Old Jan 10, 2014, 06:32 AM
mysql101 is offline
Find More Posts by mysql101
Joined Feb 2013
^ Not only that, but the screws on the tarot kit are soft. It's easy to strip them without any loctite. With red, you'll be drilling them out after.
mysql101 is offline Find More Posts by mysql101
Old Jan 10, 2014, 07:48 AM
Dry Biscuit is offline
Find More Posts by Dry Biscuit
Joined Dec 2013
Originally Posted by RDTague View Post
Red is too permanent, IMO. Red can pull the threads out, if you need to remove. Blue is a better strength of loctite, IMO, in our application.
Yup I used Z42 blue. The red is like a retaining compound which I use on some of the components on my Heli tail assemblies. The only way to loosen the stuff is a blowtorch !
Dry Biscuit is offline Find More Posts by Dry Biscuit
Old Jan 10, 2014, 09:59 AM
fanch72 is offline
Find More Posts by fanch72
fanch72's Avatar
Sweden, Stockholm County, Stockholm
Joined Sep 2013
Foxtechfpv just came out with These, which will aid in transport, too.
https://www.youtube.com/watch?v=gltkGkS1r5I
I've seen that. Has someone tried? Is it as safe as they say?
fanch72 is offline Find More Posts by fanch72
Old Jan 10, 2014, 05:02 PM
RDTague is offline
Find More Posts by RDTague
RDTague's Avatar
United States, IL, Cowden
Joined Mar 2013
This seems to be the "New Thing." The self locking props started with the Phantom 2 and since then, T Motor and Foxtechfpv has jumped onboard. I can't really see any problems, as long as the correction direction adapter is used. I know there are a ton of flyers who remove their props during transport. I, for one, have never done so. Threads stretch each and every time they are tightened, so I really never wanted to take a chance. But, that's just me, too.
RDTague is offline Find More Posts by RDTague
Old Jan 10, 2014, 11:57 PM
aurora912 is offline
Find More Posts by aurora912
Australia, VIC, Geelong
Joined Mar 2010
Just like to say thanks to RDTague for this build thread.
I have just finished building my 680pro and flew her this afternoon.
Approx 3.2-3.3kg
680pro Stock Kit
3508-580 Multistar's w/ 12x4.5 APC Multirotor Props
DJI 30amp Opto's
Gopro + t2-d Gimbal + Video gear
2 x 5000mah 25c Zippy Compact's
Flew to 20mins with 14.5V on the OSD, Batts are on charge now and will edit with how many mah's they take back.
Couldn't be happier!
btw still cant get over how heavy these things actually are compared to a f450!
aurora912 is offline Find More Posts by aurora912
Old Jan 11, 2014, 01:20 AM
car2carl is offline
Find More Posts by car2carl
United States, CA, Pasadena
Joined Dec 2013
Very nice Aurora
My order is in transit and almost same setup like yours.
Can you tell me , did you drill motor plate to fit your motor holes ?
I believe RDT drill the plates for older version because the holes spacing were not match
and your motor spacing is 19mm and 25mm , and I'm planing to use 4108-600KV same holes spacing like yours. Thank you
car2carl is offline Find More Posts by car2carl
Old Jan 11, 2014, 01:25 AM
fanch72 is offline
fanch72's Avatar
Joined Sep 2013
You're probably right.
They're out of stock now...
Old Jan 11, 2014, 04:38 AM
dchutinaton is offline
Find More Posts by dchutinaton
Joined Nov 2013
I upgraded to the Foxtech Carbon Supreme 1240 props and saw a huge improvement in stability and efficiency.
My OSD was reporting around 39 amps during hover with the plastic Gemfan 1245 props I was previously using. With the Foxtech Carbon Supreme 1240 props it was hovering at around 32 amps. That's like a 18% improvement in efficiency. Amazing! Unfortunately I crashed into a small bush/tree while messing about in manual flight mode to see how much throttle it took to hover. It looked like it was taking around 80% throttle to hover. I was testing with a single 4S 5400 battery. Unfortunately when I looked up I had lost control of the craft and barely avoided a catastrophic crash. Seems like the only damage I sustained are 3 broken props. Time to order more props. No more flying till I get more props.
