This thread is privately moderated by DismayingObservation, who may elect to delete unwanted replies.
Old Sep 16, 2013, 08:37 AM
DismayingObservation is offline
Find More Posts by DismayingObservation
Pronoun trouble...
DismayingObservation's Avatar
Southern California
Joined Feb 2006
The continuing quad saga
All remains relatively well with the reborn HPQ1 with its shiny new HobbyKing electronics.
I say "relatively" only because the number one motor kept popping its endbell during yesterday's flight adjustments. I'd removed the endbells in order for the quad to fit in its rather nice hard-shelled case which is SOP for that model.
Swapping out the number 1 and number 3 endbells fixed the problem, so I've temporarily marked that number one endbell with a Sharpie until I can engrave it or otherwise label it. The 8x3.8 APC slow-flyer props generate more thrust than stock, something to keep in mind when replacing them.
Good old Chad, aka "TheOne420" did a superb job of setup over at the hobby shop, properly activating the auxillary channel so that I can now switch the self-leveling mode on the fly. He even got the battery voltage indicator on the KK2 to work by soldering the leads of a JST connector to a couple of pads underneath the board. The positive lead went to a pad marked "AREF" and the negative was soldered to ground, or "GND." Once plugged into the male JST pins on the power distribution board, success!
I still want a better frame and motors, but we'll see how this one works in the long run.
DismayingObservation is offline Find More Posts by DismayingObservation
Discussion The Holder Saga Continues FL Knifemaker Life, The Universe, and Politics 20 May 26, 2013 10:23 AM
WTB HVP (HL) Beaufighter (a saga continues) faust Aircraft - Electric - Airplanes (FS/W) 0 May 22, 2003 06:28 AM
Miniflash Saga Continues enigmabomb Parkflyers 4 Apr 19, 2003 06:17 PM
Yippee! Saga of CLAWS Helping Hand Continues Don Sims Humor 47 Dec 12, 2002 08:34 AM
The Zagi Saga continues (Dual Rates and Threaded Rods) safetyboy Slope 5 Nov 07, 2002 02:57 PM
