Old Sep 26, 2013, 09:20 PM
Zero UAV is offline
Find More Posts by Zero UAV
Joined May 2012
Zero UAV Gemini Autopilot[OwnersThread] *Dual Redundancy Autopilot for Multi-Rotors*
Aerial photography industry is full of risks and challenges, and everything is nothing if there is no security. The Gemini autopilot, developed by Zero UAV and particularly designed for professional advertising, film and television etc., is the first double redundancy multi-rotor flight controller in the field of uav. Meanwhile it is quite a reliable autopilot provided by Zero for ensuring standardized security code of aerial photography.
Gemini autopilot consists of two independent sets of GPS, compass and IMU. What's more, users may monitor the working status of the two sets of sensors at the same time through GCS (ground control station) . In addition, if any sensor has error, it may automatically seamlessly switch to another sensor and give automatic alarm to users via GCS, which greatly reduces the possibility of crash or failure. Besides, users can freely choose any of the GPS or compass to combine with the IMU of another unit.
Welcome to contact with us for more details or on any questions:
Technical Support: support@zerouav.com
information: distributor@zerouav.com
Website: www.zerouav.com
Featured Functions:
1 Gemini goes for the flying security to the extreme by integrating with double GPS, IMU and compass. When a failure occurs, the master controller can automatically switch to the slave controller and the GCS will give alarm to users at the same time.
2 It is perfectly compatible with the safety parachute. Controlled by the Gemini autopilot, the parachute will be opened automatically and the motors will stop spinning in emergency to protect the entire system.
3 Intelligent course lock function contains automatic dodging landing gear feature which saves the trouble of using retractable landing gear.
4 Users can preset up to 256 available waypoints. By pushing transmitter softly, the craft may fly according to the 3D waypoints preset based on the 3D coordinates of each point , and the flying speed is controlled by the sticks in real time, so that it is very easy to repeat the skyline of film shots.
4 High stable FPV mode of Gemini autopilot makes a new pattern of cooperating of gimbal and craft , first invents that the craft can follow up the gimbal automatically and the gimbal may be directly controlled by the transmitter, the lens control is more smooth compared with the previous FPV mode.
5 What's more, ZERO brushless gimbal such as Z2000(5D),Z1400(GH3), BMPCC gimbal, Z6000(RED EPIC) etc. can perfectly work with Gemini autopilot to get high-precision attitude correction and achieve impressive film shot. What's more, in pursuit of the extreme security performance, both of the ready to fly system E1100 and E-EPIC for professional aerial photography are integrated with Gemini autopilot to get more security flying.
6 With 3D map in your ground control station, you can manage your flight over the sky like never before. Gone are the days when the only way to get a bird's eye view of your favorite place was on the horizon or from the window of the apartment. Now, Get started with your phone or tablet to enjoy your notably security flying!
GEMINI Autopilot ---Tibet LakeNam
YS-GEMINI---Tibet LakeNam (6 min 43 sec)
GEMINI Autopilot---Tibet YangHu
YS-GEMINI Tibet YangHu (5 min 44 sec)
Zero UAV is offline Find More Posts by Zero UAV
Old Sep 26, 2013, 09:23 PM
Zero UAV is offline
Joined May 2012
Here are some detailed technical description of Gmini Industrial Multi-rotor Autopilot (Double Redundancy FC) which may make the characteristics more clear :
1:Why we need Double Redundancy FC :
In order to improve the reliability of flight control, ensure the safety of aircraft and camera, especially the safety of people.
2:Why Double Redundancy FC safer:
According to the probability theory, suppose the?failure?probability?of? a?system is 1/100, so the probability of two systems failure at the same time is 1/10000. Meanwhile, according to the previous reliable data statistics,the eletronics of autopilot below are easier to fail (failure rate decreasing):
1 compass
2 GPS
3 gyro etc. inertial sensor
4 processor and power
5 loose connections
Among the factors above, the possibility of failure or data error of compass, GPS and sensor is higher. Copter would mulfunction once the sensor fails. Nowadays, most of the compass, gps and sensors of multirotors are similiar to even the same as the eletronics of mobile phone (such as HMC5883L in compass, ublox or NVS module in GPS), and the manuals of those eletronics have no specification whether the eletronics can be used to aviation application. However, Gemini autopilot could tell out the problems and switch to the spare sensor to pretect the copter if the sensor has failure which greatly reduces the crash possibilities caused by autopilot.
3 How does the Gemini autopilot tell out the error?
  Gemini autopilot would auto check and compare the two sensors when it is booted before flying, and make alarm to users by GCS, even lock motors if the error is beyond limited range.
