Copter Frames Aura 2-Axis Brushless Gimbal Review
A Nice Package for DSLR Sized Cameras
Inner width: 185mm
Inner depth: 115mm
Outer height: 220mm - 260mm
Weight: 830gr with motors
Camera Size: DSLR
Price: $640.00
The Aura 2 Axis Brushless Gimbal from Copter Frames looks like a solid well built camera gimbal designed for DSLR cameras. I've used a Copter Frames gimbal for smaller cameras and that before brushless technology was available so I was excited when they offered to send me the Aura for review. I was curious to see how it compares to some of the other brushless systems I've used before.
What's Included
The Aura comes complete with G10 fiberglass plates, carbon fiber tubes, plastic boom clamps and more hardware than you'll actually use. I'd rather get more hardware for spares than not enough so I applaud Copter Frames for this level of completeness. The carbon fiber tubes are 25mm OD and look to be excellent quality. In fact, all the parts looked great. It even included two iFlight 4114 brushless gimbal motors. I was worried about the fit and finish of the parts as my first gimbal years ago required a lot of modification to get things to fit and work correctly. I'm happy to report that the fit and finish on the Aura is top notch. I didn't have to ream any holes or modify any parts during the assembly. Well done! Just add your gimbal control board, battery, camera and attach it to your multirotor helicopter of choice and you're off and running.
I wanted to do this build as any user would and use the information provided. There was no manual included, but there is an assembly guide located on the Copter Frames website. The instructions there are minimal so if you've never built a gimbal before, you may have a tough time, but I was able to follow along just fine and didn't come across anything that confused me. Some of the drawings in the instruction guide are rendered drawings and may not represent the actual part. I also noted that a few parts are different than the guide and are likely design changes made to the parts after the guide was made. I initially assembled the gimbal based on the guide, which puts the pitch motor on the right hand side. I later switched that arm to the left because most cameras have their battery pack on the right side and that weight helps to counter the motor weight and makes it easier to balance the roll axis. I also moved my Alexmos flight board to the back of the roll motor plate after the first assembly. I prefer this location to the side arm mount shown in the guide.
The first thing was to assembly the boom clamps and plates that make the two 90 degree angles at the left and right side of the gimbal. The guide was easy to follow here and I liked that it showed which size bolts to use. The hardware bags are not labeled so you will need a ruler to measure the screws so you can make sure to use the correct ones.
Going down the assembly guide everything was perfect until I got to the tilt axis bearing block. It's not a big deal, but in the guide it shows two spacers, a 30mm one and a 5mm one. In the kit you get one 35mm spacer which is better, but if you are trying to follow the guide to a T, then this would throw you off, so now you know what to look for. The only other section that was different was the camera mounting plate, but that one is pretty obvious. You can use the photos below to aid in building yours.
Adjustability, Balance and Control Board
Depending on which camera you use, you are going to need some adjustments to be able to balance the camera on the gimbal. The Aura tilt bars have slots in them that allow the camera mounting tube to slide up and down with roughly 22mm of travel allowing you to easily adjust the pitch axis. You can slide the camera mount plate left or right or even slide the whole assembly at the roll motor to achieve roll balance. In some cases you might need to add lead weight to get it to balance.
Balancing a brushless gimbal is critical to good performance. I chose to move the tilt motor to the left side to make it easier to balance the roll axis. Balancing the gimbal is not too difficult, but there is a common misconception that when you move an axis, it should return to level. That would mean the gimbal is bottom heavy in that axis and it is leveling out like a plum line would. Opposite that would be the axis would go hard over one way or the other indicating it is top heavy. When you get it just right you can position the roll or tilt virtually anywhere and it will remain in that position. I prefer to use Alexmos gimbal control boards, but you could also use a Martinez board. Follow your boards instructions for setup and tuning.
Mounting
Mounting the Aura to a Cinestar style landing gear set is easy and requires no additional hardware. Simply slide the boom clamps onto the rear landing gear tube and adjust forwards and backwards to achieve proper center of gravity for the copter. Alternatively, if you have an S800/Droidworks/FY680 style mount, Copter Frames offers a mounting adaptor (sold separately) to attach the gimbal to those frames.
Stable Video
Below is a video edited for time and has been colored for fun, but with absolutely no post stabilization added in. This is how it looks right out of the camera. I used a Panasonic GH3 with a custom OctoCopter and the winds were 10-15MPH.
