Old Sep 15, 2013, 09:45 PM
BoeingDreamliner is offline
Find More Posts by BoeingDreamliner
Joined Sep 2013
Mini cub busted in midair with video...should I buy a champ?
Like what the title says, my mini cub just failed in mid air due to such low quality. i am considering buying a champ at my local hobby store. should I buy a champ or any other 3 channel plane? Video here:
Hobbyzone Mini Super Cub busted in midair - Engine FAIL (0 min 55 sec)
BoeingDreamliner is offline Find More Posts by BoeingDreamliner
Old Sep 15, 2013, 09:47 PM
Rampage is offline
Find More Posts by Rampage
DFS#000178
Rampage's Avatar
United States, CA, Twentynine Palms
Joined Aug 2005
Buy a Delta Ray.
Rampage is offline Find More Posts by Rampage
Old Sep 15, 2013, 09:48 PM
Joined Sep 2013
Originally Posted by Rampage View Post
Buy a Delta Ray.
I will consider. Thanks for the feedback!
Old Sep 15, 2013, 09:55 PM
Ginohio is offline
Find More Posts by Ginohio
Ginohio's Avatar
United States, OH
Joined Mar 2012
http://www.youtube.com/watch?v=Zc3hK...ature=youtu.be
either the Champ or the DeltaRay, also there is a new plane on the block the Duet for 59.00 with proprietary tx. Blahh... Depends on your budget. And yes.. I had the mini super cub and quickly got rid of it for a Champ. Now I have 2 Champs because they are so easy to fly I take 2 so someone else can learn the hobby as I buzz mine around them.
Ginohio is offline Find More Posts by Ginohio
Old Sep 15, 2013, 11:31 PM
Stormrider51 is offline
Find More Posts by Stormrider51
United States, TX, Wyldwood
Joined Nov 2009
Why do you say the plane failed? Just curious. No offense, but did you have that plane at full throttle all the time? It sure looked like it. What was the wind speed? What I hear blowing over the mic on the camera sounds substantial for a beginner.
I'm pretty much a beginner myself. I started a couple of months ago with an Apprentice 15e (the older version without SAFE) and frankly much of your flying in the video reminds me on my first couple of attempts. I had a LOT of simulator time on the Phoenix 4 sim before I even tried the real Apprentice and still had plenty of excitement. I flew in too much wind without an instructor and over-controlled which resulted in the plane acting like a bucking bronco. I'd intend to do one thing and it seemed the plane had other ideas. There was a lot of diving and swooping. I was luckier than you and got the plane down in one piece that first few times. I credit that mostly to having gotten enough altitude between the plane and the ground to allow me two mistakes before I hit terra firma. Again, I mean no offense but you let the plane get way too low. Did you have time to adjust the trims once in flight?
I later got a micro Champ by Hobby Zone. Lots of fun to fly when there isn't much wind. I usually fly it first thing in the morning before local winds build. I still have to co-ordinate rudder turns with up elevator or the plane dives for the deck instantly. I call it my warm up. It could serve you well but keep in mind that its flight characteristics aren't that much different than your current plane except that being smaller it will be more effected by the wind.
Learning to fly RC is a challenge. It looks easy until the transmitter box is in your hands. A good simulator like the Phoenix 4 is a great aid to learning stick control inputs. If at all possible I suggest you find an instructor to buddy box on your first couple of flights. It will prevent you from spending a lot of money on new planes and time spent repairing broken styrofoam. Can that Cub be repaired? That would be the cheapest solution.
Most importantly, don't give up. You can do this. It's not as easy as it looks or even as easy as the manufacturers would like for you to believe but it can be done. Keep in mind the old pilot's truth that "There's nothing more useless than runway behind you and altitude above you." Do your learning a couple of mistakes high. And don't fly at full throttle.
Storm
Stormrider51 is offline Find More Posts by Stormrider51
Old Sep 15, 2013, 11:39 PM
papadwight is offline
Find More Posts by papadwight
papadwight's Avatar
United States, TN, Murfreesboro
Joined Apr 2013
How hard was the wind when you were flying. The mic made the wind sound to hard for any micro to fly good.
papadwight is offline Find More Posts by papadwight
Old Sep 15, 2013, 11:53 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
I just watched the video and it looked like you were out of control most of the time, you almost crashed a few times during the flight. I didnt see any obvious in-flight failure. It just looked like you got into a tight spiral dive and didnt know how to recover. I'd guess were just pulling 'up' on the elevator which would only make things worse. In summary it looked 100% like pilot error.
