Old Feb 17, 2004, 08:40 AM
KreAture is offline
Find More Posts by KreAture
Impossible? Hah!
KreAture's Avatar
Oslo Fornebu, Norway
Joined Jun 2003
BLDC controller
Well, I wanna be the one to start up the new thread in the DIY forums
To iterate, here's the old thread:
http://www.rcgroups.com/forums/showt...hreadid=181247
I won't repost any of the old stuff, let's get new stuff in!
I am planning to make a prototype circuit with a programmer buildt in for easy re-flashing now. It will only be the basic module and not have any motor peripherals. I was thinking of using a pinheader and linking it to the FET-board so that I may do changes on the design more quickly.
I will be experimenting with heavy filtering of the EMF signal with rpm-based table-correction of the signal phase. This should make it possible to design a very high commutation-rate controller without the need for fast ADC.
KreAture is offline Find More Posts by KreAture
Old Feb 18, 2004, 12:41 AM
Mr DIY is offline
Find More Posts by Mr DIY
Mr DIY's Avatar
South Africa
Joined Aug 2003
So Kreature, what have you done so far? Have you managed to breadboard any circuitry yet? I am more than a little curious to see how your idea is going to work.
Brian
Mr DIY is offline Find More Posts by Mr DIY
Old Feb 18, 2004, 06:35 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
I have simulated the filter to stry and eliminate as much phase delay as possible. The best I got so far was 3 deg predictable phase shift spread over the last 7-10.000 rpm. (Was targeting 10.000 rpm max on 12 magnet motor. = 6000 commutations / second.)
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Oh, and I don't breadboard. I etch and smt. Faster and neater.
Old Feb 18, 2004, 07:00 AM
Mr DIY is offline
Mr DIY's Avatar
South Africa
Joined Aug 2003
I do the same... however it was meant more as a figure of speech as in ...have you put anything in hardware yet. You answered anyway
Old Feb 19, 2004, 04:18 PM
whanderson is offline
Find More Posts by whanderson
Baltimore Bwi Rr Stn, Maryland, United States
Joined Oct 2003
Re: BLDC controller
I have received my BLDC PCBs and will start populating the bord in a few days. I use the Microchip ICD2 for in curcuit programming. This eliminates the need for a programmer on the BLDC and allows debugging in the actual target application. I am starting with AN857 and hope to move to dsPICs when they are available.
whanderson is offline Find More Posts by whanderson
Old Feb 19, 2004, 04:32 PM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
Cool. I am currently redesigning my regular ESC. Making it more robust. (Removing a bit more noise from the system and getting the LVC working right. It will provide a platform for my brushless version.
Old Feb 20, 2004, 12:56 AM
Mr DIY is offline
Mr DIY's Avatar
South Africa
Joined Aug 2003
Well seeing we are giving current status reports, I am currently adding in/testing all that laborious software that does all the start up checks.. like look for correct PWM sequence from Rx, Battery voltage / FET driver voltage checks, Low voltage cut off, arming sequences/user programming ect.
My latest PCB is almost fully populated .. just needs the FET drivers and FPGA device. Still awaiting the FETs I ordered though.
Mr Takao.
I ran some tests on the ADC module and over-clocked it progressively up to 2MHz while watching the stream of samples sent to my PC. Samples where within 1 bit resolution for an 8-bit sample on a RX PWM generated voltage. Not bad for device that is clocked 10 times faster than the specified spec. I am yet to try the 4MHz clock as you have done, but I am more than happy with the 6 odd uS conversion time I am getting. It has allowed me to totally rethink how I am doing some routines.
Brian
Old Feb 21, 2004, 11:00 AM
MAVA is offline
Find More Posts by MAVA
MAVA's Avatar
El Dorado Hills, California, U.S.A.
Joined Mar 2000
Kreature
Here is somthing that may help you with the journey of the DIY Brushless Controller.
Microchip application note AN857
http://www.microchip.com/1010/suppdo...n857/index.htm
Link to all the Motor application notes.
http://www.microchip.com/1010/suppdo...ntes/index.htm
Martin
MAVA is offline Find More Posts by MAVA
Old Feb 21, 2004, 08:55 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
I had looked at AN587, and was really curious about the sensorless design they show. Most other designs sense all three phases, but their sensorless design has input from only one phase . If the motor is running at a fairly constant speed, this should be fine and save a few components. I would wonder however, how well it would handle startup or rapid speed changes.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Feb 21, 2004, 10:11 PM
Joined Oct 2003
Jeff
I am in the process of building AN857. I will let you know how it works.
Old Feb 22, 2004, 10:18 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
MAVA
I've read all their appnotes before, as well as all ST and Motorola notes. The challenge is not to get it to work. I know a lot of how it should and can be done. I am simply trying to get it done with a more elegant solution.
Old Mar 01, 2004, 01:18 AM
Mr DIY is offline
Mr DIY's Avatar
South Africa
Joined Aug 2003
Hmm ... all is quiet here. Anybody make progress?
I myself, waiting for last 2 of my outstanding components, the low drop regulator and most importantly, FETs. Should have them this week.
Old Mar 01, 2004, 06:34 AM
KreAture is offline
Impossible? Hah!
KreAture's Avatar
Joined Jun 2003
I had great success with the new regulator I tested. 1.15v drop 1 Amp. Should suffice. Now to make a new prototype with ICSP header...
Old Mar 01, 2004, 08:07 AM
Mr DIY is offline
Mr DIY's Avatar
South Africa
Joined Aug 2003
Takao write - previous thread
I had found one interesting chip.
http://www.silabs.com/products/micr...xsig_matrix.asp
The development tool is $99!
Ooh! nice 8051 based micros. Very similar to the Analog Devices ADuc812 range. I have a few of the AD devices left, but found them very expensive when compared to the Mega 8. The thing that they have, as do the devices listed above, are the 12 bit DACs. They come in very usefull. Any clues as to cost Takao?
Help! Output Waveform Of Reciever And The Bldc Controller CLEMENT DIY Electronics 4 Feb 01, 2010 08:08 AM
Discussion BLC-40 Thunder Tiger(ACE) BLDC controller Shread Power Systems 0 Mar 31, 2007 07:25 AM
BLDC controller advice needed Foxy DIY Electronics 13 Jul 10, 2004 07:37 AM
