Old Feb 14, 2004, 08:36 AM
jswayze is offline
Find More Posts by jswayze
2ManyHobbies2LittleTime
jswayze's Avatar
United States, OH, Hamilton
Joined Sep 2003
Mis-labeled Pico crystal?
I was putting together my Mini-IFO and come to the point of testing my radio system. I turned on my radio and got nothing but a "blip" from the servos. Come to find out that the channel 31 "pico" rx crystal didn't match the package it came in (see attached photo.)
It seems very odd that the crystal would have mis-matched channels/frequencies printed on it. Am I missing something or did I just get a dud?
It's killing me because I wanted to fly this weekend, and the shop that sold this to me is closed. I'll try to hunt down another one...
Any ideas? GWS?
jswayze is offline Find More Posts by jswayze
Old Feb 14, 2004, 08:38 AM
jswayze is offline
jswayze's Avatar
Joined Sep 2003
I guess if you preview the message you lose the picture... Here it is.
Old Feb 14, 2004, 08:54 AM
beanie is offline
Find More Posts by beanie
Ann Arbor, Michigan, United States
Joined Sep 2003
that is really odd!
when i did a search on line for frequency lists, i found this:
chn 31 is 72.410... so the print on the box looks right. i actually couldn't find a 72.865... i did find a 72.870 which is channel 54.
i'd take it back to the store you got it from and have them check it out.
anybody know of a simple way to verify a frequency?
-beanie
beanie is offline Find More Posts by beanie
Old Feb 14, 2004, 09:15 AM
jswayze is offline
jswayze's Avatar
Joined Sep 2003
Oh boy, I win the bonehead award for today (at least for this morning )
The correct frequency is printed on the OTHER SIDE of the crystal! I also found a thread that says that the actual cyrstal frequency is .455 MHz less than the "channel" frequency.
The reason I jumped to the conclusion tha the crystal was wrong is that my setup didn't work, and still doesn't. Here's what I've got:
- Hitec Flash 5, ch. 31 crystal
- GWS ICS-100 ESC
- GWS 4-ch. Pico receiver
- 2x GWS Pico servos
- 2s LiPo battery
I turn on the radio first, then plug in the battery to the ESC. I hear the servos "blip" like normal, then I get nothing. No control from the radio. Any ideas?
Old Feb 14, 2004, 09:41 AM
larsy87 is offline
Find More Posts by larsy87
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
Try reversing how you plug your servo and ESC wires into the Rx.
Cam
larsy87 is offline Find More Posts by larsy87
Old Feb 14, 2004, 09:42 AM
larsy87 is offline
larsy87's Avatar
London, Canada
Joined Aug 2002
Wait - Is your Hitec radio negative shift???
There's no way a Negative shift transmitter will work with a Positive shift Transmitter.
Old Feb 14, 2004, 09:47 AM
jswayze is offline
jswayze's Avatar
Joined Sep 2003
You got me there. I'd never heard of "shift" before today... I'll look into this. Thanks.
Old Feb 14, 2004, 09:49 AM
ScYcS is offline
Find More Posts by ScYcS
Just fly the darn wing!!!
ScYcS's Avatar
Germany, NRW, Herford
Joined Oct 2003
It is indeed a Hitec radio with a positive shift receiver (identified by the "J" on the receiver. The correct one will have a "F" on it). Your setup will not work. period. You will need a different receiver, one with "negative" shift.
ScYcS is offline Find More Posts by ScYcS
Old Feb 14, 2004, 09:58 AM
jswayze is offline
jswayze's Avatar
Joined Sep 2003
Well, lesson learned. This is my first non-Hitec receiver and I didn't realize there was a difference.
Thanks for everyone's help.
(Now I've got to find a LHS with these receivers so I can fly this weekend!)
Old Feb 14, 2004, 10:16 AM
ScYcS is offline
ScYcS's Avatar
Joined Oct 2003
Hitec also makes 2 versions, negative or positive shift. You should always state when buying a receiver for which shift it is. Hitec and Futaba use negative shift, JR and Airtronics and most others use positive. Some manufacturers make transmitters for both shifts (GWS for example).
Always make sure you tell the guy you buy from that it's for a Hitec radio with negative shift.
Old Feb 17, 2004, 10:46 AM
simingx is offline
Find More Posts by simingx
now that's a wattmeter...
simingx's Avatar
Singapore
Joined May 2002
If your radio is an Eclipse it has both shifts selectable.. just go to the setup menu and select "SFT. P" instead of "SFT. N"...
simingx is offline Find More Posts by simingx
Old Feb 17, 2004, 11:32 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Pls don't be supprised the actual RX cyrstal frequency is .455 MHz less than the TX "channel" frequency.
GWS4CEO is offline Find More Posts by GWS4CEO
Found GWS Pico Crystal CH17 dakine Aircraft - General - Radio Equipment (FS/W) 0 Jul 10, 2006 02:25 AM
Sold GWS RX PICO Crystal CH 19 ndawdz Aircraft - General - Radio Equipment (FS/W) 2 Jul 07, 2006 06:43 PM
Wanted GWS Pico crystal Steph280 Aircraft - General - Radio Equipment (FS/W) 3 May 25, 2005 05:10 PM
WTB: GWS Pico crystal Ch. 45 94ZA4 Aircraft - General - Radio Equipment (FS/W) 0 Apr 06, 2005 06:54 AM
Pico Crystal in Hitec Rx? bazahn Power Systems 1 Aug 01, 2001 05:25 AM
