Old Feb 19, 2004, 01:18 PM
Jasper2 is offline
Find More Posts by Jasper2
Joined Feb 2004
Hype 3D
Hi,
Since I've canceld the greatplanes extra 1.60 and will go whit fuel.
I'm in need off a daily (electric) 3D plain.
I'm thinking about the Weston hype 3D whit there electric deal:
Flyware 350/25 motor, Hacker 70 Opto controller 2 8.4 pack (3.3A) battery packs fully wired with Magnum connectors and charging connectors.
Any good?
And what batteries?
Just one more what would be the preformens could it hover?
Thanks guy's.
Jasper
Jasper2 is offline Find More Posts by Jasper2
Old Feb 19, 2004, 01:54 PM
t.nollett is offline
Find More Posts by t.nollett
coventry uk
Joined Nov 2002
hi
i have the weston cougar with the flywere motor, using 3300 8 cell packs you will only get 5 min flights these motors pull 60 amps which means its hard to upgrade to li-polys[ i also have the hype with the weston glow motor]. you need a geared set up running 10 cells [so you can move to 3s lipolys] so you can reduce the amps, other than that its a great plane you just need to Strengthen the landing gear as the mounting point is a bit weak.
t.n
ps my cougar would prop hang and pull out easy.
t.nollett is offline Find More Posts by t.nollett
Old May 10, 2004, 07:55 AM
mitchellj is offline
Find More Posts by mitchellj
UK
Joined Oct 2001
I beleive the batteries supplied are 14 of Gold Peak NiMh 3300s
various reviews in the press imply that you will need 16 cells Nicad to hover
mitchellj is offline Find More Posts by mitchellj
Weston Hype 3D Doc Data Sport Planes 16 Aug 15, 2004 08:55 PM
Where to get a Hype 3D?? Modellbau=no answer!! Arthur_GA Sport Planes 1 Feb 16, 2004 04:28 PM
Hype 3D or U-Can_Do ?? Alfster The Profile Brotherhood 20 Oct 07, 2003 02:39 AM
Weston HYPE 3D maiden flight jmannerberg Sport Planes 10 Sep 22, 2002 02:09 AM
