Closed Thread
Old Feb 17, 2004, 11:25 PM
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
TOC Parkflyer - they're coming out of the woodwork... by Sal C - Part 2
This is the continuation of the thread started here:
http://www.rcgroups.com/forums/showt...39#post1407139
Carry on
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Feb 17, 2004, 11:44 PM
Hi Wattage Electrics - Cool
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
I just conducted an interesting experiment...I compared my CD Rom motor (picture in previous thread) to my PJS550, using the same battery, controller, prop and setup.....the results are interesting.
PJS550
1:1 gearing
Etec 1200 3s
Phoenix10
APC 10x4.7 prop
5370 rpm
10.1 A
Cost $90.00
Cd rom motor
5:1 gear reduction
Etec 1200 3s
Phoenix10
APC 10x4.7 prop
5310 rpm
6.04A
Cost $freebie
60 less rpm but 40% less current!
Rad Racer is offline Find More Posts by Rad Racer
Old Feb 18, 2004, 12:13 AM
Kentucky
Joined Dec 2003
It seems to me that the PJS 550 should be putting out more rpm's than listed at full-bore throttle on a 3s pack. Didn't Eric run a static test on the 550 at one point that showed much higher rpm's?
Glad to see the Mini TOC thread has been moved over to the 3D forum. Now I don't have to jump back and forth between forums to catch up with all the great 3D planes. Hopefully you guys won't be corrupted by all the foamies over here as much as I have (I SWEAR I'll build a TOC someday, after I finish all my unfinished foamy kits! Balsa wood doesn't go bad, does it?)
Johnny B.
Johnny B is offline Find More Posts by Johnny B
Old Feb 18, 2004, 01:01 AM
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
I've got TOC bits comming.
Tram is offline Find More Posts by Tram
Old Feb 18, 2004, 07:09 AM
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
as i finaly feel my building skills are up to it now(i hope) i'll be building a mini toc right after my e*star yak, (i've been
holding off since nov so a few more weeks wont hurt ) are the plans still available through iflyrc71 with paypal?
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Feb 18, 2004, 07:39 AM
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Originally posted by Happy|Harry
...are the plans still available through iflyrc71 with paypal?
phil
Yes they are!
Sal C is offline Find More Posts by Sal C
Old Feb 18, 2004, 11:17 AM
edible_engine's Avatar
Just south of Cambridge, UK
Joined Oct 2003
theese mini toc things, how much are they. Ive only just started to read the first thread so sorry if this has been answered
edible_engine is offline Find More Posts by edible_engine
Old Feb 18, 2004, 12:37 PM
Tram's Avatar
Florence, Al
Joined Oct 2000
How much is a minitoc?
Plans - $20
Wood - $15
Assorted stuff (carbon fiber gear, wheels, glue, etc) - $15
Solite - $10 (only needs 1 roll)
Servo's x 3 - ~$60-80 (depends on what you use)
PJS 550 - $90
CC10/25 ESC - $65
Etec 3S1200 - $35
Total ~$330...
Old Feb 18, 2004, 01:09 PM
Burr Ridge. IL
Joined Jan 2004
Rad Racer:
I want one of your geared CDRomers!
Your 5300 rpm is enough to 3D the MiniTOC: It's the same rpm we were getting on the prototype which used a brushed Speed 300 and 9 720mAh Nimh's. Not a rocket but will definitely lunge out of a hover as long as AUW is <11oz.
Which 550 are you using? The E or R won't spin a 10x4.7 as fast as a plain 550, which I'm sure is much higher than 5300 (over 7000rpm if I recall correctly). Either that or is there something wrong with your 550? Mine are BEASTS!
Nevertheless 5300 rpm, almost no cost, I want one of your gems.
Did I mention I want one?
Can you at least tell me exactly how you do it? I'd like to test one in this airframe.
Now if only we could rig up a free controller...