The Aura 2-Axis brushless gimbal is nicely made and well designed. I was impressed with the fit and finish of the parts and the 4114 motors make it suitable for DSLR cameras. Ultimately, stability is a function of how well you balance the camera and tune the control board. The Aura gimbal mechanics work in such a way to make that job easy. It is perfect for a single operator and if you add an FPV system you can achieve even better footage by seeing what you are filming in real time. If you'd rather have a setup for dual operators then I would recommend the Aura 3DEE 3 Axis Gimbal which comes with pan axis stabilization and landing gear legs. Learn more about the Aura and other gimbals at CopterFrames.
Old Oct 31, 2013, 06:06 PM
remvideo is offline
Find More Posts by remvideo
bacon and eggs
remvideo's Avatar
United States, FL, West Palm Beach
Joined May 2013
how much does that pig weigh
remvideo is offline Find More Posts by remvideo
Old Oct 31, 2013, 07:39 PM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
From Jason's "Specifications Sheet" box Above:
Nicely put together review Jason. Did I miss it or did you not mention the price?
Bajora is offline Find More Posts by Bajora
Old Nov 01, 2013, 09:48 AM
Jason Cole is online now
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
Thanks. It's $640. I'll add that in up top.
Jason Cole is online now Find More Posts by Jason Cole
Administrator
Old Nov 06, 2013, 02:21 AM
ozanozkok is offline
Find More Posts by ozanozkok
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Thanks Jason,
we have some videos from users.
Aura & Blackmagic PC test video,Thanks to Javier:
BlackMagic Pocket Cinema Camera Aerial Video Test - helicamworx.com (3 min 6 sec)
ozanozkok is offline Find More Posts by ozanozkok
Old Nov 07, 2013, 08:42 AM
Sleepyc is offline
Find More Posts by Sleepyc
Closed Account
Joined Aug 2006
Nice review Jason. looks like a decent gimbal!
Sleepyc is offline Find More Posts by Sleepyc
Old Nov 12, 2013, 02:48 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
New user video,thanks to Javier,Helicamworx:
DistritoCuatro - Escazú, Costa Rica (helicamworx.com) (2 min 9 sec)
Old Nov 19, 2013, 06:16 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Condominios Vista al Valle - helicamworx.com (6 min 28 sec)
Old Nov 21, 2013, 03:09 PM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
BlackMagic Pocket Camera raw video test (3 min 42 sec)
Old Dec 20, 2013, 03:21 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
New user video,taken with variety of our gimbals :
Helivizyon 2013 Showreel (3 min 52 sec)
Old Jan 06, 2014, 10:20 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
AURA has 3. axis,now. Please check it at CopterFrames
Old Mar 02, 2014, 03:17 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
New user video from Helicamworx,Thanks Javier:
Azul Ocean Club - by HelicamWorx (12 min 9 sec)
Old Mar 06, 2014, 08:21 AM
Musician-Designer
ozanozkok's Avatar
Türkiye, Istanbul
Joined Mar 2011
Beautiful house for sale, Santa Ana - helicamworx.com (4 min 0 sec)
Old Jul 15, 2014, 02:23 AM
seethalmj is offline
Find More Posts by seethalmj
Joined Mar 2013
Hai ozanozkok … ur New Aura 3d Gimbals Can get unlimited 360 yaw /pan Rotation /without Hutrs wire ??? does it Cut wire ???
Also Built In damping / anti vibration Dampings ??/
U will Make Plug n Play ???
Thnks
ur video Seen its Awesome //
Does this Video frm ur 3 axis one or 2 axis ????
seethalmj is offline Find More Posts by seethalmj
Old Sep 30, 2014, 01:39 PM
KD0ZEQ is offline
Find More Posts by KD0ZEQ
Aviation Enthusiast
KD0ZEQ's Avatar
United States, CO
Joined Nov 2012
Anybody know what the max pay load limit on this thing is? Or if the Sony FS video Camera will fit on there? Am currently using a servo driven 3 axis but am looking on the market for a brushless setup that can handle the Sony FS100 style video cameras.
KD0ZEQ is offline Find More Posts by KD0ZEQ
New Product AURA & AURA 3DEE Brushless FOR DSLR'S Like Canon 5D ozanozkok Multirotor Talk 20 Jun 16, 2014 07:47 AM
News New Aura 3DEE 3-Axis Brushless Gimbal Jason Cole Multirotor Talk 12 Feb 20, 2014 01:16 AM
Sold Copterframes Evo TwoDee Gimbal with Hitec HS-5565MH knichefilms Aircraft - Electric - Multirotor (FS/W) 0 Jun 30, 2013 01:26 AM
New Product CopterFrames Gopro sized brushless gimbal ozanozkok Multirotor Talk 26 Apr 07, 2013 07:07 AM
Sold Lightly Used CopterFrames GO Gimbal mattchase Aircraft - Electric - Multirotor (FS/W) 4 Feb 08, 2013 01:52 PM
