This thread is privately moderated by Bud Morrison, who may elect to delete unwanted replies.
Old Mar 23, 2012, 10:10 PM
Tee Bee is offline
Find More Posts by Tee Bee
My latest completion
It's a Minnie Mambo built from an Early RC kit. Powered by Cox Surestart .049 with a Cox International intake throttle, type "B" glow plug head conversion, and no-drag starter spring. Swapped the hex-shaped prop driver out for a Babe Bee style unit to allow the spring to fit. The plane is covered with Cream Ultracote and Blue Mist and Black Monokote. Radio gear is a Futaba 2.4rx, HK 939MG servos on the rudder and elevator, and Futaba S3111 on the throttle. Uses a 400mah NiMH battery pack from Radical RC. She rolls on inflatable Trexler balloon tires and has a steerable tailwheel. Should be fun to taxi out to the runway, shoot touch-n-goes, and taxi back like the "big" boys.
Finished the assembly and test ran the engine this evening. Did some preliminary taxi testing in the street after getting a good idle established on the reedie .049.
Maiden soon!
Tee Bee is offline Find More Posts by Tee Bee
Old Mar 23, 2012, 10:24 PM
kpriddle is offline
Find More Posts by kpriddle
Slow 'n Steady...Grease 'r In
kpriddle's Avatar
Maine
Joined Oct 2008
Tee Bee,
That looks like a lot of fun! What spinner do you have on it?
KP
kpriddle is offline Find More Posts by kpriddle
Old Mar 23, 2012, 10:27 PM
kpriddle is offline
kpriddle's Avatar
Maine
Joined Oct 2008
Oh, just found it on RCU.
Old Mar 23, 2012, 10:32 PM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
you know id never had a cox .020 before. i had some 049s but they were always a problem. not this 020 within 5 flips it buzzed to life!bim in 5 days on my magnum .53 and it wont even pop.
cale10 is offline Find More Posts by cale10
Old Mar 26, 2012, 02:00 AM
Curare is online now
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Then you're probably doing it wrong.
One thing that I have noticed is that after some phaffing, reedies will run, but their constant backwards running and wobbly needles usually irritate me after a while.
Front induction Cox motors are far and away the better motor. My TD.020 is the sweetest little thing I've ever come across, fuel, flip fly, giggle, rinse, repeat....
Curare is online now Find More Posts by Curare
Old Apr 06, 2012, 05:27 PM
gene6029 is online now
Find More Posts by gene6029
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Finally finished up my Mini Mambo & installed the radio gear today.I Wanted to do the maiden today, but rain in the morning & 20+mph wind in the afternoon forced a re-think Doesnt look to much better tomorrow either...Gene
gene6029 is online now Find More Posts by gene6029
Old Apr 06, 2012, 09:50 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Perhaps.. but backwards starting .. which all reedy owners inevitably face... is ultimately down to starting technique/competence :-)
Wobbly needles are easily eliminated by discarding the useless cox spring and substituting a bit of decent quality sillycone fuel line.
Bare is offline Find More Posts by Bare
Old Apr 25, 2012, 07:15 AM
philbertthy is offline
Find More Posts by philbertthy
United States, PA, Renfrew
Joined Feb 2012
Description:
philbertthy is offline Find More Posts by philbertthy
Old Apr 29, 2012, 09:09 PM
Scirocco14 is offline
Find More Posts by Scirocco14
Scirocco14's Avatar
Asheville, NC
Joined Mar 2009
Not sure if this qualifies but...
Craft Air Scout 15 built from an original kit this winter, powered by a Fox .15 BBRC. Flies great at 1/2 throttle and is quite capable at full throttle. Not fully broken in yet, is turning around 13,000 RPM w/ an 8x4 prop.
Covered in orange & blue Monokote.
Mark
Scirocco14 is offline Find More Posts by Scirocco14
Old May 02, 2012, 05:50 PM
cale10 is offline
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
hey tee bee what reciever battery are you using in all your 1/2A models?????
Old May 02, 2012, 09:14 PM
Tee Bee is offline
Cale10, it varies by model. I mostly use NiMH packs from RadicalRC.com. They are small, light, affordable, and come soldered with the plug style of your choice. Most of my 1/2A birds use 400mah packs. The 160mah packs have worked well in my smaller stuff with TD .010s.
Old May 02, 2012, 09:37 PM
colibriguitars is offline
Find More Posts by colibriguitars
Joined Mar 2011
Tee Bee I can´t wait to see a new video of your Minnie Mambo!!! looks great!!
colibriguitars is offline Find More Posts by colibriguitars
Old May 03, 2012, 08:23 AM
Tee Bee is offline
I'm hoping to make the trip to Little Rock for the SMALL fly-in in a few weeks. Might be able to get some video then.
The Minnie Mambo came out pretty heavy at over 22oz built from the kit! With the Surestart engine set up with the low compression "Type B" head for good throttling, it has just enough power to cruise scale-like around the pattern at wide open. Will barely climb with that setup. With a stock Cox head for more compression, it has decent authority but the reliable idle is too high for landing. With the "Type A" head from Bernie, the engine seems to overtemp during the flight and quit regardless of the number of head gaskets installed.
In summary, the plane flies decently with Surestart power when tuned for normal performance but is too heavy for a Surestart tuned for a low idle capability. In retrospect, I feel that a properly throttled TD .049(Dickeybird-style) would be a better choice for this plane. It would give more top end oomph as well as decent idle. Would probably be a great plane for a Norvel .074 but I don't have any of those and will continue to fly it with Cox power.
Old May 03, 2012, 01:03 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Thought I would gather up some pics. of my smaller stuff.
aspeed is offline Find More Posts by aspeed
Old May 03, 2012, 01:08 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
Few more.
Gallery Post your 1/2A pics Tony Oliver 1/2A Planes 134 Feb 14, 2004 06:34 AM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
Post Your Corona Building Pics cactus Electric Heli Talk 27 Jun 05, 2002 08:34 AM