Eric
echassin@work is offline Find More Posts by echassin@work
Old Feb 18, 2004, 01:20 PM
Burr Ridge. IL
Joined Jan 2004
Edible Engine:
Go to the original thread and check out the video in the first post.
It doesn't include every maneuver the thing is capable of, but will give you a good idea of the plane's versatility in flight.
On page 4 or so there are construction photos to give you an idea how it goes together.
Rafael (Iflyrc71) still sends out plans/instruction manual/equipment list on request (I think $15 + S&H $5)
Cheers,
Eric
Old Feb 18, 2004, 02:09 PM
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
Eric,
I am sure my PJS is a 550, not R or E....and am surprised it doesn't perform better. Perhaps it's my batteries or controller....as each uses the lighter gauge wiring. Before I draw any final conclusions, I intend to do some further investigation using some of my other electric motor stuff.
I'm glad you like my CDrom stuff, it's a lot of fun building and testing these motors. My next motor will produce the same power as a PJS while (hopefully) keeping the current in check.
I get a lot of requests to build motors, but generally don't do so because I don't want this hobby to become a job. Now, with that said, I will build you a motor....after all you are Mister TOC. So as not to bore all these folks, I'll PM you to get the details of the motor you desire.
Wayne
For those interested, this thread has some detailed pictures of my motors.
http://www.rcgroups.com/forums/showt...hreadid=186326
Old Feb 18, 2004, 02:40 PM
guyaneze's Avatar
gainesville FL
Joined Jan 2002
rad: a couple of questions.....
could esc timing be a factor?
my pjs (300) runs better on 3 cells on an old jeti esc....runs better on 2 cells with the new cc 10.
I noticed you said your pjs 550 only pulls 10.1 A.....interesting because at full bore with a 10x4.7 and the 3s 1200 etec it should be pulling more than that.
from the old thread....
eric said in one post that both the 550 and 550R pulled about 13A
on 3s etec 1200s
from one of eric's posts he seems to have both the cc10 and cc25....not sure if one works any better....i have both....but closest motor to that that I have is the rotex 25/6/15
salc said the pjs550 should turn around 7800 rpm with the 10x4.7
anyway the cdrom motor u have seems like a winner. I've got one i pulled from an old cdrom but its a bit small and might be more of a competitor with an IPS if i ever figure out how to mount the windings on some bearings and the bell on a shaft....
eric, sal...others....cool plane...i hope to get one soon....i like the way u guys are always sharing ideas in this thread....
guyaneze is offline Find More Posts by guyaneze
Old Feb 18, 2004, 03:02 PM
BOSS
j_z_123's Avatar
New Jersey (excl EWR), United States
Joined Apr 2002
I think Some one should kit these....cause I really want one, and suck at scratch building!
Jon
j_z_123 is offline Find More Posts by j_z_123
Old Feb 18, 2004, 03:13 PM
Aberdeen, Scotland
Joined Jul 2003
Jon
ditto, that's why i waited so long to try and build one. if not a full kit, is there a possibility of a wingrib package perhaps?
as this is the part i'm most doubtfull about doing myself.
phil
Old Feb 18, 2004, 03:14 PM
Kentucky
Joined Dec 2003
Either that, or foam-ize it!!! (Sorry Eric, but like I said before, I've been corrupted by all my little foamies).
Closed Thread
Discussion They're begging to go out! rtherbe Parkflyers 13 Feb 17, 2007 06:06 PM
Discussion Are AP businesses coming out of the woodwork everywhere or just in AZ?? Rip-N-Burn Aerial Photography 90 Dec 10, 2006 09:22 AM
TOC Parkflyer - they're coming out of the woodwork... by Sal C - Part 3 JWarren 3D Flying 34 May 03, 2006 02:20 PM
***When is the GWS C-130 coming Out? ***** bobbart GWS (Grand Wing Servo) 18 Oct 23, 2004 11:02 PM
TOC Parkflyer - they're coming out of the woodwork... Sal C Parkflyers 524 Feb 17, 2004 11:26 PM
