XRAY Fuel Tank 123cc with Floating Filter
Keeps the engine running even when your car is upside down.
Perfect for a 1/8-scale off-road vehicle!
New fuel tank features an integrated floating stone filter to ensure the fuel pickup is always in the correct orientation Ė even if your car isnít. This fuel pickup system will allow fuel to continue to flow to your engine, even while waiting for a marshal put your car back on its wheels.
The fuel tank is molded from a special composite mixture which ensures very high reliability and rigidity. The molded-in splashguard protects the brakes from fuel spillage. The tank is mounted with rubber grommets to absorb vibration and small composite holders secure thick 5.5mm silicone fuel tubing. The pressure cap features a 1-piece profiled seal for perfect fit and sealing.
KEY FEATURES
  • New fuel tank design
  • Integrated floating stone filter ensures the fuel pickup is always in the correct orientation. This fuel pickup system will allow fuel to continue to flow to your engine, even while waiting for the car to be put back on its wheels.
  • Molded from a special composite mixture for very high reliability and rigidity
  • Molded-in splashguard protects the brakes from fuel spillage
  • Rubber mounting grommets absorb vibration
  • Small composite holders secure thick 5.5mm silicone fuel tubing
  • Pressure cap features a 1-piece profiled seal for perfect fit and sealing
Visit the site for more info on products from XRAY!
There are no posts
Sold Fuel Tanks (21) + 3 Fuel Jug Pumps, Filters $10 DEdwards Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jun 12, 2012 08:23 PM
Sold Fuel Tanks, Filters, etc. HeloDrvr Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 12, 2012 01:06 PM
Discussion WOT4, would you use fuel filters on the plane, or on the pump when filling up tank? dazzyboi Fuel Plane Talk 6 Jun 03, 2010 05:19 AM
Help! Fuel Tank Filtering MUTID Engines 5 Jun 02, 2008 08:55 PM
OS .91 surpass 4 stroke with mount, fuel filter, tank, prop, spinner Steve H. Aircraft - Fuel - Airplanes (FS/W) 2 Jul 01, 2004 09:01 PM
