Old Sep 25, 2013, 11:50 AM
flyingtxnewb is offline
Find More Posts by flyingtxnewb
United States, TX, Plano
Joined Jun 2013
FMS (RocHobby) Swift??
Its sold by MotionRC. Has anyone used it??? didn't find it with the search
http://www.motionrc.com/rochobby-swi...-wingspan-pnp/
flyingtxnewb is offline Find More Posts by flyingtxnewb
Old Sep 30, 2013, 10:59 AM
Joined Jun 2013
really? no one?
Old Oct 05, 2013, 08:31 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
i just got one, built it today. pretty freakin excited to go fly it !!
KCinNC is offline Find More Posts by KCinNC
Old Oct 05, 2013, 09:34 PM
Joined Jun 2013
Great!!!!! please report back!!
Old Oct 05, 2013, 09:55 PM
KCinNC is offline
Joined Aug 2007
due to rain moving in, going to be maybe Tues/Wed before i can fly it. everything on it is nice quality...i did add some carbon fiber rod to the vertical stabilizers just for added support
Old Oct 08, 2013, 06:02 PM
Joined Jun 2013
Cool!!!!! looking forward to your comments
Old Oct 10, 2013, 02:19 AM
rainy xiao is offline
Find More Posts by rainy xiao
Joined Aug 2013
really nice plane,want to buy such kinds plane....
rainy xiao is offline Find More Posts by rainy xiao
Old Oct 10, 2013, 11:12 AM
eddyalce is offline
Find More Posts by eddyalce
United States, GA, Atlanta
Joined Apr 2013
How did it fly?? Debating between getting this plane or the Parkzone F-27Q Stryker
eddyalce is offline Find More Posts by eddyalce
Old Oct 11, 2013, 06:42 PM
KCinNC is offline
Joined Aug 2007
had to go out of town for work..... "HOPEFULLY" going to get to fly it tomorrow.. weather is gonna be awesome
Old Oct 12, 2013, 10:13 AM
Joined Jun 2013
good luck!!!
Old Oct 13, 2013, 07:28 AM
tracernz is offline
Find More Posts by tracernz
New Zealand, Canterbury, Christchurch
Joined Jun 2013
I also have one. It's plenty of fun to throw around, the light wing loading means you can pretty much stop it on a dime. The only real weaknesses I've found is the foam is very thin:
a) in the hand grips, you can actually see through it in the corners
b) Where the motor mount and the plastic bit on the bottom of the tail attach, this means the motor mount will break out if you land hard on the tail.
Also, the ailerons aren't well attached. I'm going to have to do something with mine as they've both come off and tape isn't good enough for the tiny throws this thing needs.
Stealing KCinNCs pic:
tracernz is offline Find More Posts by tracernz
Old Oct 15, 2013, 03:01 PM
huntingfield is offline
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
I just ordered one of these from Motion RC. I got the tamer version . I have bought several items from Motion RC and have been very pleased with them. Its too bad about the hinges giving in, have you come up with a solution yet? I have the funfly Rare Bear from Hobbyking and it is a very small and fast plane (insane on 4 cells). Has anyone flown both of these and how do they compare?
huntingfield is offline Find More Posts by huntingfield
Old Oct 16, 2013, 05:10 PM
KCinNC is offline
Joined Aug 2007
well i've tried in vain to get mine to fly. seems like it is extremely nose heavy with a 2200 3s...even the cg seemed dead on. even with a 1300 3s it would just not take off. wide open throttle...throwing as hard as i can
big ol fat nose dive every time
Old Oct 16, 2013, 07:37 PM
Joined Jun 2013
Maybe silly question but you sure the prop is installed correctly? Check orientation
Old Oct 17, 2013, 11:44 PM
tracernz is offline
Joined Jun 2013
I've found a 3S 2200 flies nicely when positioned as far towards the back as it will go. That should give a CG close to the measurement given in the manual. I've even flown a 4S 2200 but it didn't really fit too well and I didn't feel it was that much faster. I usually takeoff with about 2/3 throttle and a good throw, any more throttle and the torque is too much and it rolls over and dives into the ground.
Yeah, they're probably fine until you have a rough landing and then they're done as they're just a bit of tape basically. I'm going to use some CA hinges to replace them: http://www.hobbyking.com/hobbyking/s...0mmx0_3mm.html
Yippee! FMS RocHobby 1100mm Strega Reno Racer ryramZ Electric Warbirds 4062 Today 05:50 PM
New Product RocHobby/FMS Critical Mass Sea Fury! 1100mm merlinfan Electric Warbirds 2592 Apr 30, 2016 11:45 AM
New Product RocHobby/FMS F-16 Diesel6401 Foamy EDFs 376 Mar 24, 2016 11:46 AM
Discussion RocHobby by FMS ryramZ Vendor Talk 4 Dec 18, 2012 09:48 PM
