Old Feb 12, 2004, 06:49 PM
Heli Mod Man is offline
Find More Posts by Heli Mod Man
---------Speed!!---------
Illinois
Joined Jul 2003
Axi primary belt drive for Corona -Beta test-
Hello fellow Coron-addicts!
Well, I have been experimenting with a primary belt drive for use with the Axi 28 20 10 motor. This is a 4 to 1 ratio primary belt drive designed for ultra high torque Axi motor on 3 cell lithiums.
I have tried numerous setups and have been plagued with belt skipping issues due to the extremely high torque of the Axi on lithiums.
I finally settled on this setup. It is an XL belt (nearly every belt drive for small electric helis are MXL). The XL belt (though a bit clunky looking) has much more tooth depth and, therefore, less skip tendency.
This thing runs SOOO smooth and quiet. The torque curve is great as well.
I am making two of these belt kits available as betas to those who would like to try it out. The belt kits are free, however, you must buy the motor. I can sell you one (I have one extra, brand new motor) or you can purchase your own motor (Axi 28 20 10).
The only request I have is that those who recieve them must be serious about using the belt drive and that they post their findings here on the board within a reasonably short period of time. I am doing this to work out any bugs the system may have, so I am hopeful to get some good feedback on it!
Thanks Guys!
Matt Shumaker
Ballistic Technology Inc.
Heli Mod Man is offline Find More Posts by Heli Mod Man
Old Feb 12, 2004, 06:51 PM
Illinois
Joined Jul 2003
Here you go!
Remember, the belt kit is free, not the motor. The motor is pictured as a reference.
Matt......
Old Feb 12, 2004, 06:58 PM
gyrodude is offline
Find More Posts by gyrodude
Joined Jan 2004
Matt will that motor only work on lithiums.......not on 8 cell hr 2600 nimh packs
gyrodude is offline Find More Posts by gyrodude
Old Feb 12, 2004, 07:00 PM
Illinois
Joined Jul 2003
Good question. Out runners are much more efficient on higher voltages. This motor has BIG power on 3 cell lithiums. 8 cells would be fine. 9 cells would be perfect.
Matt....
Old Feb 12, 2004, 07:02 PM
gyrodude is offline
Joined Jan 2004
How much for the Motor...?
Old Feb 12, 2004, 07:34 PM
Illinois
Joined Jul 2003
The motor is $100.00.
You can find them for a few bucks less if you shop around. Venture Hobbies carries them for (I think) $94.00 plus shipping.
Their number is (847) 537-8669. Ask for Erik or Brian.
Matt.......
Old Feb 12, 2004, 07:51 PM
SouthPaw is offline
Find More Posts by SouthPaw
Sterling, VA
Joined Nov 2003
Is a CC35 a big enough ESC for that motor/setup? I suspect it is probably borderline at best with the high torques.
George
SouthPaw is offline Find More Posts by SouthPaw
Old Feb 12, 2004, 08:00 PM
gyrodude is offline
Joined Jan 2004
Hobby Lobby has a Jeti 40 for $94....
Old Feb 12, 2004, 08:28 PM
Illinois
Joined Jul 2003
A 35 would be fine. It draws roughly 30 amps under normal full throttle, 34 to 35 max.
Matt.....
Old Feb 12, 2004, 08:39 PM
HankF is offline
Find More Posts by HankF
Joined Apr 2000
Does your Corona really require that big an AXI? What kind of weight are we trying to lift? Or is it a problem of a matching Kv?
I've got a 2820/10 in a 70 ounce converted Slowpoke plank which it motors along quite well. I'm surprised the Corona takes that much.
Hank
HankF is offline Find More Posts by HankF
Old Feb 12, 2004, 08:53 PM
Illinois
Joined Jul 2003
The 28 20 10 is a 280 watt motor. A Hacker is (I believe) 284 watts. You could go with a smaller motor. But, I have found heat build up to be a bit of an issue with smaller outrunners.
The biggest issue for me is performance. Matching KV is the next reason.
Matt........
Old Feb 12, 2004, 09:26 PM
SouthPaw is offline
Sterling, VA
Joined Nov 2003
Matt,
I would love to test this out for you but I'm a new flyer and I'm just now starting to transition to FF. I don't think I could test the system as well as someone with better flying skills.
Is the main shaft pulley sized to fit a 5mm shaft?
George
Old Feb 12, 2004, 09:35 PM
Illinois
Joined Jul 2003
It doesn't matter. The pulley has a 1/4" ID. I will be including a bore reducer to step it down to the proper diameter. 4mm or 5mm, no big thing!
Matt......
Question BT Tail belt drive for the Corona yaremchl Electric Heli Talk 3 Sep 21, 2006 05:21 AM
Wanted Wanted: Tail Belt Drive for Corona HARRomeo Aircraft - Electric - Helis (FS/W) 0 Oct 16, 2005 08:49 AM
FS: AXI motor, CC35 and Matt's Belt Drive for Corona 11290 Aircraft - Electric - Helis (FS/W) 1 Nov 04, 2004 03:42 PM
Efficiency of MR belt drive for Corona BigDave Electric Heli Talk 8 Oct 27, 2004 02:03 PM
Dave's belt drive for corona (main)? spacecase Electric Heli Talk 7 Feb 11, 2004 06:19 PM
