Jeti DS-16 Carbon Edition Radio
Jeti's New Flagship Radio System
The DS-16 Carbon Represents Jeti's new Flagship Transmitter
This revolutionary, digital, 16 Channel, 2.4GHz, frequency hopping radio system is fully designed and manufactured by Jeti Model in the Czech republic. This is one of the most advanced radio systems on today's market. With their solid CNC aluminum case with a fully integrated antenna, a mini USB port, built-in speaker, headset jack, metal transmitter gimbals with Hall sensors (4096 step resolution) and 9 ball bearings for precision movement, a large 320x240 backlight display and many other features the Jeti DC/DS-16s are sure to become the new standard in transmitter performance.
Jeti’s final touches and finishes are outstanding. The front panel of the system is made of genuine Carbon Fiber with UV stabilized acrylic clear coating as well as aluminum frame which is finished in multi-layer automotive paint.
One of the attractive features of the Duplex 2.4GHz line of products is it's full integration with all Duplex telemetry sensors. You can easily observe up to 40 different parameters in real-time directly on the transmitter. Or, by using the JetiBox Profi (sold separately) you can see your data in parallel mode giving you and your copilot valuable real-time information (see video).
One of the most important features of Jeti's transmitters is the gimbal and switch function assignment flexibility. With the DC/DS-16 you are free to fully customize your radio. You can swap switches or sticks (Mode 1-4) and the on-board computer will recognize your changes and assign functions anywhere you like. Other important functions are programmable Sounds/Alarms and even user-recordable sounds. This audible alarm feature was specifically designed to keep you informed while also keeping distractions to a minimum. We think this is the best way enhance both your enjoyment and your model safety. You can simply set a receiver battery capacity alarm for the desired capacity used and once that number is reached the system acoustically and visually gives you warnings. [Esprit Model]
Old Sep 11, 2013, 01:14 PM
Hoot is offline
Find More Posts by Hoot
United States, TX, Houston
Joined May 2003
Big deal. A carbon fiber front for the transmitter instead of the polished black front
Hoot is offline Find More Posts by Hoot
Old Sep 11, 2013, 01:16 PM
Hoot is offline
Joined May 2003
duplicate post. Sorry
Old Sep 11, 2013, 01:37 PM
juliant is offline
Find More Posts by juliant
Julian T
Fleet, UK
Joined Jun 2005
Have to agree. Jeti don't need the bling that Spektrum seem to like. Just provide top quality gear and the rest will take care of itself. At least the c/f won't peel I suppose
juliant is offline Find More Posts by juliant
News Joe Nall Product Feature: Jeti DS-16 awagar Radios 4 Jun 10, 2013 08:29 PM
Discussion Spread the Word: Win a “Joe Nall 2013” Special Edition Carbon Jeti DS-16 Radio!!! Esprit Model Joe Nall 2013 11 May 15, 2013 06:01 AM
Discussion Spread the Word: Win a “Joe Nall 2013” Special Edition Carbon Jeti DS-16 Radio!!! Esprit Model Radios 1 May 09, 2013 09:36 AM
Discussion Firmware 2.01 on Jeti DS-16 jotto Jeti USA 2 May 07, 2013 07:36 AM
Discussion FCC Update of Jeti Duplex DS-16 Radio System Esprit Model Jeti USA 0 Mar 15, 2013 12:57 PM
