Old Dec 08, 2001, 08:37 PM
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Little bit improved method for making actuators
First thanks to Buddly6 for showing us all how to make actuators. But after making a few I started to run out of servo control horns. So I went about it a bit different way. I don't have any nice pictures, but it's not that hard. First I went out and bought a telescoping TV antenna from radio shack. I cut through it and freed one section of the antenna. Which section you free depends on how big you want the inside diameter of your actuator to be. Next I took some of the circular servo "horns" and bored out their center such that they had a tight fit onto my antenna section. Mount the antenna into a drill, and then slide the servo horns onto it. Choose the width of your actuator by changing the distance between the horns. Next place a piece of electrical tape to keep the horns in place while you wrap. When applying glue/CA to the actuator, don't worry it won't stick that well to the horns, just be careful when removeing it.The rest should be simple after reading Buddly6's method. This allows different size ID's and doesn't use up lots of control horns.
Jim McPherson is offline Find More Posts by Jim McPherson
Old Dec 09, 2001, 01:01 AM
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
Running out of servo horns?
I'm still using the same two servo wheels I started out with.
In the picture below, I just screw the 2 wheels together.
Then wind the coil and put a couple drops of CA on it. (no white glue)
Spray with accelerator, wait 10 seconds, then unscrew the
botton wheel and take the coil off. Apply more CA to secure it.
No need to cut any servo wheels.
DNA is offline Find More Posts by DNA
Old Dec 09, 2001, 07:32 AM
Senior Member
Paul Penney's Avatar
Ancaster, Ontario, Canada
Joined Nov 2000
WOW!!! People are doing this nice actuator winder DNA, and you CAN buy servo heads at your Local hobby shop.........
Paul Penney is offline Find More Posts by Paul Penney
CheapBatteryPacks.com will be down for a little bit frederm2002 Vendor Talk 0 Apr 29, 2005 05:06 PM
CheapBatteryPacks.com down for a little bit frederm2002 Batteries and Chargers 0 Apr 29, 2005 05:05 PM
Info for making battery packs? Mike Wood Beginner Training Area (Aircraft-Electric) 4 Nov 04, 2001 12:27 PM
Is there a prescribed method for figuring out gearbox ratios kit basher Electric Plane Talk 2 Sep 28, 2001 08:11 AM
Ideas for making $$ with an E-plane maciek Electric Plane Talk 7 Aug 07, 2001 06:31 PM
