Old Sep 20, 2013, 02:23 AM
Predreadnut is offline
Find More Posts by Predreadnut
Predreadnut's Avatar
Joined Jul 2007
Dremel Model 580 Table Saw pulley/toothed belt conversion
OK, so I finally get my saw and the belt wont stay on. I read this is a common problem with them, I tried the fix of realignment of motor, spindle etc...still comes off. So does anyone have part #'s / website for converting the saw to timing pulleys and toothed belt? I found one place that gave part #'s, but that setup is more than I paid for the saw :-( HELP!! IM getting discouraged!
Predreadnut is offline Find More Posts by Predreadnut
Old Sep 20, 2013, 05:36 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Later Sewing machines have timing belt pulleys on them and earlier ones have round belt pulleys. Electric motor to flywheel drive on sewing machines. "O" rings make good drive belts.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Sep 20, 2013, 07:44 AM
ken_nj is offline
Find More Posts by ken_nj
GSMB Member
ken_nj's Avatar
United States, NJ, Howell
Joined Mar 2008
In Post #12 in this thread, tghsmith shows a toothed pulley setup. Not sure if he bought them from Amazon or not from his wording.
http://www.rcgroups.com/forums/showthread.php?t=1911137
ken_nj is offline Find More Posts by ken_nj
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
I have had my saw since they first came out and it has never thrown a belt. Did you try a new belt from Micro Mark?
Gravman is online now Find More Posts by Gravman
Old Sep 20, 2013, 12:11 PM
Joined Jul 2007
Thanks for the responses. I PMed Tghsmith and he can't remember what part #'s. I'm using a brand new seamless belt from Zimco. Adjusting the motor is the OEM's suggested solution, but getting your 1/8" Allen wrench on and turning.g to screws you can't see in a tight spot is not fun. After several cuss words, I managed to readjust the motor perfectly parallel to the spindle. After several test cuts, the belt is still on. We'll see if it stays on.
Question. What is the max thickness/material this thing is supposed to handle?? With a brand new 40 toothed, carbide tipped blade, mine barely was able to rip a 1/4" thick piece of hardwood.
Old Sep 20, 2013, 12:54 PM
green-boat is offline
Find More Posts by green-boat
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
I managed to rip a piece of 1-1/2" stock but that was a piece of balsa wood.
green-boat is offline Find More Posts by green-boat
Old Sep 21, 2013, 01:14 AM
Joined Jul 2007
Tghsmith sent me a link to www.robotmarketplace.com I believe I've figured out which components I need for the conversion. They have a neat calculator for determining what length belt you need, check it out.
Old Nov 22, 2014, 08:46 PM
bendix1 is offline
Find More Posts by bendix1
bendix1's Avatar
United States, CA, San Jose
Joined Jan 2013
Its a COGGED Belt pulley!
bendix1 is offline Find More Posts by bendix1
Latest blog entry: this is a great site
Old Nov 24, 2014, 09:21 AM
glgirvin is online now
Find More Posts by glgirvin
Milford Mi.
Joined Jan 2011
Gear beats
Hi , You can also find cog or gear belts and pulleys from stockdriveproducts .com. They also have a guide for determining length of belt based on pulley size and distance between centers of shafts. Gary.
glgirvin is online now Find More Posts by glgirvin
Old Oct 18, 2015, 04:31 PM
bendix1 is offline
bendix1's Avatar
Joined Jan 2013
Bill in Florida makes the Cog pulley and bely kit . Find him on ebay regularly,
Discussion Dremel Model 580 Table Saw Predreadnut Dock Talk 33 Sep 08, 2013 12:04 AM
Sold Dremel 4 in table saw model 580 CADILLAC200 Aircraft - General - Miscellaneous (FS/W) 4 Aug 19, 2013 10:18 AM
For Sale Dremel 580 table saw PROPJET Aircraft - General - Miscellaneous (FS/W) 3 Aug 07, 2013 11:14 AM
Sold Dremel 4" Table saw model# 580-2 & 13 extra blades holdemdlr Aircraft - General - Miscellaneous (FS/W) 19 Jul 19, 2008 09:26 PM
Wanted DREMEL MODEL 580 Table Saw Fence Gizz_mo Non R/C Items (FS/W) 0 Jun 26, 2007 12:44 AM
