Old Dec 08, 2001, 05:03 PM
Vincent is offline
Find More Posts by Vincent
Joined Nov 2001
Servo problem, please help...
Hello, I have a Hitec HS-55 servo, when I plug it into the receicer with the battery pack attached and I move the stick it makes a faint noise but no movement. I tried the same receiver and battery pack on another HS-55 and it works so that cant be the problem. Anyone have any ideas about what this is and how to fix it? Also the receiver wires going into my Rondo 400 ESC ripped off (going into the ESC). How would I know which wires to solder where? Thank you very much for your help!!!
Vinnie
Vincent is offline Find More Posts by Vincent
Old Dec 08, 2001, 05:38 PM
marcus is offline
Find More Posts by marcus
eschew obfuscation
Far north Dallas, Texas
Joined Oct 2001
Are you sure that you have the servo plugged in correctly?
Sounds like it's backwards.
marcus is offline Find More Posts by marcus
Old Dec 08, 2001, 05:50 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
If you are sure the servo is bad, after checking the coonections and other channels. It may be bad. I had 1 bad Hitec servo once and just got it replaced at the LHS.
You could also ask Mike M on the "ask Hitec" thread in open and send it in.
On the Rondo ESC, (RX lead on top and from the back (componet side);
Signal (orange) goes on the left
Power (red) goes in the center
Ground (brown) goes on the right
Fred Bronk is offline Find More Posts by Fred Bronk
Old Dec 08, 2001, 05:58 PM
ZagiArt is offline
Find More Posts by ZagiArt
Santa Paula, Ca
Joined Apr 2001
Servo Problem
Hey Fred,
I have had the same problem before. It's usually the plastic gears are stripped out. Get a rebuild kit or send it back to Hitec for repairs. Happy flying Art
ZagiArt is offline Find More Posts by ZagiArt
Old Dec 09, 2001, 10:54 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
vincent
I agree with Art. sounds like you had a crash and the little servo gears are delicate and frequently get stripped. Gears are cheap, under $5 unless metal.
Replacement is easy, but you should get someone to show you how the first time. If you have no one to help, ask on the ezone for a detailed description. We've all done it.
If you do take it apart, try to keep the gears in place when removing the cover so you know which gear goes where! They only go in one way but it can take a while to figure out if you lose track!
Dave
DaveW is offline Find More Posts by DaveW
Old Dec 10, 2001, 11:00 AM
Rotten Robbie is offline
Find More Posts by Rotten Robbie
Rotten Robbie's Avatar
Kent, Wa.
Joined Feb 2001
Replacement Gear Sets!
I have recently noticed that my LHS has begun stocking replacement gear sets for the small Hitec servos.
If this guy is stocking them, this must be a common problem.
Robbie
Rotten Robbie is offline Find More Posts by Rotten Robbie
Help! Help with servo problem PLEASE garfro Mini Helis 1 Jun 08, 2007 08:31 PM
Trex servo centering problem , PLEASE HELP JGELS Mini Helis 13 Jan 31, 2005 12:35 PM
ESC Problem, please help?? Vincent Power Systems 4 Dec 06, 2001 05:58 PM
Hornet assemble problem... please help! crazybear Electric Heli Talk 3 Nov 01, 2001 09:13 PM
RANGE PROBLEM...please HELP!!! tnsfrk Electric Plane Talk 5 Jul 24, 2001 09:46 PM
