Old Sep 30, 2013, 04:12 PM
Cardboarder is offline
Find More Posts by Cardboarder
Joined Sep 2013
Constructing a cardboard plane.
Hello. After seeing some planes made from cardboard, I decided to construct my own. I am making a large plane from cardboard, popsickle sticks, and glue. I am aware I need brushless motors, ESCs, receiver, and battery. However, I don't know what kind of each type. I'm looking for help as I'm a newbie in RC.
The plane: The plane has a wing span around 3 feet. The wings have ailerons. It has a rudder and will have elevators. 4 motors will be used. 2 on each wing. I will use a total of 5 servos and 4 brushless motors. How will I plug all this in into one receiver? Will 4 1400kv motors lift this 2-3 pound aircraft?
Edit: I haven't added elevators and the planes weighs 2 pounds without parts.
Cardboarder is offline Find More Posts by Cardboarder
Old Sep 30, 2013, 04:22 PM
cmdl is offline
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
these forums are a bit more targeted toward building:
http://www.rcgroups.com/foamies-scratchbuilt-428/
and
http://www.rcgroups.com/the-builders-workshop-131/
cmdl is offline Find More Posts by cmdl
Old Sep 30, 2013, 07:34 PM
Joined Sep 2013
Building the plane is no problem. It's that I need more help with choosing electronics for the plane rather than building. Isn't this the forum for electronics? I'm new here.
Old Sep 30, 2013, 07:59 PM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
http://www.rcgroups.com/power-systems-13/
eagle777 is offline Find More Posts by eagle777
Old Sep 30, 2013, 08:14 PM
smcx66 is offline
Find More Posts by smcx66
Joined Jun 2013
Then I would suggest getting a power train system that will produce 1kG of thrust
OR MORE, EASILY. 3-4 cells motor. So you can slap popsicle sticks on there until your heart is content. The motor's KV and prop combination is kind of like gearing. which is determine by what type of plane you want to build...
Im not a mind reader to know what you have in mind as an air frame type.
Id also recommend a prop in a slot type model....it'll save you time and money on props
as you learn to fly. They come in all type of designs.
never the less...a 1kg thrust motor will give you enough without worring
too much about power to wieght ratio.
I personally think it's cheaper to just get DTF...it saves me gas money.
I still have more than 10 sheets out of 20 that's been over 6 months.lmao
smcx66 is offline Find More Posts by smcx66
Old Sep 30, 2013, 09:07 PM
tom1968 is offline
Find More Posts by tom1968
Still circling in sink...
United States, MA, Grafton
Joined May 2006
In the Beginner Training forum, there's a sticky on Choosing a Power System. I'd suggest going through that first - it will get you up to speed better than anything else.
tom1968 is offline Find More Posts by tom1968
Old Sep 30, 2013, 09:50 PM
Joined Sep 2013
Thanks everyone!
Old Sep 30, 2013, 10:18 PM
cmdl is offline
cmdl's Avatar
Joined Jan 2012
ok, you obviously weren't clear in your first post and edited your post after i had responded. you can ask questions here (and anywhere for that matter) but perhaps being clearer in the beginning would have helped. regardless, folks on the forums i suggested would also be able to answer your questions - more so perhaps since as builders they have to consider every aspect - from the airframe to the electronics.
Old Sep 30, 2013, 10:22 PM
Joined Sep 2013
Sorry will do.
Old Sep 30, 2013, 11:08 PM
billisfree is offline
Find More Posts by billisfree
billisfree's Avatar
Joined Oct 2012
Suggested electronics for your plane:
Transmitter: $140
http://www.amazon.com/DX6i-DSMX-6-Ch...=spectrum+dx6i
ESC: 25amp (25C) $7.15
http://www.hobbyking.com/hobbyking/s...idProduct=6460
Outrunner motor: 200watt $9.48
http://www.hobbyking.com/hobbyking/s...dProduct=12920
Servos (2 @ $2.68 each)
http://www.hobbyking.com/hobbyking/s...rSearch=hxt900
DX6i receiver: $5.89
http://www.hobbyking.com/hobbyking/s..._Receiver.html
Battery: 3S (3cell 11 volt) $5.75
http://www.hobbyking.com/hobbyking/s...strSearch=lipo 3s 25c 1000
And 3 EC3 female connectors.
It sure beats the cost of those expensive Supercub planes that sell for $199
Plus your have all these parts which you can use on future planes.
billisfree is offline Find More Posts by billisfree
Old Oct 01, 2013, 02:28 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Although whether any of the suggested power setups will be of any use to you will depend on what you mean by "a large plane". Details are important, I think 36" wingspan is a pretty large plane...some of my friends think it's not large until you get over about 80". Weight is the most important factor and because you're using heavy materials yours is likely to be heavier than most.
I suggest you build the plane then tell us how big it is and what it weighs. Then we have a chance of suggesting a power system for it.
Steve
slipstick is offline Find More Posts by slipstick
Old Oct 01, 2013, 07:02 AM
Ron H is offline
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Adding 4 motors/ESCs/servos/pack will add a fair amount of weight. 2lbs AUW would be fine, but that thing will be heavy at this rate. Certainly far from ideal for a first plane.
Ron H is offline Find More Posts by Ron H
Old Oct 01, 2013, 07:22 AM
Joined Sep 2013
I know it's a challenge, but it can be done.
Old Oct 01, 2013, 08:19 AM
Joined Sep 2013
I'll post dimensions later.
Old Oct 01, 2013, 08:37 AM
Joined Sep 2013
What are the female connectors for? I thought ESCs had all the wires.
Build Log Cessna 180 - Rubber powered, cardboard and paper construction knlever Free Flight 93 Apr 29, 2014 07:44 AM
Discussion Need help with plans and resources!! A plane powered by cardboard jonathan8388 Free Flight 2 Jun 01, 2008 05:33 PM
Question Cardboard elevon plane?? hot glue Foamies (Scratchbuilt) 21 Feb 02, 2008 07:41 AM
Help! Cardboard elevon plane hot glue Foamies (Scratchbuilt) 5 Jul 27, 2007 09:28 AM
Question Cardboard PLanes xlzerolx Fuel Plane Talk 2 Aug 13, 2002 05:34 PM
