Old Dec 08, 2001, 11:01 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Smallest Li-ion Cells for Low-Voltage Motors?
Reading some of the talk about small, low-voltage motors such as the N20 made me wonder how one of these might work with a single 3.6V Li-ion cell. So far, the lightest Li-ion cell I've seen that might work is the 600mAh Neopoint 1000 discussed in the thread below. The 2-cell pack weighs 39 grams, so a single cell would weigh ~ 20 grams (~ 3/4 oz.). That's about double the weight of a 3-cell 50 mAh NiCd pack, but with about 12 times the capacity. Has anyone seen any smaller, lighter Li-ion cells available at the same kind of low prices as other surplus cell phone packs?
http://www.rcgroups.com/forums/showt...light=Neopoint
Dave Hederich is offline Find More Posts by Dave Hederich
Old Dec 08, 2001, 03:19 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Dave,
I have looked at both the Sony, and Panasonic lithium ion data, and I think that is about the lightest you are likely to find. Sony has a cylindrical 570mah cell that is 16g but I don't know if it was used in any cell packs. If you want lighter than that you will probably have to go to lithium polymer.
Jeff
jeffs555 is offline Find More Posts by jeffs555
Old Dec 08, 2001, 03:56 PM
Joined Feb 2000
I was thinking Li-ion because it is an older technology and there is more likelihood of finding cheap, surplus Li-ion cell phone batteries. I hadn't really thought about lithium-polymer (Li-poly?) because I don't know much about it other than it is a newer technology and probably better than Li-ion. So there's a new question to ask: Anyone seen any small, cheap, surplus Li-poly cells for sale?
Old Dec 08, 2001, 05:21 PM
Tuomas Pietinen is offline
Find More Posts by Tuomas Pietinen
F5D father
Tuomas Pietinen's Avatar
Vantaa, Finland
Joined Mar 2001
li-ions
I have a 12 grams 570 mA cell. Where it came from I canīt say. I tested it and it gives 25 min with 1.5 A load. Not bad. Gonna try a 2-pack of these in my Tiny with Wes Tecnik motor. The source of these cells will provide soon? polymer cells with double capacity but they are yet less reliable and lot of tolerance occurs in different producing stocks. Look at your mobile phone...the truth is out there!
tuomas
Tuomas Pietinen is offline Find More Posts by Tuomas Pietinen
Old Dec 08, 2001, 10:11 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
Dave,
Since the Li-poly is such a new technology, I doubt that you will find the kind of deals we have been getting on Li-ion. The only cell phone packs I have seen are the single cell packs for the Nokia 6100. Nokia has a 600mah and Ultra-life has a 750mah pack. The prices are in the $29-$39 range. I would expect the stripped weight of these cells is around 15 grams. Here is a link to the Ultra-life site. They have standard cell sizes down to 30mah at 1.5 grams, but I don't think you can buy the raw cells unless you are a manufacturer.
Jeff
http://www.ulbi.com/product-display.asp?ID=39
PS
I just weighed the Neopoint 1000 cells and they are just a hair under 19 grams each.
Old Dec 09, 2001, 01:43 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Out of interest, WES Technik do a 450 mAh Li Ion cell that weighs 14g. Not cheap though!
http://www.wes-technik.de/English/news.htm
Bill Glover is offline Find More Posts by Bill Glover
Old Dec 13, 2001, 01:14 PM
lymon is online now
Find More Posts by lymon
Senior Member
Houston
Joined May 2001
CR2 primary cells (3v 800mah) weigh about 11g... they can be found for $2-3
lymon is online now Find More Posts by lymon
Old Dec 17, 2001, 09:30 AM
KatManDEW is offline
Find More Posts by KatManDEW
FASST flyer
KatManDEW's Avatar
USA, OH, Newark
Joined Sep 2001
Are those CR2 cells rechargable?
