Old Oct 17, 2013, 04:54 PM
BladeScraper is online now
Find More Posts by BladeScraper
Custom User Title
Joined Jun 2011
Originally Posted by R_Lefebvre View Post
IMO, the Skya kits are pure junk. I spent way too long futzing around with the HK600GT. The aluminum is so soft, you really would be better off with plastic parts. The HK450 Pro is pretty decent though. I haven't bought a completely HK550, but I've got parts, and they definitely seem comparable to the 450 in terms of quality.
But honestly, it's gotten to the point that I find that dealing with the HK quality just isn't worth my time and effort anymore. I'm now using mostly Tarot, Heli Option, OMG and genuine Align parts. But even a lot of the Align stuff just isn't good enough. The bearings can be notchy right out of the package, and the shafts are all undersized and that causes slop.
I actually just got some 10mm industrial shafting and will make my own mains shafts now.
So is the "HK450 CCPM Full Alloy" from Skya?
BladeScraper is online now Find More Posts by BladeScraper
Old Oct 18, 2013, 08:26 AM
R_Lefebvre is offline
Find More Posts by R_Lefebvre
Arducopter Developer
R_Lefebvre's Avatar
Joined Oct 2010
I imagine so, yes.
R_Lefebvre is offline Find More Posts by R_Lefebvre
Old Oct 18, 2013, 06:05 PM
Custom User Title
Joined Jun 2011
Glad I didn't buy it...
Old Oct 18, 2013, 08:39 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
Getting ready to build my HK450 TT FBL. Parts are black. It's supposed to be a decent kit but I expect to have to tweak it a bit. I know what to look for now.
You know I'm just crazy enough to order the 700, but I don't have $200 burning a whole in my wallet right now. Maybe next year when it shows up in the USA warehouse. Then I'll shelve it like I do all my kits and slowly collect parts for it. It's my madness,
shahram72 is offline Find More Posts by shahram72
Old Oct 18, 2013, 09:13 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Oct 18, 2013, 09:29 PM
Custom User Title
Joined Jun 2011
If I get it, I want to be able to do 3D!
Old Oct 20, 2013, 04:02 AM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
The OMG hub I got for my Trex 550 had been very good (the swashplate head button and arms are Trex 600N parts, got them on sale a while back)
At first glance it looks like a copy of the KDE hub but it's actually machined to be lighter like the Align 550 hub vs the Align 600 hub. Definitely similar but not a copy. Like the KDE hub it's also the same height as an Align V1 hub which makes it 8mm taller than the V2 hub (you need FBL linkage set A rather than B)
Atomic Skull is offline Find More Posts by Atomic Skull
Old Oct 20, 2013, 04:02 PM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
Originally Posted by McKrackin View Post
I charge two 5000mAh 6S lipos in 7-9 minutes
I use Turnigy 5000mAh 6S 20C packs in my 700 for $86 a pair.
My norm is to charge four 5000mAh packs at once in parallel at 40 amps.
That's 25 minutes or less.
I use a PowerLab 6 charger and two 12V power supplies in series for 1100W and 75 amps.
I bought the charger and PS together for $242
A good charger is a MUST if you have a 700 electric.
I have the power lab 6, just don't have power supplies yet nor a generator.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Oct 20, 2013, 04:04 PM
McKrackin is offline
Find More Posts by McKrackin
Incurable heli addict
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Do yourself a favor and go 24V....It will work on 12V but is limited.
You'll be amazed.
McKrackin is offline Find More Posts by McKrackin
Old Oct 21, 2013, 03:13 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Can you guys believe this? No thrust bearings?
I checked the manual throroughly, no thrust bearings.
Re-watched the "detailed" video on YouTube, he mentions "double grip" tail slider, which the older models did not have. Well the older models have thrust bearings.
Re-watch the video from 7:20. At 8:00 he mentions the awesome great tail boom bearings. No thrust bearings.
I am honestly deeply worried about this. Making cheap helicopters available to anyone, irresponsible people, new people to the hobby?! We all know what happens when tail grip bearings fail!
Why?!
RNAF is offline Find More Posts by RNAF
Old Oct 21, 2013, 03:17 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Re-watched the "detailed" video on YouTube, he mentions "double grip" tail slider, which the older models did not have. Well the older models has thrust bearings.
Why?!
I'm sure it has bearings in the tail grips.
It wouldn't even fly without them.
The force on the grips at 10,000 RPM would just lock up the tail pitch.
Old Oct 21, 2013, 03:18 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
And the tail slider and thrust bearings have absolutely nothing to do with each other.
Old Oct 21, 2013, 03:25 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
Looking again...it might not have thrust bearings in the tail grips.
Looks like it may use the same system as the Trex 700 and just use a regular bearing and washer.
Not ideal but it has worked for years.
Old Oct 21, 2013, 03:33 PM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
I was making a point there, about their lame marketing. They tell that this is a new and innovative model and then it doesn't even have thrust bearings.
No need to tell me they're separate things.
It won't be me who's flying this model with a tail like that. You've been warned.
Old Oct 21, 2013, 03:38 PM
McKrackin's Avatar
Southern Ohio
Joined Mar 2009
You've been warned.
And your credentials for issuing such a stern warning?
Hundreds of helis use that same set up.
I'm not defending it...I've never flown it.
I have however,flown lots of helis without thrust bearings in the tail.
That's a pretty recent addition to most designs.
And as for marketing hype? I'd say the price speaks for itself.
For Sale Goblin 700 dfc head Turbojet404 Aircraft - Electric - Helis (FS/W) 1 Jun 08, 2014 12:39 PM
Discussion hobbyking assault 700DFC heli dna001 Large Electric Helis 28 Dec 01, 2013 04:12 PM
Discussion HobbyKing 700 Size Motors... MaddSkillz Electric Heli Talk 3 Feb 14, 2013 03:09 PM
Sold Goblin 700 DFC Head Turbojet404 Aircraft - General - Radio Equipment (FS/W) 1 Jan 16, 2013 04:14 PM
For Sale Goblin 700 dfc head Turbojet404 Aircraft - Electric - Helis (FS/W) 0 Jan 16, 2013 03:04 PM
