Old Feb 17, 2004, 09:19 AM
t-turley is offline
Find More Posts by t-turley
Joined Mar 2001
LRK and other larger homemade brushless motors
This thread is for those who wish to post results from their experiments with building LRK and other brushless motors larger and/or different than the "standard" CD-ROM motors. I know there are several people on E-Zone who have mentioned - at least in passing - that they are working with mini-LRKs, VCR, FD, and other "unconventional" motors. So let's hear it, folks!
I'll start with this motor that many of you will recognize from the "One hour CD-ROM" thread. It began life as an unknown brand stepper motor. It had a heavy, rubber magnet ring, and all 24 poles were wound with 120+ winds of a very fine wire. I originally wound it with 18T of #20, as you see in the photo, and set it up with 14 magnet poles NN SS NN, etc. It didn't run, but only chattered and whined. Ron van Sommeren and his German friends correctly diagnosed my problem as being the magnet poles, which were covering more than one stator pole simultaneously, causing the motor to work against itself. I reconfigured the magnets (5x5x2 mm each) to 28 individual poles, and the motor ran. The winding was too hot, though, and it drew 5.5A no-load, so I rewound it last night with 22T of dual-strand #24, which packed a lot more wire onto the stator poles. I'll try it this evening when I get home, and post my results.
As you can see, the windings on this one are different than the standard CD-ROM rewind. The winding pattern is ABCabcABCabc, where ABC poles are wound CW, and abc poles are wound CCW. The speed of the motor is definitely slower, so I'm hoping it will swing a fairly large prop of 10-11". I just need to come up with a prop adapter; the shaft is 3.3 mm, and I had to grind it down to fit the 3x6 mm bearings - a nasty chore, at best.
Tony Turley
t-turley is offline Find More Posts by t-turley
Old Feb 17, 2004, 09:36 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
The other problem, apart from the magnet versus tooth size, was that for an 24 statorpole lrk motor you have to have 20, 22, 26 or 28 magnetpoles, not the original 14. !4 (or 10) magnets for 12 teeth lrk stators.
A better way to describe the winding pattern would be
A-B-C-a-b-c-A-B-C-a-b-c-
Where the '-' denotes an empty tooth.
Since you stator is not very heigh, it could be advantageous if you used the distributed lrk winding pattern, lower resistance, slighty higher Kv:
AaBbCcaAbBcCAaBbCcaAbBcC
Neighbouring teeth in one phase or wound the opposite way.
Groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Feb 17, 2004, 09:55 AM
Joined Feb 2001
lrk formulae:
http://groups.yahoo.com/group/lrk-torquemax/message/574
http://groups.yahoo.com/group/lrk-torquemax/message/761
Met vriendelijke groet Ron van Sommeren
diy brushless e-motor homebuilders discussion.
Old Feb 17, 2004, 10:23 AM
Sp@nky is offline
Find More Posts by Sp@nky
Joined Nov 2003
Re: LRK and other larger homemade brushless motors
Tony Turley
I just finished drawing up the "same" motor, I'm looking for a lower Kv, just like you, to turn a larger prop. I am axiously waiting for your post rewind results ...
Sp@nky is offline Find More Posts by Sp@nky
Old Feb 17, 2004, 11:15 AM
myk is offline
myk
Find More Posts by myk
myk
myk's Avatar
Lake Sawyer, Washington
Joined Jul 2003
Here's mine, that I completed several months ago, it is basically a clone of the torcman motors, using the typical naming convention it would be a LRK 360-21-16 (36.0mm stator dia, 21mm stator length and 16 winds). Swings a 16x8 APC-e direct drive at roughly 6000rpm Pin is around 650W, Amps around 45+ static, batts are 4S2P Tanic 2200's, Castle Creations Phoenix 60, 16 winds of 18ga magnet wire, 5mm drill rod for the shaft, bearing are out of old harddrive. Truly an amazing motor to fly, so quiet and powerful.
Here's a link to the plane its in:
http://www.rcgroups.com/forums/showt...hreadid=169750
If you go on Ron's torquemax Yahoo group http://groups.yahoo.com/group/lrk-torquemax/ I have a photo folder with lots of pictures under the name mykarmstrong.
myk is offline Find More Posts by myk
Old Feb 17, 2004, 11:17 AM
myk is offline
myk
myk
myk's Avatar
Joined Jul 2003
One more...
Old Feb 17, 2004, 11:20 AM
myk is offline
myk
myk
myk's Avatar
Joined Jul 2003
Last one.
Old Feb 17, 2004, 11:53 AM
niels polfliet is offline
Find More Posts by niels polfliet
cd brushless motors rule!
niels polfliet's Avatar
Sint-Gillis-Waas, Belgium
Joined Nov 2002
Hi Tony!
Very nice motor, looks a lot like mine, except mine has 15 poles...
It works as a direct drive helimotor in a micro heli. It's really great, no gear noice.
I've been searching all over for 24 pole of 12 pole stators, i would like to try a big diameter lrk in it, to shave some weight of maybe. Where did you find yours? I'd love to try LRK..