Note to self, do not fly in manual mode in my backyard!!!
dchutinaton is offline Find More Posts by dchutinaton
Old Jan 11, 2014, 07:50 AM
multi phobic is offline
Find More Posts by multi phobic
Joined Jun 2013
Hey guys, I have a specific question reguarding this setup. I have the Naza V2 and the T2D gimble. I cant seem to get control of the tilt function of the gimble. Im plugged into the F1 on the Naza and I use the small servo cable that splits to three heads. I have the white plugged into the "T" at the top row and the black into a negative on the bottom row of pins. I have the opposite end plugged into the NAZA so that the white cable is on top pin in the F1 port. I think the problem may be in my TX setup.. I have the input for my right knob on my dx9 going to the AUX1 port on my RX which goes to the X1 port on my NAZA. Does any of this match what anyone else has?
multi phobic is offline Find More Posts by multi phobic
Old Jan 11, 2014, 05:45 PM
RDTague is offline
RDTague's Avatar
Joined Mar 2013
I'm not sure what radio you are using, but Here is a video I posted on my blog page for a DX8.
Old Jan 11, 2014, 05:46 PM
RDTague is offline
RDTague's Avatar
Joined Mar 2013
Approx 3.2-3.3kg
680pro Stock Kit
DJI 30amp Opto's
Awesome!
Old Jan 11, 2014, 05:47 PM
RDTague is offline
RDTague's Avatar
Joined Mar 2013
Man that SUX! Hopefully the damage isn't too bad!
Old Jan 11, 2014, 08:22 PM
RkyMtnShooter is offline
Find More Posts by RkyMtnShooter
United States, CO, Windsor
Joined Aug 2013
Need Help!
Hey guys - I sure could use some help. I just completed my 690 build based on RDTague build (stock 690 frame with SunnySky 580kv motors). This is my third copter build (F450 + F550) so I have a little experience but still learning.
Description: RkyMtnShooter Tarot 690 build Name: Tarot690-3.jpg
Description: Name: Tarot690-4.jpg
Description:
Build Config.
- Sunnysky 580kv motors - ZTW Spider 30A ESC Opto with SK firmware - Naza V2 - Spectrum AR8000 w/ TM1000.
Description: Name: Tarot690-11.jpg
Description: Name: Tarot690-13.jpg
Description:
The problem I'm having is the motors are not lifting properly. The craft lifts on the right side. If I try and punch it to get it into the air it will flip over. Now I know what you are thinking... wrong prop set up or wrong MC wiring - no... not that easy... I believe all this is correct. I can say from experience with the Naza V2, the craft should lift off amazingly even and smooth - so I know how a good lift off should look.
Here's my config details:
- MC is wired correctly - both from receiver and motors
- I Throttle calibrated each ESC individually and got the confirming beep
- Each ESC has 3M foam between it and the frame - to remove vibration and electrical flow.
- Naza V2 allows you to test each motor individually to make sure it's wired correctly and spinning correctly - they are...
- all props are perfectly balanced (I use scotch tape on bottom - worked great on other crafts)
- when I spin up the rotors they look and sound great. Not seeing any unusual vibration or hearing anything funny.
- when I move the sticks the craft responds correctly (eg. AIL tilts craft left and right, etc..)
- I originally used bullet connectors for the ESC's but soldered directly after reading RDTague post regarding this.
I'm kind of at a loss on what to do next...? ESCs and motors seem ok. It seems like a calibration problem... From just looking at rotors spinning, it kind of looks like rotor #4 is spinning slower than the others - but I might be hallucinating.
I would appreciate any assistance you guys can offer. Thanks!!
RkyMtnShooter is offline Find More Posts by RkyMtnShooter
Old Jan 11, 2014, 08:50 PM
LoneStriker is offline
Find More Posts by LoneStriker
Joined Oct 2013
What mode are you flying when it flips? Have you tried flying manual mode? If manual mode works, then there's possibly something amiss with some of your sensors: GPS, compass, accelerometer. Did you try the Naza IMU calibration?
LoneStriker is offline Find More Posts by LoneStriker
Old Jan 11, 2014, 10:20 PM
Joined Aug 2013
Thanks for the fast reply! I have tried all modes - GPS, ATTI, Manual. I did notice when I try to lift-off in GPS & ATTI it lifts on the right side, but when I try in Manual it appears to lift from the rear. By the way my motor config is Hex-V.
I did select IMU Calc but the software said I did not need to do this. Should I try this if software is telling me that it's not nesscessary?
Build Log Tarot iRon Man 1000 Octocopter Build Askyvision Multirotor Talk 1527 May 30, 2016 03:50 AM
Link RC kite build logs.. show your kite and link it to your build log davereap RC Paragliders and Kites 19 Mar 31, 2016 06:03 PM
Question Tarot 690s build, making sure I don't forget anything or make any mistakes sodaant Scratchbuilt Multirotors 9 Jan 13, 2014 06:53 PM
Build Log Tarot FY680 build log leadwake Multirotor Talk 1 Jun 04, 2013 07:59 PM
Sold New Intel i7 3770k, 32Gb RAM, 1TB HD Custom Build $690 cbcalhoun Non R/C Items (FS/W) 7 Dec 15, 2012 01:45 AM
