Old Feb 18, 2004, 10:56 AM
sal is offline
sal
Find More Posts by sal
sal
NSP (Vermont)
Joined Aug 2000
New! MicRotex motors are here!
Got in three motors as samples to bring to WRAM Show!
I have some of the specs so here they are:
MicroTex 20/5/16
Efficiency max 79%
6A with max at 8amp
Rm .284
weight: 24 gms
Prop size 7 x 3.8-8 x 4
with 8 x 4 prop 280 gms thrust @7.8 A
with 7 x 3.8 prop 232 gms thrust @ 5.3 amps
sal is offline Find More Posts by sal
Old Feb 18, 2004, 11:04 AM
sal is offline
sal
sal
NSP (Vermont)
Joined Aug 2000
MicRotex 20/5/18
Efficienct 79%
Max amps 6 with peak at 8
Rm .314 ohms
weight 24 gms
prop 8 x 4, 9 x5
With 2-li_poly cells
with 7 x 3.8 prop
325gms thrust @5.1 amps
with 8 x 4 prop
370 gms thrust @7.6 amps
with 9 x 5 prop 300 gms thrust @ 8.8 amps
Old Feb 18, 2004, 11:09 AM
sal is offline
sal
sal
NSP (Vermont)
Joined Aug 2000
MicRotex 20/5/14
24 gms
efficiency 79%
max amps 6 with peak at 8
Rm .192 ohms
2 cell-Li-poly
with 8 x 4 prop 280 gms thrust @7.8 amps
If anybody is able to convert these figures to Kv, Io and Rm (we know that one already)
I will give them a free MicRotex motor. This is the first person with complete and ACCURATE info. on all 3 motors.
In the meantime. If you want to see one come to our booth at the WRAM show this weekend.
Old Feb 18, 2004, 11:43 AM
ronrandle is offline
Find More Posts by ronrandle
ronrandle's Avatar
Huntersville, NC
Joined Jul 2002
Sal those figures look very promising, I wish I could convert 'em as I would pop one of those on a plane in a heartbeat.
I'm having a hard time distinguishing between the 15 and the 14 as the specs look identical.
But what blows me away is the 18 with over 13 ounces of thrust on 2 cells with a 9x5 prop and 7.6 amps. That is incredible.
If I make up a few figures and they look good can I at least get a discount?? :-)
Ron
ronrandle is offline Find More Posts by ronrandle
Old Feb 18, 2004, 12:43 PM
Joe Ford is offline
Find More Posts by Joe Ford
Castle Tech
Joe Ford's Avatar
Olathe, KS
Joined Aug 2003
sal what type of props...GWS, APC,...??? Also what 2 cell lipo...etec, kokam, tp...mah?
Joe Ford is offline Find More Posts by Joe Ford
Old Feb 18, 2004, 01:04 PM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
Don't know where Sal is getting his numbers, but they're not the same as what is listed on the Rotex web site. The site also lists the type of props that were used in the tests.
http://www.modelweb.cz/freeair/motory.htm
DNA is offline Find More Posts by DNA
Old Feb 18, 2004, 02:01 PM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Sal: Why not just put 2 pieces of tape on the bell and use an RPM meter to find the Kv (divide the RPM by the voltage at the ESC), then measure the amperage with a wattmeter or Sears clamp meter on for the Io. That'd be super simple and take less than 5 min.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Feb 18, 2004, 02:18 PM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
Prices please
How much for the 20/5/18? Nothing on your website yet, so when can we order?
jpflyer
jpflyer is offline Find More Posts by jpflyer
Old Feb 18, 2004, 03:33 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Hi Sal, I just sent you an e-mail in the hope of being one of the first in line for a 20/5/18. [Ordered February 2]
I am puzzled by the posted data for the 20/5/18 - how is it that a 9x5 at 8.8A is producing LESS thrust (only 300g) than an 8x4 at 7.6A (370g)? I assume, just from the 8x4 and 9x5, that those are GWS HD props?
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 18, 2004, 03:46 PM
DNA is offline
DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
It says that they're $80 on NSP's web site.
Old Feb 18, 2004, 05:17 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
Those are numbers for the 20/8 series not the 20/5. So which one do you have?
And some the props are HD and others are SPC SF so they might not be comparable.
Rick.
rpage53 is offline Find More Posts by rpage53
Old Feb 18, 2004, 07:06 PM
DNA is offline
DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
Nope, they're not the numbers for the 20/8/18.
Sal shows for the 20/5/18
Web site shows ----
For the 20/5/18
With 2 li poly cells
with 9 x 5 prop 250 gms thrust @ 6.0 amps
With 3 li poly cells
with 8 x 4.3 prop 350 gms thrust @ 7.7 amps
For the 20/8/18
with 9 x 5 prop 220 gms thrust @ 4.12 amps
with 9 x 5 prop 310 gms thrust @ 5.6 amps
Old Feb 19, 2004, 01:22 AM
LTChip is offline
Find More Posts by LTChip
LTChip's Avatar
Helena, MT
Joined Feb 2003
Sal - can you explain what the 20/5/15 is - that is the one that you have for sale on your website????
Are they / were they ever in stock? If not- when do you expect to have them - and which model specifically will be in stock soonest - and which model will be shipped to those that ordered the 20/5/15?
It seems that it would have been more honest to call that a pre-order rather than imply that they are a stocked item.
Please clear this up for us.
LTChip is offline Find More Posts by LTChip
Old Feb 19, 2004, 01:23 AM
LTChip is offline
LTChip's Avatar
Helena, MT
Joined Feb 2003
Also - can you please post the dimentions of the motor mounting shaft?
Old Feb 19, 2004, 01:42 AM
rpage53 is offline
Boffin
rpage53's Avatar
Joined Apr 2001
I just knew that the 20/8 was 79% efficient and the 20/5 was 75%. I guess Sal's motors are different then.
So Sal, we need rpm to be able to calculate MotoCalc parameters. Unless we guess about the rpm required to produce the thrust.
Discussion The NEW CustomCDR. 20mm Billet Bullet motors are here!! Part #2 ryanl2006 Power Systems 335 Apr 03, 2009 01:41 AM
The NEW CustomCDR. 20mm Billet Bullet motors are here!! ryanl2006 Power Systems 872 May 07, 2006 04:49 PM
For Sale The NEW CustomCDR. 20mm Billet Bullet motors are here!! Pre-builts and kits.. morphs Aircraft - Electric - Airplanes (FS/W) 7 Oct 13, 2005 11:13 PM
The Big AXI Motors are here! sal Power Systems 164 Dec 17, 2003 03:27 AM
New Brushless motors are here! Todd Long Vendor Talk 0 Nov 08, 2002 12:02 AM
