Old Feb 18, 2004, 09:40 PM
frederm2002 is offline
Find More Posts by frederm2002
CheapBatteryPacks.com
Beaverton, OR
Joined Dec 2002
iRate lipoly Inventory Updates
I have updated our current inventory for Lipoly's on our website. Many of you have been asking for more product and the good news if we have some more.
Also, New Hi-Ouput 830 cells is also on its way with our next shipments. We will be offering it for preorder on our website shortly. Loose cells or packs. Your choice. The 830 is a thicker cell which gives it a lower IR value (per the manufacturer). Still from the same manufacture just a new size and shape.
5.5 x 34 x 50mm is its size. We are seeing about a 8-10% voltage improvement on the new thicker cells.
www.cheapbatterypacks.com to order or to see qty status.
frederm2002 is offline Find More Posts by frederm2002
Old Feb 18, 2004, 10:16 PM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
I don't see the 830's. Are they the same as the 850's?
OOps never mind - I didn't read it closely enough.
Any idea of about how long?
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Feb 18, 2004, 10:59 PM
Beaverton, OR
Joined Dec 2002
Should be for sale by April 1st. . Hopefully earlier. Will have plenty of inventory this time around.
MIke
Old Feb 18, 2004, 11:36 PM
Beaverton, OR
Joined Dec 2002
UPDATE !!
Will have a large shipment in less then 2weeks. Will have an air shipment of 830's next week. Will keep you all posted.. Pricing should be similar to 850's...
Old Feb 19, 2004, 12:08 AM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
Mike,
Everyone seems to be talking about new improved cells comming out this spring. Any other new stuff in the works from your end?
Narrower 2200 cells would be nice
Also - on these 830's - does this meam they will be capable of running at a higher C level than the 850's?
Larry
Old Feb 19, 2004, 12:16 AM
Beaverton, OR
Joined Dec 2002
the 830's are thicker then the 850's The engineer told me that the thicker cells have lower IR and that is why higher voltage under load.
I have always tried to be conservative with my ratings. 8C,10C,15C are all possible with this cell as they are with the 850. The difference is that watts will be up under those same loads. By about 8-10%. I will post some comparitive graphs.
the 1800-2600 cells may now be done in a 50mm width instead of the 56mm width. This should help some. I am working to get it down to 42-46mm...
I have read a lot of new threads lately of "new" cells coming etc. We will have to see. As for my products they will continue to offer outstanding performance at a great price. And we will continue to offer loose cells, solder, flux to those that want to build their own cells. For those that want premade packs we can do that to. We can weld lipo cells together and create 2p-10p or 2s-10S whith out any problem.
Old Feb 19, 2004, 07:38 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Are you trying to win a popularity contest or something?
Dave Hederich is offline Find More Posts by Dave Hederich
Old Feb 19, 2004, 08:08 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
If so, I'm clapping!
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Feb 19, 2004, 08:14 AM
Happy|Harry is offline
Find More Posts by Happy|Harry
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
- RD
ditto
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Feb 19, 2004, 11:10 AM
arx_n_sparx is offline
Find More Posts by arx_n_sparx
Dismembered Member...
arx_n_sparx's Avatar
Niagara Falls/Toronto area
Joined Dec 2003
I have a question
Does cheapbatterypacks make packs that are center tapped? I won't purchase a built pack without this feature. The center tap wires can be of a lighter gauge wire (#20 awg would be fine), but the taps are what I would consider as neccessary for cell balancing.
Brad
arx_n_sparx is offline Find More Posts by arx_n_sparx
Old Feb 19, 2004, 11:34 AM
Beaverton, OR
Joined Dec 2002
The problem right now is that doing center taps adds solder to the tabs in the middle of the pack. Since we weld instead of solder it would mean now we must also solder to each tab. this would definately increase costs for us. But for those that don't mind paying for the work done I have not problem offering it.
MIke
Old Feb 19, 2004, 12:28 PM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
I have tested the new 830's and I compared them head to head with the 850 Irate.
They give constantly higer amps and voltage (around 0.1V per cell), with an avg 9% more watts during a full discharge.
The test was done at 13C...
luc is offline Find More Posts by luc
iRate Lipoly 2600 - Available now with Solderable Alum Tab frederm2002 Batteries and Chargers 13 Apr 30, 2004 12:45 PM
iRate Lipoly 1300 and 2600 in stock now frederm2002 Batteries and Chargers 4 Dec 10, 2003 01:36 PM
iRate LiPoly's. Pre-order them now ! frederm2002 Product Announcements 0 Dec 08, 2003 02:51 AM
Pre-Order for iRate Lipoly cells now available frederm2002 Batteries and Chargers 0 Dec 06, 2003 09:04 PM
