Old Feb 18, 2004, 04:11 PM
madkiwi is offline
Find More Posts by madkiwi
New Zealand
Joined Jun 2001
1/4 scale cub - do I need 1/4 size servos?
Hi all
I've just about managed to get my hands on a 1/4 scale Bud Nosen J3 kit.
Apart from throwing out the heavy wood and lightening where possible I really wanted to know what size servos I could use?
The wing span is 108" and all up weight I have no idea but guess anywhere from 16lb to 18lb's or lighter if possible.
So should I use standard size or even bigger? I thought about using the hitech or JR wing servos for the ailerons, but really unsure.
Any help or advice would be appreciated.
Dwayne
madkiwi is offline Find More Posts by madkiwi
Old Feb 18, 2004, 04:30 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
On my 1/4 Sig I used standards for each aileron. I used a 1/4 scale for the elevator and a standard for the rudder.
This was a few years ago. Todays high touque standard servos would suffice.....
But the 1/4 scale servos are not nearly as expensive as they used to be. Hitecs are under $40 here in the states.
Old Feb 18, 2004, 07:13 PM
Highflight is offline
Find More Posts by Highflight
Out of Time
United States, TX
Joined Jul 2003
Here's the thing about a 1/4 scale Cub:
Even though the aircraft is big, it's still a non-airbatic plane so for scale type flying, standard servos would "technically" be OK.
But here's the BUT: All of the control surfaces on that aircraft are large and on a typical landing, the weight, momentum and intertia of, say, an elevator half, can easily cause it to whip downward when the tail drops and strip out standard duty gears. THAT'S the kind of abuse that a standard size servo won't stand up to.
I'd highly recommend that you use at LEAST 85oz servos for each aileron and elevator half, and a 150oz for the rudder by itself, and it wouldn't hurt if you exceeded those specs.
Here's the trick if you're getting into giant scale; save all your standard servos for the throttle and bomb release mechanisms.
Since you're getting into giant scale, just bite the bullet and start "supersizing" your servos too.
Highflight
Highflight is offline Find More Posts by Highflight
Old Feb 18, 2004, 11:44 PM
4*60 is offline
Find More Posts by 4*60
most exalted one
Canada, BC, Blind Bay
Joined Aug 2002
I would probably go with Highflight on it, but.... I'm flying a 13lb. 1/4 scale Balsa USA Cub with standard servos except for 700bb on the elevator. The way I fly it and the way it touches down I'll probably be OK. I was told by a very long-time very large scale flyer that the combo would work fine and it would be all I need. He could have sold me more expensive servos.
4*60 is offline Find More Posts by 4*60
Old Feb 19, 2004, 01:30 PM
madkiwi is offline
New Zealand
Joined Jun 2001
Hi all
Thanks for the replies. I should have mentioned it will be an electric setup but I guess that doesn't really matter. I will use standard servos (ball bearings) on aileron, rudder and something bigger for the elevator.
Thank you for your help.
Dwayne
Old Feb 21, 2004, 11:43 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
Madkiwi - My recently completed 1/4 scale Tiger Moth uses Hitec HS77 BB MG servos on all surfaces except rudder. One per aileron and one per elevator half - they have plenty of torque and accuracy for a slow flying model and the 'MG' bit ensures the gears won't easily strip in a heavy landing or during transportation. The rudder on the Moth uses two smaller Hitec servos, but I can't remember which ones right now and can't see the lable on them either. I strongly suggest that you split the elevator for both safety and reliability reasons.
GordonTarling is offline Find More Posts by GordonTarling
Question 1/4 scale Cub?? GeeBeeFan Scale Fuel Planes 19 Apr 11, 2012 01:19 PM
1/4 Scale Cub - Wiring & Redundancy madkiwi Giant Scale Airplanes 13 May 29, 2004 06:54 PM
1/4 scale cub-ryobi 31cc highfly68 Giant Scale Airplanes 2 Feb 26, 2004 07:36 PM
Sig 1/4 scale Cub and Astro 40G Matt Dyer Power Systems 7 Sep 06, 2003 04:28 PM
100 in 1/4 scale Cub w servos $275.00 GoodTill Aircraft - Fuel - Airplanes (FS/W) 1 Jan 18, 2003 08:25 PM
