OK a couple things have happened since I opened this post.
1st - I was able to contact Iron Bay and they are now sending me the instruction manual ($15), the canopy ($28) and the engine cowl ($28), should be in within the next week, woohoo
2nd- talked with previous owner who actually has another one in far better shape. He says that he is currently using a Quadra 35 witha reduction unit and it flies at approx. 90 mph = 500 scale mph, so I could get by with using an equivalent G38 and a straight prop instead of using the reduction unit and the thing should fly balls to the walls. Can anyone back that up?
I am also considering whether or not to put wire landing gear on it, fly it around, and get used to it before I get the $$ saved to purchase retracts. Any ideas??
About the ailerons, do ya think it would be better to put a servo on each aileron or use a single 1/4 servo to control both? I do plan on using a 1/4 scale servo on the flaps but they are connected with control rods so that would be easy.
Come on, gimme some advise here you giant scale people, please!!!