  During flying, gmini autopilot would process and fuse the data of sensor and estimate the failure through Extend Kalman Filter algorithm. Besides, if the sensor has abnormal drifting, Gemini could tell out the error and switch to the spare sensor very fast by calculating previous flying status and estmating current sensor data.
The dual backup failure distinguish algorithm have been through rigorous design, simulation and actual flying test, which has the characteristics of accuracy, quickness, safety and practicality. To prove this, you can have a try: anytime when you get the mobilephone close to the GPS/compass, and interfere any of the autopilot compass using the magnet inside phone speaker, or anytime when you cut off any GPS or the connections of Gemini Slave, you will see the accurate failure prompt, failure distinguish and auto switch from the GCS.
Old Sep 26, 2013, 09:45 PM
King Multirotor is offline
Find More Posts by King Multirotor
Joined Aug 2013
Looks attractive, are these two components Gemini M & Gemini S working at the same time?
King Multirotor is offline Find More Posts by King Multirotor
Old Sep 26, 2013, 09:56 PM
Zero UAV is offline
Joined May 2012
When you boot the FC, both of the two sets work at the same time, and after they works, the control will be mastered by the one which works better.
Old Sep 26, 2013, 10:14 PM
david157 is offline
Find More Posts by david157
Joined Jun 2013
Sounds good, how' the price?
david157 is offline Find More Posts by david157
Reply With Quote  (Disabled)
Old Sep 26, 2013, 10:18 PM
Joined Aug 2013
Brilliant! In this case if the master one fails, can the other one switch to work instead automatically? And how does the safety parachute work? Sorry for the questions, but it is really great work and very interesting
Great Thanks
Old Sep 27, 2013, 07:24 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
More Information will be attached......
Looking forward to seeing the full specifications.
robone is offline Find More Posts by robone
Old Sep 28, 2013, 08:55 PM
Multirotorr is offline
Find More Posts by Multirotorr
United States, KS, Alden
Joined Dec 2012
Great Thanks
Yes, the two sets autopilot are independent and connected.
About the parachute control, that is Gemini Autopilot may auto-check the rollover of the craft, it will output parachute-opening signal to enable the parachute when the rollover of the craft is over 70 degree. In auto mode, the motor may stop spinning.
Multirotorr is offline Find More Posts by Multirotorr
Old Sep 29, 2013, 03:28 AM
Zero UAV is offline
Joined May 2012
The specifications will be released on website soon.
Old Sep 29, 2013, 04:28 AM
Thegn is offline
Find More Posts by Thegn
Joined Jul 2011
Good! But don't forget you other products... Seems like the YS-X4 has been forgotten, since the other products have gotten a September firmware, but not the YS-X4?
Thegn is offline Find More Posts by Thegn
Old Sep 29, 2013, 05:07 AM
Joined Dec 2012
i think all of the products are updated, the YS-X4 firmware is the September version
Old Sep 29, 2013, 08:27 PM
WTT is offline
WTT
Find More Posts by WTT
WTT
Zero UAV
Joined Dec 2012
Great Thanks
Zero parachute can be controlled by Tx. Here is a video:
http://www.tudou.com/programs/view/HjEUTy18TPc/
WTT is offline Find More Posts by WTT
Site Sponsor
Old Oct 07, 2013, 07:45 PM
hyccrr is offline
Find More Posts by hyccrr
Joined Sep 2013
is this double redundancy FC released already?
hyccrr is offline Find More Posts by hyccrr
Old Oct 10, 2013, 09:08 PM
Zero UAV is offline
Joined May 2012
This is just the spy, it will be officially released later. Welcome customers to have practical test!
Old Oct 11, 2013, 02:59 PM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
Imho the set of 2 controllers is surplussed and looks like the attempt to sell 2 controllers at one time
Of course, its more easy to have minimum changes in existing system, but if you really want to have compact and reliable system, its much better to have 2 independent boards in one case.
DVE is offline Find More Posts by DVE
New Product Zero UAV YS-X6 [Owners Thread] *Autopilot system for multirotors* Zero UAV Multirotor Electronics 2444 May 05, 2016 02:45 AM
New Product Zero UAV YS-X4 [Owners Thread] *Autopilot System for Multi-Rotors* Zero UAV Multirotor Electronics 2793 Apr 12, 2016 03:38 AM
Video Instruction Video List for DJI Systems Related to Multi-rotor DJI INNOVATIONS Multirotor Talk 1 Mar 01, 2013 01:13 PM
Video Instruction Video List for DJI Aerial Photography Multi-Rotor Systems DJI INNOVATIONS Aerial Photography 0 Mar 01, 2013 05:45 AM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 10:51 PM
