Feb 18, 2004, 09:25 PM
San Francisco, CA, USA
Joined Jun 2001
you can make a Y connector that will allow you to hook up your multimeter in series with your battery. cut off the probes and attach them to a female connector for later use. put a male connector on the multimeter leads. you can reattach the probes later if you want. then make a Y connector that has one male and two female plugs. each of the three wires in the Y connector connect the positive of one plug to the negative of the other. then you connect the multimeter to one of the female plugs, the ESC to the other female plug, and the battery to the male plug of the Y connector.
make sure your multimeter is rated for a good amount more current than you expect to see. it sounds like you'd need at least one rated for 20A. multimeters rated for 20A+ are kind of rare, so you might want to get an Astro Whattmeter instead. they are very handy tools. do a search, and you will find lots of info on them.