KatManDEW is offline Find More Posts by KatManDEW
Old Dec 17, 2001, 09:46 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
The CR2 cells are "not" rechargeable. Having said that, there was quite a discussion a while back about an article in RCmicroflight about a charger for li-ion, that just happened to charger CR2 type primary cells as well. The schematics for the charger were quickly removed from the RCmicroflight web page because of the dangers associated with charging non-rechargeable cells. The author of the RCmicroflight artical said that he had (if memory serves me) averaged about 10-30 cycles before the batteries would no longer recharge. I'll see if I can find a link for the charger, (any li-ion/metal charger should do as long as the voltage cut off is set right), if you want to search for the info, I'd suggest looking under "banned charger". I've got some CR2's that I eventually plan to try to recharge, I just don't have a plane to discharge them with yet. You can pick up CR2's DIRT cheap on ebay.
Jim McPherson is offline Find More Posts by Jim McPherson
Old Dec 17, 2001, 08:20 PM
JoeyC is offline
Find More Posts by JoeyC
JoeyC's Avatar
Valencia, CA
Joined Oct 2001
The smallest commercial Li-ion cell is NEC's 3.8V, 150 mAh prismatic cell that weighs 5 g. NEC also has a 300 mAh that weighs 8.5 g. I don't know if these are available as surplus (I doubt it).
http://www.necel.com/battery/laminate.cfm
JoeyC is offline Find More Posts by JoeyC
Old Dec 18, 2001, 02:24 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Just remember, I will delete posts that show how to charge non-rechargeable L-I cells.
There are dangers involved that some may not head. If you wish to exchange info yourselves, that is up to you.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Feb 14, 2002, 02:21 PM
hotairflyer is offline
Find More Posts by hotairflyer
No Dear its not a new one
hotairflyer's Avatar
Joined Nov 2001
Tuomas Pietinen
Did you ever find the source of the 12g battery you have mentioned? I am interested in trying one in a MICRO IFO that I am building.
THanks
hotairflyer is offline Find More Posts by hotairflyer
Old Feb 14, 2002, 06:22 PM
crossup is offline
Find More Posts by crossup
Senior to who? Member
crossup's Avatar
Annapolis, Maryland USA
Joined Feb 2001
Small Li-Ion
Went to my local (500') electronic supply store and WOOHOO!!! Li-Ion batteries out the wazoo. They had about a dozen Tadirans in 2or3 sizes, and various Li-Ions from button cell to about 3K mah. Only bad part is the prices are astronomical when you 're used to Mark Hacketts prices.
Anyway, Im suggesting those of you who lust after these, check your non-chain( not Radio Shack, in other word) electronics store- hopefully you will get the same surprise I did
crossup
crossup is offline Find More Posts by crossup
Old Feb 14, 2002, 06:33 PM
JoeyC is offline
JoeyC's Avatar
Valencia, CA
Joined Oct 2001
crossup,
Are you sure these are rechargeable Li-ion? As far as I know Tadiran only makes primary, non-rechargeable Lithium batteries (Lithium Thionyl Chloride). DO NOT CHARGE THESE BATTERIES!
Old Feb 14, 2002, 06:58 PM
planeman is offline
Find More Posts by planeman
High Exalted Poohbah
planeman's Avatar
Atlanta, GA USA
Joined Sep 2001
For cheap Li-ion and Li-poly batteries go to eBay and search on these terms or by the cell phone battery pack manufacturer and the above terms.
I just bought two Li-poly Qualcomm battery packs containing two 3.5 volt batteries for $12.00 each (normally $60.00). You have to break open the molded plastic from around the batteries to get the batteries out and you will have to solder and set them up...but its cheap!
I also got 20 Li-ion 830mah batteries for about $1.50 each.
Planeman
planeman is offline Find More Posts by planeman
Finding out "C" ratings for li ion cells? Daniel G Batteries and Chargers 4 Aug 28, 2005 09:16 PM
Looking for larger cylindrical li-ion cells- will pay anything! davidp Batteries and Chargers 4 Apr 20, 2004 10:54 AM
A good use for those surplus Li-Ion cells Capt. Electron Life, The Universe, and Politics 3 May 11, 2003 04:44 PM
looking for cheapy Li-Ion cells for experimental configurations. L.I.A. Batteries and Chargers 0 Apr 17, 2003 07:05 AM
Question How many Li-Ion cells for RX??? CactusJackSlade Batteries and Chargers 12 Nov 25, 2002 10:54 AM
