Old Sep 04, 2013, 10:42 AM
Bidwin is online now
Find More Posts by Bidwin
United States, TN, Nashville
Joined Sep 2007
Question
Motor Specs?
I posted the following questions in the Beginners Training Area but maybe it's better here. If a moderator sees this would you please delete my post from the Beginners forum?
I want to use some of the sizing tools but don't have complete motor specs. How can RM and Io be determined if they're not specified by the motor manufacturer? Is there a way to estimate them?
bidwin
Bidwin is online now Find More Posts by Bidwin
Old Sep 04, 2013, 12:32 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
If the motor is in the DriveCalc database you can get those figures from there. You can't estimate but if you have the motor on hand you can measure and calculate. No-load current and RPM at two different voltages then amps and RPM from 4-5 props at the same voltage.. plug the numbers into DriveCalc and you'll get what you need.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 04, 2013, 01:58 PM
Joined Sep 2007
Originally Posted by Dr Kiwi View Post
No-load current
Thanks for the response, Dr Kiwi. Can I get the no-load current with a watt meter or is there a better way?
Old Sep 04, 2013, 03:49 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
Yep! Just run at WOT without the prop for the shortest time you can, to get a reading [long no-load runs simply generate heat with no cooling available!]. Obviously, to use the Io any further in computations of Kv/Rm etc you'd need RPM without the prop, then amps/RPM with various props.
Sold NEW Team Orion Vortex 8 4 pole, 2000kv Brushless Motor 1/8 scale race spec 2s-4s aquaanox Cars - Trucks and Parts (FS/W) 0 Jan 22, 2013 05:09 PM
Question motor specs. dkm1971 Electric Plane Talk 3 Jan 21, 2013 11:11 PM
Help! help required ! motor specs.. avionicboy Power Systems 4 Jan 05, 2013 10:43 PM
Help! help required ! motor specs.. avionicboy Modeling Science 1 Jan 05, 2013 02:15 PM
