Old Feb 19, 2004, 12:41 PM
dalbert02 is offline
Find More Posts by dalbert02
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
how to mount a PJS300 on an IFO and get your wife mad at the same time!
I decided I wanted an IFO so I came here and did some research and found that the PJS300 was highly recommended for this bird. I got the kit a few days ago and was somewhat perplexed on how to mount the engine. Out of boredom, I decided to raid my wifes little tool box, and guess what I found? A machined aluminum bead reamer! Perfect! All I had to do was make a few cuts:
dalbert02 is offline Find More Posts by dalbert02
Old Feb 19, 2004, 12:42 PM
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
and then do a little drilling:
Old Feb 19, 2004, 12:43 PM
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
and a little tapping:
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
and a little de-burring / chamfering:
Old Feb 19, 2004, 12:44 PM
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
and then just check that the screw fits:
Old Feb 19, 2004, 12:46 PM
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
and finally make some adjustments with Kapton tape. Kapton because I have it and I am cool. No, really, it is just a tad thicker then scotch tape and I like yellow...
Old Feb 19, 2004, 12:47 PM
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
and after all of 30 minutes I am finished with my mount:
Old Feb 19, 2004, 12:49 PM
K4UAV
dalbert02's Avatar
Miami, FL
Joined Jul 2003
For those of you familar with the IFO, the GWS motor is attached using nylon tie wraps. I will use two tie wraps to attach the aluminum mount to the carbon fiber fuse of the Mini IFO. More pics when the plane is done. And maybe pics of my wife when she finds out she no longer has a bead reamer!
Old Feb 19, 2004, 02:18 PM
Steven D is offline
Find More Posts by Steven D
This space for rent
Steven D's Avatar
Peachtree City, Ga USA
Joined Apr 2000
Fuel tubing
Fuel tubing from the local auto parts store works well, and you don't have to sleep in the dog house
Can't recall the size, but its a tight slip fit, no other retention is needed.
Steven
Steven D is offline Find More Posts by Steven D
Help! How to get your wife to fly with you...... Water Boy Electric Plane Talk 63 Dec 22, 2006 09:49 PM
Wes Technik 5-2.4 on an IFO Mini? mthomson Scratchbuilt Indoor and Micro Models 7 Sep 04, 2002 11:02 PM
DO NOT spray windex on an IFO dezflyer Parkflyers 2 Sep 08, 2001 07:21 PM
Just got a Rayovac 9 volt NiMH battery will this work on an IFO?> JStory Electric Plane Talk 7 Aug 06, 2001 06:23 PM
Kyosho Ferias: How to mount a sp380 on a firewall? slowpoke Electric Plane Talk 2 Jul 06, 2001 12:58 AM
