Old Sep 24, 2013, 09:34 PM
Littlenitro_216 is offline
Find More Posts by Littlenitro_216
United States, MI
Joined Jul 2012
Electric set up
Hello fellow flyers!
I am VERY green when it comes to setting up a electric airplane. Right now im getting into 3D electrics. I am getting a Extreme Flight Extra 300 60" EXP and have a 3dhs Extra 330sc still in the box.
I would like some help getting a general understanding on how to set up an airplane so that the battery, motor, and ESC all work together and i dont burn something up haha.
Any help is appreciated
Have a good one
-littlenitro
Littlenitro_216 is offline Find More Posts by Littlenitro_216
Old Sep 24, 2013, 09:57 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
This model to 6 lb.
Extreme Power Pack.
Power Combo
Extra 300-EXP ARF
Torque 4016/500 brushless motor
Airboss 80 Elite ESC
$429.95 + Shipping
For 200% thrust, with APCe 15x8
Is necesary one outruner with
Weight. 350-420 grams
Kv around 480.
6slipo 4000ma.
ESC 70-85A.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Sep 25, 2013, 02:54 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
1. Work out what current the motor/prop are going to take. The various calc programs, Motocalc, Drivecalc etc are useful for this but you have to have first decided what battery voltage you're going to use. E.g. 3S, 4S etc.
2. Choose the ESC so it can take MORE current than this.
3. Choose a battery that could provide even more. The current a battery should be able to provide is mAh/1000 x C-rating.
E.g. motor wants 42A, choose 50A or better 60A ESC, battery something like 3000mAh @ 30C (3000/1000 x 30 = 90A). Nothing burns up .
There's a lot more to choosing a power system that works well for a specific plane but those basics at least get you one where the parts work together without damage.
Steve
slipstick is offline Find More Posts by slipstick
Old Sep 25, 2013, 03:44 AM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Have a good one
-littlenitro
You will not go wrong using the setups that EF and 3dhs respectively recommend. If you're not willing to spend that money, then find a motor with the same Kv (within 20 or so), and close to the same weight, ESC of the same current capacity (ensure it has a switching BEC built in or use an external switching BEC) and the same capacity and cell count packs - and use no more than the recommended prop size
scirocco is online now Find More Posts by scirocco
Old Sep 25, 2013, 09:03 AM
Fourdan is offline
Find More Posts by Fourdan
Fourdan's Avatar
Antony (France)
Joined Sep 2003
Have a good one
-littlenitro
Hi Little nitro
Try Scorpion Calc wizard
http://www.rcgroups.com/forums/showp...&postcount=368
Select the right flight mission/style
Louis
Fourdan is offline Find More Posts by Fourdan
Old Sep 26, 2013, 06:01 AM
United States, MI
Joined Jul 2012
Steve
Hey thanks slipstick! I really appreciate the help
When you gave the example, 3000mAh @ 30C (3000/1000 x 30 = 90A) do i always divide the mAh by 1,000?
So that being done, you would need a ESC that can take up to 90A? with the 30c 3000mAh battery.
Old Sep 26, 2013, 06:02 AM
United States, MI
Joined Jul 2012
Originally Posted by Fourdan View Post
Hi Little nitro
Louis
Thanks Fourdan, ill check out the calc
Discussion Kyosho spitfire 50 ep electric set up FedericoA Electric Warbirds 13 May 04, 2014 04:57 PM
Help! 72in lancaster electrics set up. george44110 Power Systems 1 May 01, 2013 02:11 PM
Discussion Bismarck electric set up 1.7mtr Snibo179 Scale Boats 12 Mar 06, 2013 05:20 AM
Help! electric power set-up help mx_ata2d Electric Plane Talk 10 Feb 14, 2013 10:48 AM
Discussion Stupid fast electric set up? rjstrickjr Power Systems 11 Feb 12, 2013 11:22 AM
