| Thread Tools |
| This thread is privately moderated by Bud Morrison, who may elect to delete unwanted replies. |
Joined Jul 2007
Cox Li'l Stinker
Here is my last eBay purchase, the second Little Stinker I have bought. This one came with instructions and a control handle that can vary the line lengths.
The bronze reed was badly deteriorated, and the air intake was clogged. The dirtiest Pee Wee I have bought. I had to sharpen a pin to clean out the jet of the (choke type) carburetter. Neither of the Stinker engines has a screen air filter, maybe cause they take air from inside the fuselage where it is clean. |
Western KY
Joined Sep 2003
Overland --
Select the "New Reply" button on the lower left side below the last post in the thread to start a new response. When the text entry box appears, there is an "Additional Options" area underneath with a "Manage Attachments" button. Click this button to open the file upload dialog box. You can then browse to locate your images. Once you have all the images files listed, select "Upload" -- you will get a file uploading message -- when finished, close the window. Don't forget to submit the original response. andrew |
Austin, Texas
Joined Oct 2006
Here is my spankin new Das Not Ugly! from ulman.
Scratch built... as you can plainly see... and is my first. Havne't flown it yet... but look forward to it. 3x HS55's .061 Wasp 6x3 APC Berg Microstamp 4L CC Bec 2s 250mah lipo 1 oz dubro fuel tank. I haven't weighed it yet.. but supposed to be under 14oz... may be cutting it close! |
This is my first post to rcgroups. I'll post some pics of the 1/2A planes I've been building and flying lately. This is a Pong Two, built from plans available at Flying Models. Designed by L.F. Randolph. Powered by Cox Black Widow .049 and covered with Ultracote. 2-channel R/E with standard Futaba receiver/battery and Hitec HS-81 servos.
Here's my other Pong Two that was built simultaneously with the yellow one. This one has a Cox Medallion .09 up front and a 1.5oz tank. I added a hatch for the fuel compartment and used spruce for the spars. Otherwise, it's built by the plans. It's much faster than the .049-powered version. Does nice rolls to the left with rudder and elevator only. I removed the landing gear after these pics were made and have never used them since I fly these planes in a grass field. Lots of fun!
Skydrill
Here's my latest 1/2A project. It's a Skydrill built from a kit available from Steve Adams at Select Hobbies. The parts are laser cut and it builds very nicely. It looks like a miniature Kaos. The span is 32" and it's powered by a Hypercolor Stage 3 Skyline .049 engine(a customized, modified Cox Sure Start .049 built by Tim Wiltse.) It has rudder, elevator, and ailerons operated by Hitec HS-55 servos and a Berg4L receiver. Just need to finish the radio installation and adjust the cg before the maiden flight occurs.
| Thread Tools | |
| Gallery Post your 1/2A pics | Tony Oliver | 1/2A Planes | 134 | Feb 14, 2004 06:34 AM |
| Post Your Zagi 400X Pics Here | HavingFun2002 | Foamies (Kits) | 63 | Feb 02, 2003 01:21 AM |
| Post your Aeroflakes meet pics here | Jgardner | Indoor and Micro Models | 38 | Jan 24, 2003 03:44 PM |
| Post your fun fly pics here. | Paul Susbauer | 3D / Fun Fly Fuel Planes | 8 | Jan 23, 2003 03:11 AM |
| Post Your Corona Building Pics | cactus | Electric Heli Talk | 27 | Jun 05, 2002 08:34 AM |
