This thread is privately moderated by helinor, who may elect to delete unwanted replies.
Old Sep 03, 2013, 05:59 PM
helinor is online now
Find More Posts by helinor
says hello from Norway
helinor's Avatar
Norway, Telemark, Skien
Joined Mar 2013
Build Log
HJ 450 build and some mods
Have now built my HJ 450 quad. Uses XXD 30A ESC`s and XXD 2212 920kv motors. 1045 props. FC is KK2.0 mounted on lower plate. Maiden on default settings went ok.
helinor is online now Find More Posts by helinor
Old Sep 20, 2013, 08:28 PM
helinor's Avatar
Joined Mar 2013
Update
HJ450 ready...and it flies
Spec:
HJ 450 frame
DJI 920KV motors
DJI 30A OPTO ESC`s
DJI 10x38 props
Turnigy 3A BEC
KK2.0 FC board running V1.6 sw
Align 600 landing skids
Running on 3S battery
Fly Sky FS-T6 Tx and Fly Sky 6ch Rx. Soon to be Spektrumized...
Next will be to make a mount for my GoPro
Old Oct 01, 2013, 05:16 PM
helinor's Avatar
Joined Mar 2013
New update for my HJ450 build.
Changed the landing gear for some DJI F450 ones to get the space I need for the GoPro. Using the protection case hard mounted to the bottom plate with a tripod mount for now. Maybe some sort of gimbal next.
Quad flying Treungen (5 min 30 sec)
Old Oct 18, 2013, 04:28 AM
helinor's Avatar
Joined Mar 2013
Update with settings for KK2 and DX6i
Next update:
Modified a lower plate to go on top to get better attachment of the battery when I have my GoPro on.
Here you have my settings with version 1.6 by KK :
Ail/Ele (linked)
P gain 50
P limit 25
I gain 25
I limit 20
Rud
P gain 50
P limit 20
I gain 50
I limit 10
Self level
P gain 50
P limit 5
acc trim roll 0
acc trim pitch 0
Stick scaling
Ail/Ele/Rud 50
Throttle 60
Minimum throttle 15
Old Feb 17, 2014, 08:16 PM
helinor's Avatar
Joined Mar 2013
Here you have my latest mod. I got a very bright LED lamp and put it up front of the quad. I can see it from a very far distance and it helps vith orientation. Here is a link to the LEDs
http://www.banggood.com/Wholesale-2x...r-p-50211.html
Just mounted it with a zip tie to test it but will make a better mount for it eventually It is wired to a JST plug soldered to one of the ESC soldering pads.
Old Feb 17, 2014, 10:59 PM
nom is online now
nom
Find More Posts by nom
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
Nice build! Going to start my own 450 with a camera mount. Thanks for posting, it will help me quite a bit!
nom is online now Find More Posts by nom
Old Feb 18, 2014, 01:53 AM
helinor's Avatar
Joined Mar 2013
If you look at this post you can se a bit more of how i did it on mine
http://www.rcgroups.com/forums/showt...php?p=26842676
Old Mar 30, 2014, 09:16 PM
banders5144 is offline
Find More Posts by banders5144
Joined Mar 2014
Hi there. I just want to say awesome build you have there. I recently just purchased a HJ450 frame off Amazon and putting together a quad. Using Pixhawk flight controller, NTM Propdrive 28-26 1200KV motors, Afro ESC 30A SimonK. I was wondering if you could post direct links to where you purchased your landing skids and mount/gimbal for your GoPro. I am definitely going for the same look you are and your progress gives me a lot of confidence on how mine will turn out. Also where did you purchase your nylon spaces from? Local hardware store or online? The prices I have seen online seem pretty steep. Again awesome build.
banders5144 is offline Find More Posts by banders5144
Old Mar 31, 2014, 03:15 AM
helinor's Avatar
Joined Mar 2013
Thanks for your kind words.
My quad is just going through a rebuild with a new controller. I got myself a Naza M lite (just the controller, no GPS for now) and has just mounted it and done some small changes.
Will have to set it up next.
Wishing you good luck with your build. Please post up some pics of it on the way
The landing gear is genuine DJI parts and were bought from allerc.com. I have swinged the front ones out a bit to get them out of camera view, and to get space for the camera mount. Se pic.
Link is here http://www.allerc.com/dji-fw450-550-...cs-p-8217.html
The camera mount was bought from Banggood.com
Link is here http://www.banggood.com/Walkera-QR-X...8-p-84143.html
I have ordered this mount now to try to get rid of a bit of jello on my videoes. Will report back when i have tried it on
http://www.banggood.com/Walkera-QR-X...-p-911721.html
My aluminium spacers for the front and back mounting to make the tabs stiffer I bought of ebay. Not cheap but works ok. I guess you could find them cheaper but remember they have to be 37mm long.
Link is here http://www.ebay.com/itm/Aluminum-M2-...item27e154124b
Old Apr 18, 2014, 04:53 PM
helinor's Avatar
Joined Mar 2013
New update
My new camera mount came in and is now mounted. The mount is from the Walkera QR X350 and uses anti vibration balls for jello free video. Have only tried it filming while hoovering but it looks like it works OK.
This is the link for the mount.
Have attached som pics of it.
Old Nov 04, 2014, 03:09 AM
helinor's Avatar
Joined Mar 2013
Naza GPS mounted...
Yippee! Well, almost done......(Corona build) RoNeRiC Electric Heli Talk 1 Sep 20, 2004 08:32 PM
just bought a twin max and almost done building it Pablito Parkflyers 0 Jul 20, 2002 10:47 PM
