Old Feb 17, 2004, 10:35 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
The Ultimate Slow Stick Help Thread - Part 3
It's time for a part 3
The others can be found here:
Part 1: http://www.rcgroups.com/forums/showt...hreadid=122951
Part 2: http://www.rcgroups.com/forums/showt...15#post1502315
Carry on
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Feb 17, 2004, 11:59 AM
Ron H is offline
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Wow this thread is still going strong. My SS is flying fantastic with a rewound 400!. See threadEasy way to strenghthen your wing
Ron H is offline Find More Posts by Ron H
Old Feb 17, 2004, 12:45 PM
wallasan10 is offline
Find More Posts by wallasan10
wallasan10's Avatar
United States of Texas
Joined Dec 2001
Got a chanch to try out my SS without the littlebirdz mortor mount when my prop hit the ground as I was doing touch and goes and it came apart.
I was able to glue it back together, J-B Weld this time, and while that was setting up I flew my plane without it for tha first time.
The Slow Stick is MUCH better with the littlebirdz mount than without it! With it, there is almost no trim change from full throttle to throttle off. Without it the plane seems to be all over the place.
My guess is that you could do much the same thing by bending the fuse. but the mount is may save you a gearbox.
Anyway, I like it. A nice product.
Allons, Randy
wallasan10 is offline Find More Posts by wallasan10
Old Feb 17, 2004, 01:40 PM
rmasonjr is offline
Find More Posts by rmasonjr
<burp>
rmasonjr's Avatar
Brookhaven, Mississippi, United States
Joined Mar 2002
I just got through printing and reading the other 2 threads. I printed 2 pages on a single printed sheet and it took me 2 weeks - great info, though!
rmasonjr is offline Find More Posts by rmasonjr
Old Feb 17, 2004, 03:45 PM
Renegade-I is offline
Find More Posts by Renegade-I
Magna, UT
Joined Jan 2004
Question on the SS:
Has anyone had to move their battery in front of the wing mount for proper CG?
Renegade-I is offline Find More Posts by Renegade-I
Old Feb 17, 2004, 04:15 PM
darrell_f is offline
Find More Posts by darrell_f
darrell_f's Avatar
United States, FL, Melbourne Beach
Joined Dec 2003
yes, no problem
It was tail heavy and gear was too far back with battery pack under wing. This works very well. I have a battery 'tray' with velcro. In front of wing actually makes it easier to change packs also.
darrell_f is offline Find More Posts by darrell_f
Old Feb 17, 2004, 04:58 PM
Magna, UT
Joined Jan 2004
Thats exactly what I was experiencing.
I am using the GWS 7.2v 400mah battery, woul dthat make a difference?
Old Feb 17, 2004, 05:29 PM
Karl Bē is offline
Find More Posts by Karl Bē
29 rods from you in western WI
Karl Bē's Avatar
Joined Jan 2003
Originally posted by Renegade-I
Question on the SS:
I have a battery forward of the wing, with HS-81 servos well aft of the wing to compensate. This clears up the fuse at the CG for attaching an aerial camera.
In general, placing weight as close to the CG as possible makes for a more maneuverable craft, and weight towards the tail, nose, and wingtips reduces responsiveness. This is actually not a bad thing for aerial photography.
Wing shown was an experiment with spoileron roll control and zero dihedral. Spoileron operation with only one servo gave vague roll control.
Karl Bē is offline Find More Posts by Karl Bē
Old Feb 17, 2004, 08:18 PM
Magna, UT
Joined Jan 2004
That looks good. From the looks of it did you mount the battery sidewise?
Old Feb 17, 2004, 08:36 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
I take a different approach. I balance the plane without the battery and then everything I put at the CG... battery (any size or mixed) AP camera, bomb drop, parachute drop , etc. or any combo! Never a worry if it will balance! Pic shows battery mount and camera/bomb drop/parachute mount on side
boomer
boomerace is offline Find More Posts by boomerace
Old Feb 17, 2004, 09:03 PM
Magna, UT
Joined Jan 2004
Boomer,
How close/far does that put you to the front?
Old Feb 17, 2004, 09:13 PM
Karl Bē is offline
Karl Bē's Avatar
Joined Jan 2003
Yes. I clipped the pushrod guides off two TE brackets. Velcro straps hold it in place between the rubberband posts. No problem with it slipping sideways.
The heavy battery (7 oz) made inline mounting a problem if I wanted it fully in front of the gear.
Down for maintenance, here it is sans stick:
Old Feb 17, 2004, 09:57 PM
boomerace's Avatar
Joined Sep 2001
Boomer,
My present MP Jet brushless setup is 7-1/2" from front of motor to front of wing! Flys fantastic!
boomer
Old Feb 17, 2004, 11:50 PM
aeropenguin is offline
Find More Posts by aeropenguin
Who Says Penguins Can't Fly?
aeropenguin's Avatar
Bay Area, California
Joined Jan 2003
Interesting variation, Karl. I just have the battery on velcro. Take a rectangular piece of plywood, and cut it the length of the battery pack, the width of one velcro strip. Epoxy onto the battery holders and viola. With a thrust mount moving the motor farther up, balancing isn't much of a problem anymore so you can get away with it that far back.
-Michael
aeropenguin is offline Find More Posts by aeropenguin
Old Feb 18, 2004, 08:42 PM
Karl Bē is offline
Karl Bē's Avatar
Joined Jan 2003
Michael, did you epoxy a plate to the battery holder for a horizontal mount, or inline? Where are you placing your battery?
I tried several configurations to get the battery forward of the wing/landing gear, all assuming a 2.2 oz Nippy Black 1812/100 mounted axially at the front, bolted to a GWS gearbox (picture). With the battery inline (maybe 5" long), there was no way to balance since the wing was pushed back to make room for the battery. I was able to balance with an 8" fuse extension, resulting in a longer tail with the servos on wire extensions as well, but I didn't like the long length. Too easy to slam in car doors, run into walls, etc. My wing is about 2" aft of the front of the stick. Lots of room for all manner of camera mounting options without the battery getting in the way.
Anyone run a more-or-less stock plane with zero incidence, ie. using two LE brackets or two TE brackets?
The Ultimate Slow Stick Help Thread Part 7 boomerace Beginner Training Area (Aircraft-Electric) 517 Apr 27, 2005 12:04 PM
The Ultimate Slow Stick Help Thread - Part 6 Ron H Beginner Training Area (Aircraft-Electric) 544 Feb 16, 2005 09:59 AM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 08:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
