Old Feb 12, 2004, 09:56 PM
tripxrcer is offline
Find More Posts by tripxrcer
Just Keep Swimming ju....
tripxrcer's Avatar
Phoenix Arizona! Wanna fly? All year round is guoooud.
Joined Oct 2003
Multiplex cockpit MM, flaperon mixxing? help please
Hey
I recently recived a mulitplex cockpit MM and i cant seem to figure out the flaperons, is it posable to have the allerons go down when i pull on the elevator or can you only do it with the slider?
ALSO
I cant seem to get the throtal to set the "center" to the accual center of the stick, its set so the center is accually at the bottom.
ALex
tripxrcer is offline Find More Posts by tripxrcer
Old Feb 13, 2004, 11:24 AM
wildpalms is offline
Find More Posts by wildpalms
Professional idiot
Hampshire, UK
Joined Jun 2002
It is possible to use the ailerons as flaps and this will usually be controlled by the slider.
What you can't do with the Cockpit is mix the flap function into the elevator.
wildpalms is offline Find More Posts by wildpalms
Old Feb 14, 2004, 01:12 PM
Smashed_Toad is offline
Find More Posts by Smashed_Toad
Smashed_Toad's Avatar
Joined Dec 2003
Not true! The Cockpit Flap Comp is in the mix.
Do you have V1.0 or V2.0 software?
In the set up menu you can choose to center on either side or in the center.
Smashed_Toad is offline Find More Posts by Smashed_Toad
Old Feb 15, 2004, 04:24 AM
Professional idiot
Hampshire, UK
Joined Jun 2002
I have version 2. I haven't used it in a while but the Flap/Elev Comp mix applies elevator in response to flap? IE You use it to correct the pitch change from applying flap.
I thought Alex was looking for the opposite IE when he pulls up elevator the flaps drop and vice versa. Something I never go mine to do.
Dave
Old Feb 15, 2004, 10:53 AM
tripxrcer's Avatar
Joined Oct 2003
i have 1.0,
so you can do spoilers? sinked with the elevator?
ALex
Old Feb 16, 2004, 02:28 AM
rorywquin is offline
Find More Posts by rorywquin
Turbines suck ;-)
United Kingdom, Hillam
Joined Mar 2000
Originally posted by tripxrcer
i have 1.0,
ALex
Yes - it will be in the elevator compensation menu! You can also compensate for throttle on the elevator
rorywquin is offline Find More Posts by rorywquin
Old Feb 16, 2004, 02:36 PM
Professional idiot
Hampshire, UK
Joined Jun 2002
Can someone explain how to do it. I've been through the compensation mixers and all they do is apply elevator compensation when the other controls are applied IE Down elevator when I open the throttle or when I apply flap. I can't find one that will apply flap when I move the elevator stick.
Dave
Old Feb 17, 2004, 04:06 AM
Turbines suck ;-)
Joined Mar 2000
WP
I don't think you can do that - I sold mine a while back (mistake - should have kept it as a spare).
IIRC there is only spoiler/flap>elevator and throttle>elvator mixing (compensation) not, the other way around!
Old Feb 17, 2004, 10:54 AM
Joined Dec 2003
Yup only the other way around unless you trick the radio! plug flap into elevator and elevator into falp then adjust the mode to match Poof you have flap -> elevator mix weird but depending on your planes in theory would work.
Multiplex Cockpit MM... need your advise and help tripxrcer Electric Plane Talk 6 Jan 12, 2004 12:17 PM
WTB MULTIPLEX COCKPIT MM or 3030 dunwrkn Aircraft - Electric - Airplanes (FS/W) 3 Feb 27, 2002 11:32 AM
Multiplex Cockpit MM jdoan Vendor Talk 1 Jan 07, 2002 04:24 AM
RCJOY with Multiplex Cockpit MM & Realflight G2 ARE Electric Plane Talk 2 Nov 03, 2001 04:13 PM
Multiplex Cockpit MM Question / Throtle Radek Z Electric Plane Talk 4 Oct 11, 2001 12:41 AM
