery?
Old Mar 10, 2015, 10:19 AM
raptor357 is offline
Find More Posts by raptor357
United States, MI
Joined Jan 2013
My GPS i think is bad it shows up in china all the time and the elevation is wrong and everything. I flashed it with u-osd, any fix for the gps or should i just buy the ublock gps or another kind?
raptor357 is offline Find More Posts by raptor357
Sold HK Mini OSD System w/GPS Module (Brand New) vodaye FPV Equipment (FS/W) 4 Aug 12, 2013 01:43 PM
Found someone to reflash my hobbyking Mini OSD System w/GPS Module mike300z FPV Equipment (FS/W) 1 Jul 21, 2013 05:31 PM
Question HK G-OSD II Mini OSD System w/GPS Modul simplyfly FPV Talk 8 Nov 27, 2012 02:56 AM
Sold Hobbyking G-OSD II Mini OSD System w/GPS Module NIB ross_badger FPV Equipment (FS/W) 1 Jun 29, 2012 07:32 PM
Sold Hobbyking G-OSD II Mini OSD System w/GPS Module NIB ross_badger FPV Equipment (FS/W) 5 Jun 25, 2012 11:40 AM
