Old Sep 09, 2013, 01:46 PM
EndOfDays is offline
Find More Posts by EndOfDays
EndOfDays's Avatar
Austria, Niederösterr., Eggenburg
Joined Jan 2010
Build Log
Project 30mm
Yet another copter is going to be build, the title is according to the diameter of the rods used for this copter. My last project aber 12mm rods can be found here:
http://www.rcgroups.com/forums/showthread.php?t=1880665
This time not the flight time only is the major focus, but the ability to lift a reasonable payload for a reasonable time.
Today I got the first components delivered, the 30mm rods, which have nice quality. The rods are 30/24mm meaning, that they have 3mm wall thickness, which is enough to carry payload in the desired range. The weight per meter is 275gr, so I hope to be able to keep the frame below 2kg in the final stage (incl. motor mounts and additional CFK reinforcements).
Hier a pic of the rods:
and here a drawing of the copter (will be an X8), the length of the rods is 1m each.
and an optional variant:
best regards
Ferdinand
EndOfDays is offline Find More Posts by EndOfDays
Old Sep 10, 2013, 06:58 AM
EndOfDays's Avatar
Joined Jan 2010
Finally the Propeller and motors arrived ...
U-Motors 100KV:
Propeller 28x9,2
If they fly as they look ...
best regards
Ferdinand
Old Sep 10, 2013, 07:04 AM
flylite is offline
Find More Posts by flylite
I Like Popcorn
flylite's Avatar
UK, Greater London, London
Joined Oct 2009
Wow, this is going to be an impressive build!
Thanks for sharing EOD
flylite is offline Find More Posts by flylite
Old Sep 10, 2013, 07:05 AM
thach is offline
Find More Posts by thach
thach's Avatar
South Korea
Joined Oct 2012
OMG It's really big.
How much are the motors & propellers?
thach is offline Find More Posts by thach
Old Sep 10, 2013, 07:06 AM
ThomB is offline
Find More Posts by ThomB
Joined Dec 2011
lol again an extreme build
ThomB is offline Find More Posts by ThomB
Old Sep 10, 2013, 07:11 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Ferdinand, I knew you wouldn't disappoint us. Thank you for being the pioneer in endurance flight!
Sid3ways is offline Find More Posts by Sid3ways
Old Sep 10, 2013, 08:46 AM
chuenwe is offline
Find More Posts by chuenwe
chuenwe's Avatar
United States, NY, Huntington Station
Joined May 2012
Holy batman!!!
chuenwe is offline Find More Posts by chuenwe
Old Sep 10, 2013, 09:44 AM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
I I have been wanting to do a build with those motors and props for months now but the price is out of my budget right now I'm really glad somebody is finally going to put these new motors to the test because ice been wanting to know how they perform. Good luck with your build I'll be waiting anxiously for the videos
flohio117 is offline Find More Posts by flohio117
Old Sep 10, 2013, 09:57 AM
hugy is offline
Find More Posts by hugy
hugy's Avatar
Joined Apr 2010
Ferdinand as always you are awesome. Following with great interest.
hugy is offline Find More Posts by hugy
Old Sep 10, 2013, 11:42 AM
Stefan_Go is offline
Find More Posts by Stefan_Go
Stefan_Go's Avatar
Finland, Pirkanmaa, Valkeakoski
Joined Sep 2012
An X8 with hose motors?
You don't do things half way, do you? I'm so subscribed to that because if I ever got the budget, I was thinking of building a Y6 with those drive train.
Stefan_Go is offline Find More Posts by Stefan_Go
Old Sep 10, 2013, 03:19 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
I think you would get a longer flight time just going to a hex or octo. I'm not sure if flight time is what your shooting for but an x8 seems less efficient. Either way it's pretty awesome lol.
Old Sep 10, 2013, 03:42 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Great build!!! Can't wait to see it working.
RCvertt is offline Find More Posts by RCvertt
Old Sep 10, 2013, 03:44 PM
EndOfDays's Avatar
Joined Jan 2010
You can do a quad that is more efficient, but if you want to build a lifter (for a reasonable payload) you have to try hard to beat the X8 with a hex, but you will never beat it with a flat octo, you will never be able to build a frame that lightweight (for a flat octo) that would allow to take advantage of the better prop efficiency. In this particular case you have to think of a frame that has a diameter of 2m(!) (that has to be done in a rigid way).
best regards
Ferdinand
Old Sep 10, 2013, 05:24 PM
Cyberdactyl is offline
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
Over/under counter rotating prop systems are always around 15-30% less efficient than allowing a single prop to have its own undisturbed and non-accelerated air.
http://www.humanpoweredhelicopters.o...sa-tp-3675.pdf
Cyberdactyl is offline Find More Posts by Cyberdactyl
Old Sep 10, 2013, 07:07 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
best regards
Ferdinand
yeah I see your point. are you going to use regular lipos for it or the Li-ion batteries?
Build Log B.A.D. Omega Project 30mm Jet Fighter +Video/plans X-1 & X-2 Freddie B Micro EDF Jets and Power Systems 241 Feb 08, 2016 11:09 AM
Discussion Project: twin 30mm edf with differential thrust. airfoil'd Micro EDF Jets and Power Systems 0 Aug 11, 2013 07:51 PM
Build Log 747 30mm EDF build hi2nr RC Airliners (Commercial, Cargo, Troop Carrier) 31 Feb 09, 2013 01:32 PM
Discussion Projects using 30mm EDF? mkcp40 Micro EDF Jets and Power Systems 22 Jun 02, 2012 11:22 PM
Wanted 3s 1800(ish)mah 70mm x 30mm x 30mm Toker Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 10, 2011 07:58 AM
