Old Sep 10, 2013, 10:39 PM
Fish07 is offline
Find More Posts by Fish07
IF ani't broken, don't fix it.
Puerto Rico, Carolina
Joined Jul 2006
New Product
New Release: Aeroworks 20cc to 30cc Trainer GT ARF-QB Quick Build
From Aeroworks:
Aeroworks is proud to add the New 20cc 30cc Trainer GT to their line of QUICK BUILD Series Aircraft
Hello all,just found this at FG wanted to share with you all,enjoy
http://www.aero-works.net/store/detail.aspx?ID=556
Fish07 is offline Find More Posts by Fish07
Old Sep 11, 2013, 05:55 AM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Looks sweet. Very scale looking. Aeroworks always has good quality products.
Dale 813 is offline Find More Posts by Dale 813
Old Sep 12, 2013, 08:26 AM
kking86 is offline
Find More Posts by kking86
United States, PA, Shoemakersville
Joined Feb 2013
man, that thing looks awesome.
kking86 is offline Find More Posts by kking86
Old Sep 12, 2013, 08:52 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Looks like a pretty tower trainer 40...
Thermalin is offline Find More Posts by Thermalin
Old Sep 12, 2013, 09:23 PM
Fish07 is offline
Joined Jul 2006
Looks like the good old Sig Katet MK II.
Old Sep 14, 2013, 12:07 PM
DGrant is online now
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
I like it! Bout time someone took that format and blinged it up a bit. It looks very modern and current, with a nice touch of nostalgia.
At $449 it might be a tough sell, but we'll see. Thats probably 2 times the cost of the engine I remember when the engines were twice the cost of any kit. just a though there.. Its still a very nice plane.
DGrant is online now Find More Posts by DGrant
Old Jan 06, 2014, 04:48 PM
acs_guitars is online now
Find More Posts by acs_guitars
Guru/Mechanic Extraordinaire
acs_guitars's Avatar
USA, FL, Jacksonville
Joined Jun 2007
I have one of these I assembled and maidened this past weekend. I was considering the OS 33, but went for the DLE 30 instead as I was not sure the Pitts muffler would not interfere with the nose gear. The assembly was straight forward and I ran into no real issues. I built the plane Saturday and had it ready to go for Sunday morning at the club. The DLE carb needles needed a bit of tweaking to get it running, but after only 5-10 min on the starting table, we decided to throw it in the air. I set the control throws using the TLAR method (That Looks About Right) for Low Rates and left the High Rates at 100%. The DLE 30 is certainly overpower for this plane, but exactly how I like it. It lifted off very quickly and only required a few clicks of trim and the CG feels pretty neutral. At half throttle and on low rates, it flies just like you would expect a trainer to fly - No bad habits and a good putt-around T&G plane. On MY high rates it flies like an aerobat performing very well... It rolls like an Extra, pulls tight inside and outside loops cleanly, and inverted flight requires surprisingly little elevator input. It's a great sport plane and I can see it quickly becoming one of my favorites.
acs_guitars is online now Find More Posts by acs_guitars
Old Jan 10, 2014, 09:44 PM
daddyrabbit1234 is offline
Find More Posts by daddyrabbit1234
Scale flyer
daddyrabbit1234's Avatar
United States, GA, Clayton
Joined Jul 2013
Would be nice to see this plane offered as a tail dragger for the grass flyer's out there. IMHO tri gear with pant's doesn't seem to be the best set up for a trainer plane.
daddyrabbit1234 is offline Find More Posts by daddyrabbit1234
Old Jan 10, 2014, 11:17 PM
Joined Jun 2007
I got in a few more flights today with a prop change. The first flights were done with a 20x8 Vess prop which did great until I nicked the tips taxiing due to the nose gear flexing. Today I tried an 18x6 which is not enough prop IMO. The needles didn't need much at all and the motor certainly unloads now. I plan on trying an 18x8 and 18x10 before I settle on one. Today I started wringing it out a bit more. I tried a few 3D maneuvers that I knew it would not want to do, and I was right... it didn't do them. However, the DLE30 will pull unlimited vertical at a decent climb rate with the 18x6 prop and will knife edge quite well the full length of the field. As a trainer should, it slows down nice, has a gentle stall, and in a cross wind it will crab in nice and slow. So far I really like the kit with the DLE30 and finding no gremlins.
Old Jan 10, 2014, 11:21 PM
Joined Jun 2007
Converting this to a tail dragger would not be too difficult, the hardest thing would be the steerable tail wheel.
Most purpose-built RC trainers are actually trike gear and tail draggers are traditionally considered more difficult for ground handling (In general, I don't really agree with this, but that's what they say). The pants are not included in the kit so they really are not an issue, and it does quite well on grass IMO. Though I think a heavier dual spring Fults style nose-gear (http://www.fultslandinggear.com/RFseries.html) would be much better... Turning around with much speed will flex the nose gear a bit. I have a Fults on order and will soon see if that is much improvement.
Old Jan 16, 2014, 10:33 PM
Joined Jun 2007
I got the Fults gear installed.... Much more solid than the stock piece.
Next up is the tow point.
Old Mar 01, 2014, 07:28 PM
Stikpilot is online now
Find More Posts by Stikpilot
United States, KS, Wichita
Joined Aug 2009
Can you tell me which Fults gear (Part Number or Size) that you used? I'm waiting for the back order at Aeroworks to come in in April. I thought I'd start picking up some of the items I'll need for this plane.
Stikpilot is online now Find More Posts by Stikpilot
Old Mar 01, 2014, 07:29 PM
Joined Aug 2009
That said…per chance does anyone have one of these airplanes NIB that they want to sell? Never hurts to ask….
Old Mar 01, 2014, 09:35 PM
Joined Jun 2007
I went with the RF770 because it uses a little larger wire and is a bit more stout... I would call the Fults gear a requirement on this ARF, it is a MAJOR improvement.
I built a second one for a club member with the wheel pants, they look great and fit the Fults gear with only minor trimming to clear the axle.
Old Aug 27, 2014, 10:22 PM
redraider is offline
Find More Posts by redraider
Go Tech
redraider's Avatar
United States, NM, Mayhill
Joined Jul 2006
Anybody know of one of these for sale? I tried to order one today from Valley view, Chief, and aeroworks. Out of stock until January. :/(
redraider is offline Find More Posts by redraider
For Sale AeroWorks Extra 260 Freestyle QB-L (Quick Build-Light) NIB Full Package Mister Gassy Aircraft - Electric - Airplanes (FS/W) 4 Jan 27, 2016 05:47 PM
Sold Aeroworks Yak 54QB (Quick Build) .60-.90 Arf New in the Box $210 hobbyfun100 Aircraft - Fuel - Airplanes (FS/W) 2 Jun 19, 2013 01:33 PM
Off Site AEROWORKS 75cc Yak 54 ARF-QB Quick Build w/ Carbon Fiber Wing/Stab Tubes (ARF)(NIB) chrome350 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 11, 2012 04:06 PM
For Sale Like new Aeroworks .60 - .90 Extra 300 ARF-QB Quick Build wingset and parts thundercl58 Aircraft - Fuel - Airplanes (FS/W) 11 Aug 29, 2011 12:37 PM
Wanted AeroWorks .90 to 1.20 Yak 54 ARF-QB Quick Build silent_guru Aircraft - Fuel - Airplanes (FS/W) 0 Sep 02, 2009 11:55 AM
