Multiplex EasyStar thread - Part 2
Following the success of Jurgens thread on the new Multiplex EasyStar, this is the MK2 version!
The original thread left off here; http://www.rcgroups.com/forums/showt...92#post1840592 Tim Hooper |
What did I start here?
![]() The threads of the Terry and Tipsy are also very long, but the EasyStar is even better suited for a novice than the Tipsy and still doesn't get too boring for others. If I can fly the EasyStar Indoors, the rudder must be big enough. Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
Joined Nov 2001
I was thinking about the Terry/Tipsy...but went with the EasyStar after all the good things that everyone says about the stuff it is made out of. I also like the idea that I can fly it in a little bit of wind. I have a Tiger Moth and love it, fly it up high and cut the power and cost around...that is just so nice. It sounds like this plane was made for that kind of flying.
Me Too...
I have read several pages of Jurgen's original post, and was impressed with what people had to say.
My father-in-law is a plane enthusiast, and was what got me interested in the hobby. I originally went flying with him a couple of times, where he would let me train using the buddy box. Then, we got started using some simulation software. I finally decided on getting a GWS Zero for my first plane...I didn't really know what I was getting into. Anyway, the maiden voyage left little to be desired, and months later, trying to get a drive shaft, we were finally successful. Anyway, it's back together now, however, after the recommendation from my father-in-law, I started reading information on the EasyStar, which is where I found this thread... I ordered mine yesterday as well as another poster did. Here's the equipment list. EasyStar ARF (of course) Hitec HS-81 servos (2) Jeti JES-020 ESC Hecell 1100 NiMH 8.4V 7-Cell Folded Pack HE-1100-BL07P Deans Ultra Plugs for battery and motor connections I'm using an old radio that was given to me that has a 6 channel Mini Rx and a 4 channel Tx. Any ideas on if this will be a good combination? Which batteries are better, KAN or the Hecell? I noticed both were about the same price, however, the KAN's seemed to be rated slightly lower in mAH. Any pointers for building/flying for the first time? |
Joined Jul 2002
Your equipment list looks fine. Just range check your TX and RX.
1) I have used velcro on the canopy, because the clips wore out pretty quickly. 2) Put the elevator and rudder wires on the inner most holes on the control horns. You want to have max throws for the rudder. 3) Put packing tape on the on the bottom of the fuse and around the nose. 4) Consider putting packing tape where the wing contacts the ground at rest. This is the area where the wing tips curve up and tends to get worn/scuffed during landings. 5) Don't glue in the antenna tube as the instructiosn say. If you have to replace the reciever it's tough to remove. Just hold it in with the packing tape you run the entire length of the fuse. 6) Might want to consider using connectors for the wiring at the motor and not gluing it in place. This will make it easier if you want to remove it or play around with other motor seups. 7) Launching the plane needs very little up elevator. It hand launchs very easily. Seems to like a little nose down when trimmed out, more so than most trainers in my opinion. 8) The plane builds very quickly. 9) It soars and thermals surprisingly well. 10) Have fun
Everything sounds good, except a little explaining on 6.
So the instructions tell you to glue the motor into the plane? What is a better way to attach it, so as to make it easier if you want to remove it some day? I was planning on using connectors on the motor side, so that will not be a problem. Is there any place to download the instructions to building the EasyStar? It will be a few days before mine gets here, and just thought I might read them over. Thanks. |
Wayne, NJ
Joined Apr 2001
If you glue a speed 400 plywood motor plate to the face of the motor flange and cut out a hatch in the motor cowling that tapes back on, the motor can be bolted in and removed. Sand the wire trough in the fuse so the wire slides easily so you can move it to solder and make sure you don't CA the wire in. Set up the one I did for my club like this, we plan on going through a few motors with this thing.
Mike |
My youngest child, Barbara, turns 10 tomorrow. Her EasyStar arrived today. Look for her adventures with it to show up as a review on the Ezone sometime in the future.....
![]() She does have some affinity for airplanes, BTW. A semi-famous sequence of pictures of her taken in 2001 is here: http://www.shredair.com/album/washougal3.html We're about to open the box and make sure all is well. |
Latest blog entry: Diverted from R/C to Free Flight (of a...
| Thread Tools | |
| Fanfold Corsair Build Thread Part 2 | Vyceroy | Foamies (Kits) | 230 | Apr 14, 2010 11:49 AM |
| EDF50 Funjet and EDF40F16 thread part 2 | Thatovalguy | Foamies (Scratchbuilt) | 458 | Sep 02, 2009 01:32 PM |
| Mini SpeedWing 250 Thread -- Part 2 | Acer | Foamies (Kits) | 91 | Jan 22, 2005 06:43 PM |
| Yippee! Multiplex EasyStar thread - Part 3! | tim hooper | Foamies (Kits) | 496 | Apr 08, 2004 05:40 AM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 10:35 AM |
