Old Oct 08, 2013, 06:06 AM
eluminerRC is offline
Find More Posts by eluminerRC
eluminerRC's Avatar
Joined Apr 2013
Boscam 5.8 GHz with 2 inch coax cable
Hello guys!
Here is my problem.
I was doing a project where I've tried to put Boscam 5.8 GHz video receiver into my HK 7" monitor in order to get compact, park flier, FPV ground station. I've manage to do this and I'm pretty happy how this turned out (check the pictures).
However, I have a problem now (which I've expected, but not that drastically). My video range dropped significantly and now I can't get over 100 m (300 feet). Now, when this was "stock" I could easily go over that.
Of course, a lot has changed so I was expecting a range drop. But this is too much to the point where it's useless even for park flying.
Here's what I've tried and didn't work:
- I thought that my transmitter 2.4 GHz antenna and my 5.8 GHz video antenna are now to close. I've moved the monitor/ground station 30 feet from the transmitter and same thing happens - so, this is not a problem.
- I've tried all 8 channels and I get pretty much same result on every single one - so, this is not a problem either.
- Since I'm now powering my entire ground station from transmitter pack I was thinking that maybe this has something to do with it. However, no. When I power my FPV equipment from separate pack (on the ground and on the craft) I get pretty much the same result.
These things were easy to try and that's why I've tried them first. Here is what I'm thinking now:
- I basically had only one place inside the monitor to put VRX and even this was really tight. However, this was in the middle of the monitor so every port, switch, LED and RP-SMA connector would be useless there. So, I've desoldered everything and put short cables/wires and mounted them on the housing. Now, LED, switches and RCA connectors are not the problem, but RP-SMA connector and 2 inch coax cable could be. However, as far as I've researched this shouldn't be a problem on such a short distance. What do you think guys, is this 2 inch extension a problem?
- Next: I've noticed 2 big and 3 smaller coils on the monitors main PCB. I know that coax cable should be protected from interference, but still, could these coils be the problem?
I'm willing to try something in order to solve this but I wanted to get couple ideas where to start because any interventions now are pretty complex.
As far as craft side goes, I don't think the problem is there because nothing has changed since last time.
Thank you!
eluminerRC is offline Find More Posts by eluminerRC
Old Oct 09, 2013, 03:58 PM
eluminerRC's Avatar
Joined Apr 2013
bump!
Old Oct 10, 2013, 12:53 AM
Mantovani is offline
Find More Posts by Mantovani
Australia, VIC, Melbourne
Joined Sep 2001
I think you have eliminated most things and now I would try shielding the rx by covering it with copper tape or similar & then ground it. I would guess the monitor will be spewing some rf as it would have a dc-dc converter & other oscillators.
Nice job by the way, looks neat
Mantovani is offline Find More Posts by Mantovani
Old Oct 10, 2013, 06:22 AM
eluminerRC's Avatar
Joined Apr 2013
Thanks for the answer.
I'll try two things this weekend. First, I'll remove display and desolder the monitors PCB board so it's not powered on. Then I'll try to fly using some other display connected with video cable (TV or EasyCap on laptop). This way I'll eliminate the influence of the monitor on the rx. If this is the problem, then some shielding will be required.
If this won't work, then I'll make CP antenna and solder it directly to the rx eliminating the coax cable and connector losses.
Then we'll see. If neither of this will work, then I'm out of ideas for now.
Old Oct 11, 2013, 09:35 PM
HansAuf is offline
Find More Posts by HansAuf
Pass me some zip-ties!
HansAuf's Avatar
United States, FL, Gainesville
Joined Nov 2006
You may have already thought of this, but I'll mention it just in case. The Boscam VRX is RP-SMA. Is the extension cable you have connected possibly SMA? It's very easy to miss this and it would exhibit the behavior you are seeing.
HansAuf is offline Find More Posts by HansAuf
Old Oct 11, 2013, 10:09 PM
Moto Moto is online now
Find More Posts by Moto Moto
Extreme Superlative Hyper-Pro
Moto Moto's Avatar
United States, AL, Guntersville
Joined Dec 2012
That's a nice looking assembly. What are you using to mount the screen on the transmitter?
Moto Moto is online now Find More Posts by Moto Moto
Old Oct 13, 2013, 07:14 AM
eluminerRC's Avatar
Joined Apr 2013
Hello guys! Problem solved!
@HansAuf: Yes, cable is RP-SMA.
@Moto Moto: There is metal "L" peace already on the monitor that is for sliding monitor onto something. I've just unscrew it and screw it on other way so the "L" peace is heading out of instead in the monitor.
Now, here is the solution.
The problem was that aluminium case is actually a shield for the VRX. So, when I took it out the case, there is no shielding so it's prone to RF noise.
So, I've took copper tape and completely enclosed the VRX. But I mean COMPLETELY (you have to put some kind of tape on the inside to prevent shorts). I've tried to put only single peace over it but that didn't work. So, only thing that left uncovered are 4 small openings where wires and coax cable comes out. Of course, I've grounded the shield. And that is it, works as before.
The problem is in RF noise from the monitor, because when I've disconnected it everything worked fine. Even if it's on standby it creates a lot of RF noise.
Thanks for the help guys, especially Mantovani.
Old Oct 13, 2013, 08:09 AM
HansAuf is offline
HansAuf's Avatar
Joined Nov 2006
Nice. Glad you got it worked out.
Old Oct 13, 2013, 06:56 PM
Joined Sep 2001
Good to hear you had success
Discussion 5.8 GHz versus 1.2 GHz VTx ranges chileflora FPV Talk 80 Dec 10, 2015 03:06 PM
Discussion BOSCAM 7" LCD with integrated 5.8 Ghz Rx gnolivos FPV Talk 12 Sep 21, 2013 04:20 PM
Sold 5.8 Ghz Boscam gear VTX,VRX + Cloverleaf antennas DennyNC FPV Equipment (FS/W) 4 Jul 24, 2013 03:49 PM
For Sale 5.8 GHz 8 dBi Flat Patch Antenna With Immersion Duo tkoguy FPV Equipment (FS/W) 3 Apr 24, 2013 06:30 PM
Sold My extra Boscam/Foxtech 5.8 GHz Johnny Ace FPV Equipment (FS/W) 0 Oct 28, 2012 05:59 PM
