Old Sep 09, 2013, 12:31 AM
HGT is offline
HGT
Find More Posts by HGT
HGT
United States, CO, Parker
Joined Jan 2013
Build Log
DJI X8 Phantom
I am moving my pics of the X8 Phantom build to a dedicated little thread so I can keep all the pics together. The Phantom thread moves at light speed.
To help understand the pics better, I will try to explain what I did.
This first pic is of the remaining 6 ESC's. I remove all wiring and the LED's from 1 of each pair so I can sandwich them together closer. The stock capacitors are only rated for a 3S battery so I replaced them with a higher voltage value to accept a 4S battery.
This is what has to be done to the bottoms of the arms. They are not perfectly flat and there is a hump next to the LED cover that has to be removed. I milled an area for the motor to sit flush and opened up a center hole for the shaft and lock washer to clear. Since the motor is pushing up I used only 2 screws to secure the motor and the last opening is for the wiring.
This is the bottom ESC after wiring is completed. The top ESC is soldered to the same wiring by scraping the PCB to remove the coating over the copper.
This is of course how the stock board and BEC appear. I removed all components and gave it an insulating coating of rubberized paint.
The DJI LED/BEC are 2 separate components after they are separated. The copper shafts holding them together are soldered in place so heating them allows the shafts to be removed and the BEC portion was used. I scraped 2 new areas to solder the BEC to so there was no wiring showing.
One down, 3 to go...
A close up of the ESC sandwich.
Wiring size was increased and soldered ends coated in liquid tape.
The stock motor mounts were lowered and chamfered out to match the screw heads so they sit securely in place. The new motor mounts were made from some black PCB board and shaped to fit snug in the arm.
A pic of the motor wiring going into the arm.
The remaining pics are of the completed mod.
DJI X8 Phantom by High Gain Tuning. (5 min 6 sec)
HGT is offline Find More Posts by HGT
Old Sep 09, 2013, 02:25 AM
Ryhza is offline
Find More Posts by Ryhza
Closed Account
Joined Jan 2012
Nice HGT looks awesome
Ryhza is offline Find More Posts by Ryhza
Old Sep 09, 2013, 02:35 AM
Olivier_C is online now
Find More Posts by Olivier_C
Since 1902. Maybe.
Olivier_C's Avatar
France, RA, Grenoble
Joined Dec 2004
Definately looking great, and cool noise, or are all Phantom making this noise, is that the hollow plastic frame ?
Olivier_C is online now Find More Posts by Olivier_C
Old Sep 09, 2013, 02:48 AM
ThomB is offline
Find More Posts by ThomB
Joined Dec 2011
nice idea, im going to do the same but not with the standard esc but the 4in1 qbrains.
ThomB is offline Find More Posts by ThomB
Old Sep 09, 2013, 03:16 AM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
Quote. The Phantom thread moves at light speed.
Not as fast as your Phantom. Very cool.
Paul@SCC is offline Find More Posts by Paul@SCC
Old Sep 09, 2013, 04:11 AM
Aaalie is offline
Find More Posts by Aaalie
Aaalie's Avatar
Netherlands
Joined May 2006
I was wondering how you land this little lightning?
BTW, super project!!
Aaalie is offline Find More Posts by Aaalie
Old Sep 09, 2013, 04:12 AM
karlomatuguinas is offline
Find More Posts by karlomatuguinas
Joined Aug 2013
nice hgt... thumbs up... hope you can post details on how you did this, this is much better the phantom v1.2.... next build is this, buy a low priced phantom v1 and upgrade it to x8 "the HGT mod"...
karlomatuguinas is offline Find More Posts by karlomatuguinas
Old Sep 09, 2013, 04:47 AM
ariZedA is online now
Find More Posts by ariZedA
Joined Jul 2013
very interesting! what are these dual propeller setups called?
and I suppose the prop wash from the top propeller feeds the bottom propeller and vice versa contributing? very cool if so!
ariZedA is online now Find More Posts by ariZedA
Old Sep 09, 2013, 04:59 AM
ThomB is offline
Joined Dec 2011
called X8
Old Sep 09, 2013, 05:48 AM
Joined Jul 2013
Originally Posted by ThomB View Post
called X8
Ah yes I get it now Would love to see a X8 F550 setup
Old Sep 09, 2013, 06:44 AM
Since 1902. Maybe.
Olivier_C's Avatar
Joined Dec 2004
Then that'd be a X12
Old Sep 11, 2013, 11:58 AM
HGT is offline
HGT
HGT
Joined Jan 2013
I like that device and it would make a very neat installation in some quads, especially those with small CF boom tubes.. Definitely no room for 2 of those in a Phantom though. The second stacked Phantom ESC essentially takes no extra room away from anything else.
Old Sep 11, 2013, 12:00 PM
HGT is offline
HGT
HGT
Joined Jan 2013
I have some gear that should be here this week. Not a lot of choices that clear the bottom props but I found a set.
Right now it takes off of any flat surface.
Old Sep 11, 2013, 12:11 PM
HGT is offline
HGT
HGT
Joined Jan 2013
If there's anything you don't see how I did it just ask here and I will post it.
With all due respect to DJI and I did use all DJI components in this build, I have to agree. I have a lot of ideas for DJI when it comes to airframes that would increase their ESC and motor sales. I was really hoping to see a larger Hex Phantom as they just fly so well and I like clean builds.
I have modified the door opening a bit more and it now accepts a 3S 4400 mAh battery I made from 2 OEM Phantom batteries. I now get a full 17 minutes with my first alarm set to 11.1 volts. Total weight is right around 1200gr.
Old Sep 11, 2013, 12:18 PM
ThomB is offline
Joined Dec 2011
everything can be made fit Would you recommend these dji motors? and why not on 4s? no room?
Sold DJI-PHANTOM DJI Phantom Quad Copter RTF ig720 Aircraft - Electric - Multirotor (FS/W) 2 Apr 29, 2013 07:44 PM
Discussion DJI Phantom or DJI F550? ThePhantomMenace Multirotor Talk 4 Apr 14, 2013 07:18 PM
Sold *PriceDrop* Droidworx/Photohigher Quad/Hex/Octo/Y6/X8 + AXI 2814/22's + DJI Wookong-M Huddo Aircraft - Electric - Multirotor (FS/W) 8 Feb 10, 2012 03:55 PM