Mine's from a 3.5" floppy disk drive. Actually its a mix, the bell comes from another motor.
here are some pics of it mounted in the heli;
a pic to prove it flies
more here; http://www.rcgroups.com/forums/showt...hreadid=197862
Niels
niels polfliet is offline Find More Posts by niels polfliet
Old Feb 17, 2004, 12:59 PM
t-turley is offline
Joined Mar 2001
Niels,
I don't know the source of the motor. A friend of mine knows that I like messing with homemade outrunners, so he gave me a box of old drives and motors. This motor had already been pulled from whatever device it was in. That's a great job you did with your motor.
Mike,
That is a great looking motor. Where did you get that stack of statorplates? I'd like to find a stator or statorplates with a 23 mm diameter. I did find an old Syquest cartridge drive that had a 23 mm stator, but the stack was only about 3 mm thick.
Tony Turley
PS: I'm hoping to get a mini lathe this summer, and begin some custom work.
Old Feb 17, 2004, 01:25 PM
myk is offline
myk
myk
myk's Avatar
Joined Jul 2003
Tony Turley
Thanks Tony, I got the stator material from an old palm sander I had laying around. Alot of hand powertools that run on AC have 12 pole stators, I even looked at some new cheap sanders at sears for $19.00 that would make good donors. The only drawback is that the laminations are fairly thick which somewhat reduces the efficiency of the motor (eddy durrent losses) but I am totally satisfied with mine, it really goes like a bat out of you know what So go raid the shop, mommas kitchen (mixers, blenders, etc), local junk yard, electrical repair shops, you'll find a bunch of sources. Good Luck
Good looking heli motors guys, that is awesome a direct drive heli, never though I'd see that.
Old Feb 17, 2004, 03:26 PM
hrvojekl is offline
Find More Posts by hrvojekl
hrvojekl's Avatar
Zagreb, Croatia
Joined Sep 2002
Tony,
Take a look at www.batt-mann.de
they have 23 mm stator plates (22.8 actualy)
Hrvoje
hrvojekl is offline Find More Posts by hrvojekl
Old Feb 17, 2004, 05:48 PM
t-turley is offline
Joined Mar 2001
Thanks Hrvoje. For you or anyone else that speaks German, I have a few questions about that site. A screen capture follows. What does "paketlange" mean? Alta Vista translated it as "package for a long time", but I really doubt that is accurate, considering a dimension in mm is given. Also, what is "Elektroblech M270-50A"? And finally, I assume the prices on the right side are given in Euros?
Tony Turley
Old Feb 17, 2004, 05:56 PM
t-turley is offline
Joined Mar 2001
Here are the promised results from my testing of the rewound LRK this evening. With 22T of dual-strand #24, the no-load current dropped to about 3A. With the 10x7 APC SF shown, it drew 9A from a 7-cell 600AE NiCd, but only turned the prop at 2600 rpm!! I took that measurement several times, to be sure. What next, guys? I doubt that 2600 rpm would do more than drag an airplane down the runway. I'd like to get the rpms up without drastically raising the current.
Tony Turley
PS: the line you see through the cooling hole was made by a Sharpie marker, when I was attempting to get the no-load rpms. It didn't work.
PS PS: Hey Ron, I looked at those links you posted above. Peter's 68.5 mm 24-pole motor sounds like it is a real stump puller. 60A & 1450W!! I'd like to limit mine to 15A or so, all the while getting around 5000 rpm or so on the prop.
Tony
Old Feb 17, 2004, 06:00 PM
t-turley is offline
Joined Mar 2001
Back side:
Old Feb 17, 2004, 06:59 PM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
mike, can you give some more detail about how the bell is attached to the shaft? also, I am working on a 50mm stator diameter, 12 pole motor... current stator height is 12.5mm, but I can double it up and make it 25mm (use two stators) by remaking the bell. I know not to exceed 2/3 length/stator diameter ratio, and that the same wiinds will turn faster on the double thick stator... but if I wind twice the winds on the thicker (using thinner wire), how will it compare to half the winds (with thicker wire) on the thinner stator? other than be able to absorb more heat, what would be the effect?
tony, how about testing with a popsicle stick for no-load rpms, and a larger prop or two fo some more data points? I'm guessing you're going to need fewer winds, for 12-pole I'd guess 10-14 for 8-cell, but for a 24-pole I'd guess much less...
opualuan is offline Find More Posts by opualuan
LRK and other larger homemade brushless motors, part II Ron van Sommeren Power Systems 13 Jul 19, 2005 04:18 PM
LRK and other larger homemade brushless motors: Part 2 Mr DIY Power Systems 156 Jan 03, 2005 10:48 AM
"Effecient homemade brushless motors Show Case" jlm0924 Power Systems 1 Jul 13, 2004 07:31 PM
larger homemade brushless t-turley Power Systems 10 Jan 04, 2004 01:44 PM
FW Ta 400, 4.35m, six lrk-torquemax diy homebuilt brushless motors Ron van Sommeren Scale Kit/Scratch Built 0 Jan 13, 2002 02:52 PM