So what makes you think there was any in flight failure of the model?
My advise would be to fix it and next time thottle back to a slow cruise speed and use much more gentle control inputs. You were being much too aggressive on the controls, you just need tiny movements on the stick.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Sep 16, 2013, 12:15 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
Yep, the plane was pretty much flying you instead of the other way around.
chucksolo69 is offline Find More Posts by chucksolo69
Old Sep 16, 2013, 03:03 AM
JRjoe is offline
Find More Posts by JRjoe
NCFR !!!
JRjoe's Avatar
United States, IN, Valparaiso
Joined Jul 2013
Funny
Watching the video i thought the same. Full throttle the whole time, very windy, and mostly out of control. Saw no failure either. hmmm....
by the way, if you pull back on the left stick it'll slow down..!!!
OK, just pokin fun at you. The Apprentice or DeltaRay would be good choices. Possibly a Champ on a CALM day.
JRjoe is offline Find More Posts by JRjoe
Old Sep 16, 2013, 09:10 AM
Joined Sep 2013
Anymore beginner 3 channel planes?
Old Sep 16, 2013, 09:21 AM
wayfaringdreamer is offline
Find More Posts by wayfaringdreamer
wayfaringdreamer's Avatar
United States, PA, Middletown
Joined Sep 2011
If I was just starting to learn I'd go with either the Delta Ray or the Stratos Firebird. Both are cool looking planes imho.
wayfaringdreamer is offline Find More Posts by wayfaringdreamer
Old Sep 16, 2013, 09:43 AM
Leo L is offline
Find More Posts by Leo L
United States, NY, Queens
Joined Oct 2005
You have received a lot of good advice here. I suggest that you do the following:
1) Consider spending some time on a simulator. It won't replace real flight experience, but it will give you a little more confidence in operating the controls.
2) Go to the sticky at the top of this forum called "Six Keys to Success". Read, study and memorize the recommendations from AEAJR.
Either repair your mini-SC or buy another (better) beginner plane and go have some fun. Currently, the best beginner planes are:
- HobbyZone Delta Ray
- HobbyZone SuperCub
- HobbyZone Champ
- HobbyZone Stratos
- E-flite Apprentice
- Multiplex EasyStar
Leo L is offline Find More Posts by Leo L
Old Sep 16, 2013, 10:04 AM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
If you are willing to assemble ( easily ) a plane , try the EzFly from Fancy Foam . In my opinion , it's the best trainer available . Made from EPP foam so it's tough , when properly balanced and trimmed it's SUPER stable ( let go of the right stick and it returns to straight level flight by itself ) , and the motor/prop are protected from nose first " landings " . I use low temp hot glue to assemble mine .
http://www.fancyfoam.com/index.php?m...roducts_id=309
All the electronics you'll need are listed underneath the plane on that page .
Al
Here's mine ( home made )
144 gram EZfly RC plane (3 min 34 sec)
balsa or carbon is offline Find More Posts by balsa or carbon
Old Sep 16, 2013, 10:34 AM
Joined Sep 2013
- HobbyZone Champ
- HobbyZone Stratos
Thanks. I have already read all the tips and now considering buying a hobbyzone stratos. you get free shipping and an extra 1300 mah battery for 6 bucks from hobbyzone.com
Old Sep 16, 2013, 10:58 AM
PiperRon is offline
Find More Posts by PiperRon
PiperRon's Avatar
Joined Feb 2013
Doesn't matter what you choose for your next plane. You will crash it just like you crashed the mini cub.
We all crash when we are learning how to fly. Get a plane that is easy to repair and parts are readily available.
PiperRon is offline Find More Posts by PiperRon
Discussion Mini Super Cub vs Hobbyzone Champ Rockhem Electric Plane Talk 3 Sep 07, 2013 12:36 PM
Discussion Hobbyzone Mini Super Cub vs Champ Rockhem Beginner Training Area (Aircraft-Electric) 15 Sep 04, 2013 10:08 AM
Discussion Champ vs Mini Super Cub vs Super Cub vs ? rctoyguy Beginner Training Area (Aircraft-Electric) 18 Aug 17, 2013 08:30 PM
Discussion Difference between champ and mini super cub? martin34a Beginner Training Area (Aircraft-Electric) 11 Apr 17, 2013 01:42 PM
Discussion Help with how to set up the DX6I for s-cub and champ etc. video fishycomics Radios 0 Jan 13, 2012 03:49 PM
